Steel bash plate vs aluminium bash plate
Results 1 to 20 of 22
    Apr 2014
    Default Steel bash plate vs aluminium bash plate
    Hi fellow offroaders
    Just a question for interest sake. Which is really better, a steel bash plate or aluminium plate?
    I know aluminium is much lighter but by how much really?
    And which one will be more durable? Taking cost into consideration also.
    Would love to hear some input.
    Thanks guys
    Thanked: 307
    Default Re: Steel bash plate vs aluminium bash plate
    The density of Al is roughly one third of steel.
    The strength of Al depends on the grade which is identified by the series, from 1000, 2000, etc to 5000 and 6000. There are higher grades, but not generally for commercial use.
    The lower grades are easy to form and bend nicely, but machine terrible. E.g. drilling a hole often smears the Al instead of cutting it cleanly.
    5000 and 6000 are "machine grade" alloys and finishes well. It also comes in various hardness conditions, e.g. T1, T3, T5.
    In sheet form, these grades do not bend well over short radii and could crack. They can be softened by heating. I once had a bash plate bent from 6mm Al and the hydraulic press got stuck while putting in a 20° bend. It had to be heated with an oxy-acetylene flame along the bend line to get the machine to complete the bend.
    The 6000 series is marine grade and used for manufacturing boats, specifically 6082.
    Although these materials are a third of the weight of steel, they can have up to 80% of the tensile strength.
    For something underneath a car, I have - but would not again - used 3mm Al. 4mm works fine if you just want to protect the plastics, but 5mm is better for more rigidity and you can still bend it. 6 is too thick.
    A good compromise is 3mm stainless steel. It does dent, but it is easily straightened out afterwards. Al workhardens, so is a bastard to panel beat back into shape when it gets thick.
    Another reason for SS is that Al requires a very powerful laser to cut compared to steel. Typically a machine which could cut 10mm steel could only do 3 mm Al. You pay for that power. Water jet cutting is optimal for Al, but the end product is still more expensive than SS.
    Johnie
    Volvo XC60 T5
    180kW/350Nm (1500 - 4800 rpm)
  3. The Following 12 Users Say Thank You to JJJ For This Useful Post:
    Delmas
    Thanked: 939
    Ek kan nie veel sę oor die tegniese deel nie maar in 2018 het Sarel een gebou van Aluminium toe ons Van Zylspas gaan ry het. Wel hy het baie houe gevat en is hier in die werkswinkel. Sy werk gedoen maar beslis te sag. Staal of stainles is beslis beter.
    Elize
    en ry saam met SarelF in
    4x4 Isuzu NPS 300 met kamper
    Kyk gerus by www.blinkgatproducts.com
    Vir enige aluminium produkte,canopy's, campers kontak gerus
    Sarel 0828209413
  5. The Following User Says Thank You to witklipbank For This Useful Post:
    Thanked: 307
    Wynand, the best way to understand which is better or most suitable for the application, is to see and physically feel the stiffness of the material.
    But not only the sheet, the folded product, as the strength is multiplied a number of times when you start folding lips along edges.
    I am running the risk of insulting your intelligence, but a practical example would be a length of 20mm wide flat bar, say 3mm thick. When you pick it up in the middle, the ends bend down under it's own weight.
    Now, take a piece of 20mm equal angle of 2mm thickness and do the same. If it does bend, it will be a lot less.
    If you are really interested - as in planning to fabricate something - you can visit me for a looksee. I have all sorts of material varying from 1.5mm to 6mm - and thicker in plastics - which will demonstrate the principle as well as the properties.
    PM me if you would like to come round.
    Johnie
    Volvo XC60 T5
    krugersdorp
    Thanked: 340
    aluminum - sticky
    steel -slippery
  8. The Following 7 Users Say Thank You to jadranko For This Useful Post:
  9. #6
    Apr 2014
    Quote Originally Posted by JJJ View Post
    Hi
    Thanks for the info. Way too technical for me though lol.
    I have already purchased a Rival 3mm Steel bash plate to be fitted to my Mitsubishi Triton. Will probably arrive here tomorrow.
    I was just wondering if I should have dashed out a bit more money and rather have bought the aluminium plate. I know it's lighter in weight, just don't know by how much. And then of course more expensive.
    What I gather from info of various sources is that that alu plate is not as durable as the steel plate. So the more serious offroaders prefer the steel plate.
    Below is the current condition of my standard bash plate
    Thanks for the input, much appreciated.
  10. #7
    Pretoria, Hartbeesfontein
    Thanked: 782
    With the aluminium you will always wonder - was the bash too hard - while you will have more peace of mind with the steel
    Robert
    '09 VW Caddy Maxi TDi
    '06 Citroen C3 1.4HDi8)
    '97 Isuzu 280 S/C plaasbakkie
  11. The Following User Says Thank You to Tweeling For This Useful Post:
  12. #8
    Apr 2017
    PUMULA
    Thanked: 320
    I went aluminium, mainly due to the fact I live and most of my trips are near the beach. Steel rusts.
    Current off-road vehicles: *** Great family accommodation. See Facebook, Google maps and airbnb. Wild Wind Ranch/Mkulu Kei
    * 1975/8 SHREK Land-Cruiser FJ40 DIESEL P/U, BFG 31x10.5 muds. 2 x 1.6 ton tirfor winchs
    * 1994 Land-Cruiser J70 DIESEL P/U, my truck recovery vehicle. 15000 warn winch. And 3.5ton tirfor winch. Back full of appropriate sized recovery gear. BFG31x10.5 muds
    * 2014 Land-Cruiser LX V8 76 DIESEL STATION WAGON, BFG's 285 all terrain.
