Defender What is this leaking under the engine
Results 1 to 12 of 12
    Oct 2018
    JHB
    Default What is this leaking under the engine
    Hi
    I seem to be leaking something of this pipe under the engine.
    anybody got an idea what it is?
    where its coming from and how to fix?
Size:  34.4 KBName:  B398188D-330B-4F9A-B73D-66C87C2623E7_1_201_a.jpg
    Mar 2012
    Ballito
    Thanked: 92
    Default Re: What is this leaking under the engine
    I would guess power steering fluid. Looks like the type of pressure line which would likely hold either PS fluid or AC gas.
    Chris
    ZS5CMA
    '17 Hilux 2.8GD-6 D/C 4x4 A/T
    Thanked: 96
    The one that is "wet" looks like the aircon pipe
    I would guess that it is merely transporting the oil down it so look higher up for the actual leak
    My power steering box on the D1 uses atf oil and is a bright red ,
    If it is black then it could be your oil cooler on the radiator and the oil has found its way to the aircon pipe
    My bet is the atf fluid is the cause of the leak
    Thanked: 170
    If you have a TD5 then that is the oil cooler pipe from the R380 gearbox
    Edwin
    Defender '99 TD5 Pick Up
    Rock sliders, Spare wheel carrier, Roof Rack, Aluminium canopy, Tentco RTT, Tentco Awning, 280Ah Dual batteries, 3 x Sliding Drawers, Water tank, Hot Shower, Kitchen
    Jun 2016
    Thanked: 7
    Definitely gear box oil cooler pipe
    Dec 2010
    klerksdorp
    Thanked: 142
    Just take two spanners and tighten it.
  7. The Following User Says Thank You to johnnybritz For This Useful Post:
    Thanked: 96
    Quote Originally Posted by Defender TAZ View Post
    Didnt know that on the R380
    Thanked: 170
    Here is is the cooler pipe
    Edwin
    Oct 2018
    JHB
    Neither did I.
    doing some research looks like it was only on defender outside of the UK.
    one forum recommended just blanking it off.
    anybody heard of doing this ?
    Oct 2015
    Thanked: 115
    Ditto on the cooler pipe. Dont blank it off. The oil pump feeds oil directly out through the pipe for cooling, which is the only sort of cooling for the R380.
    I fitted a cooler at the turn of the pipe for better cooling.
    Maybe some thread tape on that nut and tighten will seal the leak.
    Barry Enslin
    ONE LIFE!
    Aug 2015
    Whyalla
    Thanked: 49
    Thread tape is for plumbing, not automotive - a small bit breaking off can cause havoc!
    Thread seal fluid or correct tightening.
  13. The Following User Says Thank You to Tombie For This Useful Post:
  14. #12
    Dec 2014
    Thanked: 1965
    Check your oil level, too...
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
