Suspension Gavinjimny
Results 1 to 1 of 1
Thread: Gavinjimny
    May 2014
    Sunnydale
    Default Gavinjimny
    Hi I have a 2001 Kia Sportage which has leaking seals on the rear axle. I have removed the 4 nuts that hold a plate on. From a thread I saw the axle should just pull out?? There is a slight movement on the shaft but it still will not release. Is there anything else that could stop it from releasing??
    I need help??
