Discovery 3 Tyre Size Options - All Terrain - Discovery 3 17" rim size (7J)
Results 1 to 15 of 15
    Cape Town, Grassy Park
    Thanked: 12
    Default Tyre Size Options - All Terrain - Discovery 3 17" rim size (7J)
    Hi
    I have a 2007 Disco 3 2.7TDV6 S. Its due for tyre replacement. I want to keep all terrain tyres.
    The OEM size is 235/70/R17 for this model.There are limited options from my searching the internet.
    These are the OEM sizes:
    Currently I have 265/65/R17 tyres fitted, this is an alternative size according to this chart. Also I read on another forum that the 265/65/R17 which is made for a 7.5J rim is a bit wide for the OEM 7J rim and may cause long term issues with rubbing and prone to side wall damage because of the extra width since the rim is a 7J.
Name:	Alternate sizes R17.PNG
    The link to the website for the above chart: https://tiresize.com/tiresizes/235-65R18.htm
    My current options are, also cost limiting are from General Grabber AT3:
    1. 265/65/R17 - R2200
    2. 255/65/R17 - R3200
    3. 245/65/R17 - R2600
    Which of these size options are better suited and match closer to the OEM 235/70/R17?
    I will appreciate any comments from the forum.
    Apologies for posting in the wrong sections, needs to be moved to Tyre chat section.
    Thanked: 96
    Default Re: Tyre Size Options - All Terrain - Discovery 3 17" rim size (7J)
    errols tyres has two versions of the 70 profile
    Oct 2017
    Kriel
    Thanked: 40
    Quote Originally Posted by SchyffS View Post
    Hi
    Check these alternative sizes...
    MTUNZINI
    Thanked: 577
    I drive 265/65x17 on my D3
    I like it because it gives a bigger wider footprint for this heavy vehicle , and uses a lot for sandy beach work.
    BUT
    I will not put Genl Grabber on a D3 , their sidewalls are very weak, it sees a twig and you have a puncture.
    Go for other make with over 1100 kg weight rating
    Koos Best
    Land Rover Discovery3 TDV6 S.
  5. The Following User Says Thank You to Koos Best For This Useful Post:
    Oct 2017
    Kriel
    Thanked: 40
    Quote Originally Posted by John.oosthuizen95 View Post
    255/65 seems good...
  7. The Following User Says Thank You to John.oosthuizen95 For This Useful Post:
    Cape Town - RSA
    Thanked: 378
    265/65/17 is probably the most widely available tyre size. So that helps too when far from home.
    Go for the LT spec tyre, not a P spec.
    LT- equals light truck
    P - equals passenger.
    Ex - 2005 Cherokee CRD
  9. The Following User Says Thank You to Quiksilver For This Useful Post:
  10. #7
    Thanked: 12
    Hi, Yes they do but they are not all terrain hence my query about the alternative sizes.
    Thanks for sharing.
  11. #8
    Thanked: 12
    Hi
    @Quicksilver and @Koos Best and @John.oosthuizen95
    Here are the links to the tyres with specs:
    https://www.tyres.co.za/products/265...13504205848611
    https://www.tyres.co.za/collections/...abber-at3-114s
    https://www.tyres.co.za/collections/...abber-at3-111h
    Are these LT? Are these the same Grabbers that have weak sidewalls?
    I only do occasional trips, gravel and sand. Not any expedition stuff or rock crawling.
  12. #9
    Oct 2017
    Kriel
    Thanked: 40
    A t 3 has a thicker sidewall than the a t 2 as far as i know...these should be good.... As the sidewalls has 3 layers instead of 2
  13. #10
    Feb 2016
    Paarl
    Thanked: 631
    As a tyre guy, I side with Quicksilver: I would stick to the 265/65R17's. They are widely used and should you have a puncture somewhere, you are more likely to be ably to get one of those. Plus it has a larger footprint. My brother is also running these on his 2008 TDV6 with no issues (granted he doesn't go offroad, except to a winefarm)
    In my opinion the rim being too narrow: If you follow the tab below, even the standard 235's are too narrow for the 7J's. My limited math says a tyre that is a bit wider will leave the sidewall LESS exposed.
    No code has to be inserted here.
    1996 Discovery 1 (SOLD)
    2001 Mercedes C180 (SOLD)
    2012 Nissan Xtrail 2.0 (Weekend Wagon)
    2010 Kia Sedona 2.9Crdi (Written off)
  14. The Following User Says Thank You to Nitebob For This Useful Post:
  15. #11
    Thanked: 12
    Looks like I will be sticking to the 265/65/R17.
    The price is also good.
  16. #12
    Tzaneen
    Thanked: 315
    Cooper has a 245/70-17 At3 LT.Overall the same as 265/65-17 but the sidewalls is more"flat",it fits the rim better.My choice when I was running 17".
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
  17. The Following User Says Thank You to DiscoFrans For This Useful Post:
  18. #13
    Thanked: 12
    Quote Originally Posted by DiscoFrans View Post
    This is also my first choice, but the price is a bit steep for the Coopers. I currently run Coopers, came with the vehicle when I bought it 2 years ago.
  19. #14
    Thanked: 12
    Hi everyone, I have fitted General Grabber AT3 265/65/R17 on my Disco 3 TDV6.
    Iím aware that Land Rover specifies 2 and 2.3 bar, however the fitment centre inflated them to 3 bar.
    What is preferred Tyre pressure for them.
  20. #15
    Tzaneen
    Thanked: 315
    Start with LR suggested pressures.
    2012 RR TDV8 4.4
    2008 FL2 TD4 SE A/T
