Panel Configuration
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 50
    Friemersheim, Southern Cape
    Thanked: 3413
    Default Panel Configuration
    I need some help/advice.
    Have 14 x 80W panels
    Have 150V70A MPPT Charge controller
    How would you configure them for the MPPT?
    I suspect 7 panels in series and then 2 banks might take me past the 150V limitation.
    Robert van den Berg
    Ellisras
    Thanked: 692
    Default Re: Panel Configuration
    Look at the label on the back
    What is the Voc = ?
    Multiply that with the number of panels in series then see if you are over 150V
    Rudolf Ras
    2000 Patrol GU 4.2D(onkey) "old-timer" and wise at 851 000 km
    2014 Patrol GU 3.0CRD "teenager" in puberty at 111 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" at 124 000 km
    Thanked: 682
    With the panels watts, ideally need this 6 values (in the 2 red boxes) ... with them temp coefficients being the straws that can break the camels back, as they say, IF you want to run on the edge.
    Political Correctness
    Thanked: 602
    Normally 36 cell 80W panels have a Voc at about 22 to 23V. Yes 7 will exceed the max on the controller.
    Okahandja, Windhoek
    Thanked: 904
    Also check the charge current in the case of 12V that it dont exceed 70 Amp.
    Johan Kriel
    Thanked: 3413
    3 different makes of panels.
    Voc of one make is 21.6V
    That takes me past 150V.
    Now what other configuration can I do?
    6/4/4 or 5/5/4 or 4/4/4/2 etc?
    Or just loose two and go 6/2?
    Robert van den Berg
    Thanked: 602
    It seems like 4 in series and 4 parallel strings with 1 panel not used. This looks like around 35A which is far below the 70A of the controller.
    Thanked: 3413
    I am ok on that. Currently running 12 panels in 6/2 config on 150V35A MPPT.
    Robert van den Berg
    Thanked: 3413
    So it is ok to do one series set with less panels as other sets?
    Wouldn't 2 five in series sets and one four in series set not be ok as well. 3 parallel strings?
    Robert van den Berg
    Okahandja, Windhoek
    Thanked: 904
    Or 7 banks of 2 each.
    Johan Kriel
    Thanked: 602
    6/4/4 and 5/5/4 a no go as the mppt will not be able to get the different amount of panels at their MPPT point. 4 times 4 and loose 1 or 6/2 and loose 2.
  12. The Following User Says Thank You to ekkekan For This Useful Post:
    Thanked: 602
    Can also work
    Thanked: 3413
    Thanks. That answers my doubt if it will work with unequal series strings.
    Have to save up for two more 80W panels
    Robert van den Berg
  15. #14
    Okahandja, Windhoek
    Thanked: 904
    ignore
    Johan Kriel
  16. #15
    Thanked: 3413
    Nogal...
    Victron MPPT calc site says that 150V35A MPPT will also work on that.
    One never thinks of smaller series strings.
    Robert van den Berg
  17. #16
    Okahandja, Windhoek
    Thanked: 904
    Nogal...
    Haven't check, not sure if you charge say 36 volt if it will work?
    Johan Kriel
  18. #17
    Wartburg
    Thanked: 1768
    It's the voltage which kills - keep the total panel Voc voltage to less than the max rating of the controller.
    But the controller should not blow if your panels are within the voltage spec, but could deliver more current than the controller rating - the controller will only deliver the max rated amps, irrespective of what's available on tap behind it. I suppose it's similar to connecting a 6A battery charger to an Eskom source, which can deliver much more than 6A.
    Mike Lauterbach
  19. #18
    Thanked: 602
    I agree. It is amazing how many posts we see with respect to the max amps. This does not normally fry a controller as the voltage does if the max is exceeded. Also a number of inverters can accept more panels in Watts than what the spec says and it will just limit what can be used and helps outside the 11h to 14h peak sun period.
  20. #19
    Thanked: 682
    Maximum PV open circuit voltage of 150v yes.
    As bad is that is the Maximum PV short circuit current, being 50amps on the 150/70 (or max 30A per MC4 connecter).
    The 150/70, the 70 part is the Rated charge current i.e. the max amps it can charge the batteries at, being 70amps.
    That is a battery bank of wot, +-700ah at 10% charge rate.
    A MPPT can only produce what is drawn on the DC side and that production is completely reliant on what the panels can produce.
    I.e. if the DC side needs 70amps at 12v and the panels can only produce 10w, then 10w is all you are going to get from that MPPT.
    Conversely, if you have 4000 watts of panels installed and the DC side needs 10w, then 10w is all you are going to get from that MPPT.
    A 80w panel, per watt, is quite expensive compared to larger panels ... and required more mounting parts. Just saying.
    14 x 80w panels = 1120w = +-900w on average on a good day all things being equal.
    Bottom line - on ALL MPPT's:
    Don't ever exceed that Maximum PV open circuit voltage.
    Don't ever exceed that Maximum PV short circuit current.
    If one does exceed either, then Phone Life Line. Find their no. in the Yellow Pages.
    Why?
    Because maybe they would care that you let the smoke out, as no-one else would.
  21. The Following User Says Thank You to the_terrible_triplett For This Useful Post:
  22. #20
    Thanked: 3413
    The 80W's I have....so use them
    Mounting, easy. Screw two long purlins onto roof and mount with coach screws and fender washers, dis mos op die plaas stoor se dak
    Robert van den Berg
