A-Frame towing New Suzuki Jimmy all grip 2020
Results 1 to 11 of 11
    Aug 2018
    Vrede
    Default A-Frame towing New Suzuki Jimmy all grip 2020
    Morning all,
    What are the limitations when towing a Jimmy all grip....
    Is it harmful for the Jimmy as I intend flat towing on a A-frame behind camper.
    Any comments will be welcomed.
    Daan
    Thanked: 717
    Default Re: A-Frame towing New Suzuki Jimmy all grip 2020
    Not to be done without removing rear propshaft or modifying rear axle with freewheel hubs. Both transfer case and main gearbox back driven in neutral can be damaged due to lack of lubrication.
    Mike Nieuwoudt
    '89 LR 110 V8
    Aug 2018
    Vrede
    Mike,
    Thanks for reply.
    Please explain as I am not up to speed on the technical issues.
    Daan
    Thanked: 717
    Actually just looked at Gen3 Jimny rear axle and freewheel hubs is near impossible. So rear propshaft removal it is., or like in an older thread https://www.4x4community.co.za/forum...02#post3900402 a dog clutch. You can actually read that whole thread for the info. https://www.4x4community.co.za/forum...wing-the-Jimny
    Mike Nieuwoudt
    '89 LR 110 V8
    Mar 2013
    Thanked: 431
    Get a propshaft nut socket, rechargeable impact drill, correct size ratchet spanner and a torque wrench. You''ll be able to pop that sucker on and off in no-time.
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    LROC member:5881
    -Land Rover Defender 110 Td5
    -BMW F800GS
    Oct 2012
    Thanked: 89
    New Jimny has a Nutral selection on transfercase, and can be flat towed, have a look in your owners manual for exact details.
    Thanked: 717
    Quote Originally Posted by Fearl3SS View Post
    Fearl3SS, could you perhaps copy or refer the relevant pages from the owners manual?
    I have a .pdf copy for the new Gen4 Jimny and do not see any mention of neutral in the transfer case (see owners manual Page 3-16 to 3-22). It also clearly says that "If you need to have your vehicle towed, contact a professional service. A SUZUKI dealer can provide you with detailed towing instructions. " and further on "Do not tow your vehicle with the rear wheels directly on the ground (and the transmission in neutral). If you do, the transmission will be damaged fatally." (Pages 7-6 to 7-7) However, further on Pages 7-7 to 7-8 they say it can be flat towed (all 4 wheels on the ground) with the front hubs unlocked and transmission in neutral IF THE ENGINE IS RUNNING (i.e. you let the engine idle while towing).
    Mike Nieuwoudt
    '89 LR 110 V8
    Jan 2007
    Thanked: 330
    There is no neutral position on the 2018+ Jimny's transfer case.
    Vic
    Helderkruin
    Thanked: 442
    Jimny is so klein kry n kar trailer en sit hom dasr op baie beter.
    Oct 2012
    Thanked: 89
    There you go. you read the owners manual.
    and even highlighted it now for everyone should this question come up again..
    Thanks for explaining this to the rest of us.
    Thus flat towing it is a bad Idea. unless you do some mods.
    Jun 2013
    Parys
    Thanked: 31
    And yet, one sees numerous Jimny's being towed behind motorhomes. Spoke to 43 (!) motor home caravaners during their annual get-together at a caravan site outside Warmbaths end last year. All of them, bar 4, had Jimny's behind - one even a new generation All Grip with (according to them all) no problems or modifications at all?
    When you check the comments on Caravanparks.com, there are many cases of people who have towed in excess of 50 000 kilometres with their Jimny's ....... ? Obviously not all new, but many of the later models??
    Just my 2c.
    1984 SJ 410 ("Ben Laden" ) sold
    2013 Jimny ("Seuntjie") Wizerd rock sliders and underwear, Steering damper
    2011 Suzuki Grand Vitara 2.4 ("Moeder") DASTEK chip (Sold)
    2010 Audi S3 ("Silvo")
    2013 VW Touareg V6 TDi ("Geit")
    2 bicycles ("Blitz" and "Monstrosity")
    2014 SYM 300i GTS Scooter ("Babatjie")