    * 1988 HILUX TOYOTA 4x4 D/C.
    SOLD 2020 Jan.
    * 2011 HILUX 4X4 P/U, BFG 31x10.5 all terrain
    * 1999 PAJERO 3.5 V6 Mitsubishi (sorry not a Toyota), BFG 31x10.5 all terrain
    * 2006 FORD ranger 2.5 diesel. 4x4, (what was I thinking, also not a Toyota!) I have a spare 5000 warn winch I might fit.
    * 2011 Isuzu bakkie 4x4
    * FIONA - Rhino Yamaha 660 4x4. Warn winch. Mud tyres
    * 4x4 trailer, 1987, BFG all terrain
    * GSA 1200 BMW ADVENTURE LC 2018, the closest motorbike to a land cruiser
    * A Massey Fergusson 375 tractor. Not BFG's and not a 4x4
  13. The Following User Says Thank You to K-9 For This Useful Post:
  14. #9
    Thanked: 1106
    I make a variety of bash plates for Nissan Patrols. Most of them are made from 5mm steel. I use steel because that makes it easy to weld on bracing and mounting. They are not simply flat plates.
    Some guys still bend them.
    It takes a hell of a sturdy thing to resist the momentum that a 2-3ton vehicle can generate even at relatively slow speeds.
    I am not saying that Aluminium can't do the job, but it needs to be pretty thick if you want to completely eliminate damage to a heavy vehicle driven enthusiastically.
  15. The Following 2 Users Say Thank You to Peter Connan For This Useful Post:
  16. #10
    Oct 2019
    Thanked: 40
    Sorry for going off topic... Peter, whats the price on those bash plates... I need one for my 2001 Patrol
  17. #11
    Jul 2017
    Thanked: 322
    Quote Originally Posted by Wynandsc View Post
    Where did you buy it and what was the price please?
    Jacques Jooste
    2011 Triton 3.2 Auto 4x4
  18. #12
    Apr 2014
    Quote Originally Posted by Tweeling View Post
    I fully agree. Think going with the steel plate was the best decision.
  19. #13
    Apr 2014
    Quote Originally Posted by jooste777 View Post
    Purchased it from a guy that advertised on the Mitsubishi Lovers SA group on facebook. R1,000
  20. The Following User Says Thank You to Wynandsc For This Useful Post:
  21. #14
    Thanked: 373
    I installed a 4mm steel one on my Colt 19 years ago. It is heavy and I must take it off when I drain the oil but after many bashes it is still perfect.
  22. The Following User Says Thank You to PierredW For This Useful Post:
  23. #15
    Thanked: 307
    Yes, preferably, enthusiastically should not be part of the equation.
    But sometimes - in my case anyway - the protection is to keep the plastics intact and keep parts attached to the car. They are not designed as jacking points. My reasoning is that if your protection cannot "give" the attachment points have to dissipate the impact.
    Here is an example of a 3mm Al fuel tank cover on a Freelander 2.
    Admittedly, the car was airborne before it struck something upon re-entry. If the plate was not there, the fuel tank would have been pierced.
    When I got home, I removed the plate and straightened it out in a bench vice. The reason the bracket did not bend, is because it is made from 4.5mm stainless steel.
    Johnie
    Volvo XC60 T5
  24. #16
    Thanked: 155
    Spend extra and get a stofpad bash plate
    Hi
  25. #17
    May 2018
    Thanked: 89
    I got mine from Tuff Stuff and it was the 3mm steel one for R500. Just ask for Andre when you call their landline. It comes in 2 parts like the original in the Tritons but it weighs much more and actually has a extra bracket that bolts onto the cross member. It took about and hour to fit as I dont have a hoist it was a bit of a struggle. They are supplied with everything from bolts to brackets.
  26. The Following User Says Thank You to Yster1979 For This Useful Post:
  27. #18
    Jul 2017
    Thanked: 322
    Quote Originally Posted by Yster1979 View Post
    Awesome.
    Thank you very much
    Jacques Jooste
  28. The Following User Says Thank You to jooste777 For This Useful Post:
  29. #19
    May 2013
    cramond outside Pietermaritzburg
    Thanked: 76
    Quote Originally Posted by Greenhorn View Post
    My Stofpad aluminium plate which is CNC made exactly to fit, can still access oil drain plug has served me well
    Ford Ranger Supercab 3.2 auto 4 x 4
    Blinkgat camper, Stofpad sump and gearbox guard,ironman snorkel,maxxis bighorn,firestone air springs
    Mazda MX5 _ sold after 5 happy years
    Polo 2.0 wife
    Retired
  30. #20
    Thanked: 766
    You guys have covered much of this topic. If I may add my 2 cents.
    If you're concerned about cracking on aluminium, just use a slower bend (bigger radius). The inability to bend the 6mm aluminium is more a factor of the pressbrake not having sufficient tonnage - using a bigger bottom V and "helping" the bend decreases the amount of power you need. Also know that aluminium has a grain that runs in the length of the sheet, so orientate the sheet so that the tighter bends that may want to crack run across the grain.
    For steel I would certainly only consider Domex 700 or Docal 1000 - you'll get away with a lot less weight and the same or better strength.
    I liked the post about the steel being more slippery than aluminium - this is a point I never considered before and is a very valid point. That's certainly put me off aluminium.
  31. The Following 2 Users Say Thank You to Heinz Modricky For This Useful Post:
