VERY VERY Disappointed in GARMIN !!!! - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 40 of 81
  1. #21
    Thanked: 14993
    Default Re: VERY VERY Disappointed in GARMIN !!!!
    Quote Originally Posted by JCMostert View Post
    What is the reason why people still use GPS's? I've got a Garmin that is 5 years old, and I used it once. The cellphone does every that the GPS can do and do it better.
    Yes......except allow you to talk/whatsapp and navigate all at the same time.
    Phones don't multi task very well. Especially when you are driving and need to migrate between apps.
    EDIT: and I still have to find even a rugged phone that can handle dashboard temperatures...........and don't tell me to use some stupid stick on cradle that then puts the phone outside of my Line Of Sight.
    Jakes Louw
  2. The Following User Says Thank You to jelo For This Useful Post:
  3. #22
    Thanked: 320
    Oh... And then there is T4A when touring Africa...
    2017 Mitsubishi Triton 2.4 D/C 4X4 Auto Diesel
    Lynx Bashplate
    DIY Drawer system
    DIY Drop Fridge Slide
    My ULTIMATE dual battery box
  4. #23
    Feb 2018
    Thanked: 1200
    If you have the same problem as I had this what I did, I filed down a piece of plastic used in the glue gun to the right size and inserted it into the hole and put insulation tape over it to make it water proof, just not too tight other wise it switches on. I use it for canoeing but I do replace the insulation tape every six months just to make sure that it's intact and waterproof. I guess one could add a bit of silicon glue to the edges of the insert to seal it better but so far insulation tape does the trick.
ID:	582428   Click image for larger version.
ID:	582429   Click image for larger version.
ID:	582430   Click image for larger version.
  5. The Following 2 Users Say Thank You to River Rat For This Useful Post:
  6. #24
    Thanked: 172
    Electronics products are consumables, accept it.
    Try finding spares for a five year old notebook or smartphone.
    Besides, who would want to use a 5 year old smartphone?
    The days of stand-alone GPS units are numbered anyway.
  7. The Following User Says Thank You to Makaira For This Useful Post:
  8. #25
    Thanked: 764
    The "lussie" of the strap of my Forerunner watch broke.
    I see loops are available ​​Forerunner® 235 Band Keeper @ R50 when I last checked, FWIW.
  9. The Following User Says Thank You to PieterOos For This Useful Post:
  10. #26
    Thanked: 764
    Depending on application. I still prefer my Garmin OR650 on a RAM mount when navigating gravel routes and trails on my MTB, than a mounted cellphone. (Same when hiking in the 'Berg etc)
    I will also rather keep the cell phone in a more safe / secure place for backup, than to risk damaging it and to cut off a comms line.
  11. #27
    Thanked: 14993
    Quote Originally Posted by SinWolf View Post
    errr, ummm, as far as I know, T4A is now available on iOS and Android........
    Jakes Louw
  12. #28
    Thanked: 47
    Not with full functionality though
    "A clear conscience is usually the sign of a bad memory"
  13. The Following User Says Thank You to mufie For This Useful Post:
  14. #29
    Umhlanga
    I had the exact same issue with my Montana 600 early last year. Took it to Navworld in Durban. Actually they were in Mount Edgecombe. They said Garmin dont do repairs but would exchange it for a newer model at cost. I paid R2400 and got the new 680 Montana. Dont know why they not doing the same for you!
  15. #30
    Friemersheim, Southern Cape
    Thanked: 3380
    They could not even sell me a new strap, whats to say the "lussie"
    And it is not even an old/discontinued product.
    Me thinks it is Garmin SA that is so useless.
    BTW, an O-ring solved my problem. As well as what to buy in future
    Wife's Forerunner strap broke....sent unit to Jo'burg. Told discontinued...offered another unit.
    They sent unit back as it was still serviceable. Got it back in a worse state and had to chuck it. Seems they tried to pry off the rubber casing instead of just saying sorry no repair possible.
    Robert van den Berg
  16. The Following 2 Users Say Thank You to Prof For This Useful Post:
  17. #31
    Sep 2012
    Waterfall
    And what do you do if you are in an area with no mobile phone reception? And what do you do if you have no data?
  18. The Following 2 Users Say Thank You to John Hollow For This Useful Post:
  19. #32
    Thanked: 172
    Quote Originally Posted by John Hollow View Post
    You use a paper map, like you used to do many years ago ...
  20. The Following User Says Thank You to Makaira For This Useful Post:
  21. #33
    Thanked: 363
    Quote Originally Posted by Makaira View Post
    I assume you are still using a Nokia 6610 from many years ago ?
    2006 VW Touareg 4.2 V8 Auto
    2000 Disco 2 GS 4.6 V8 Auto
    2013 Wildebeest Kalfie Boswa
    2002 Audi S6 4.2 V8 quattro
    2013 Freelander SD4 (SWAMBO)
    ORRA Z07
  22. #34
    Thanked: 764
    Offline maps, eg OSM etc. GPS (navigation) will still work.
    (Eg see https://wiki.openstreetmap.org/wiki/Android )
  23. The Following User Says Thank You to PieterOos For This Useful Post:
  24. #35
    Thanked: 14993
    I'd rather just download the maps on the phone and use them in offline mode............you guys do know that is a thing these days?
    Jakes Louw
  25. The Following 2 Users Say Thank You to jelo For This Useful Post:
  26. #36
    Thanked: 363
    OR.... just use the Garmin which was designed to do the job neh....
    ORRA Z07
  27. The Following User Says Thank You to TwinDisco For This Useful Post:
  28. #37
    Thanked: 14993
    Quote Originally Posted by TwinDisco View Post
    yep, sonder data of drama
    and you can load T4A as well as other maps, wow, who would have thought...........
    Tools fit for purpose. I don't use a vernier as a shifting spanner nor vice versa..............
    Jakes Louw
  29. The Following User Says Thank You to jelo For This Useful Post:
  30. #38
    Thanked: 172
    He doesn't know this, that's why he was on about the data.
  31. #39
    Apr 2015
    Table Top
    Thanked: 104
    Only works if you have cell phone coverage mate.
  32. #40
    Thanked: 1353
    I'm still using a Nokia 3310...
    (Disclaimer: I'm a Technological Terrorist and believe a phone is for phoning...)
    Ettienne de Kock
    1998 Nissan Patrol 4500 GRX
    1959 SII 88"
    197? RRC
  33. The Following 2 Users Say Thank You to EttiennedK For This Useful Post:
