Brad Harrison to cigarette plug
Results 1 to 7 of 7
    May 2018
    eastrand
    Default Brad Harrison to cigarette plug
    hi.
    I have a 80L NL fridge that comes with a grey Brad Harrison connector...
    Is it possible to make make an extension composed of a BH plug connected to a cigarette plug so that I can power the fridge thru a cigarette socket that is commonly found in the boot/ loadbin of most vehicles
    Tia
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 1484
    Default Re: Brad Harrison to cigarette plug
    Yes.
    No problem. Just expect you may experience bad contact due to heat buildup in the cig plug sometime or another.
    That is why BH and Hella are better options.
    Johan Maree
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    BMW R1200GS & GSA
  3. The Following User Says Thank You to JohanMaree For This Useful Post:
    Nigel
    Thanked: 2328
    That drain on that fridge is very light. There is a 15a fuse on a lighter socket.
    Uniglide
    +27 zero eight 2 four 95 9252
    Thanked: 953
    For peace of mind rather change to a Hella, that said I have run my fridge for days on the cigarette lighter type connection in the back of my vehicle.
    FJC - Just Cruising
    Jul 2013
    Thanked: 314
    Make up one like this, eezi peezi , 4 mm wire will suffice.
    Thanked: 694
    As already said, no problem, just consider that depending on your vehicle the fridge will either be off with the ignition or continue draining the battery. In case of the latter, the fridge has a setting which allows you to set the voltage at which it should stop operating, thereby not entirely draining your battery. That helps so you can still start your car and mainly to protect your battery, I would however not entirely rely on that for starting purposes deep in the bush.
    2010 Bombardier Electrostar 746 kw - Gautrain (Daily Commute)
  8. The Following 2 Users Say Thank You to Kortgat For This Useful Post:
    Dec 2019
    Thanked: 35
    I actually did the reverse of the OP. Works quite well.
    I had an issue with my fridge and battery box in the trailer where the cigarette lighter attachment kept coming out with the vibration of driving.
    I actually cut the existing cable I had and put two Brad Harrison plugs on each end. So now when the fridge is in the trailer it plugs into the battery box using the Brad Harrison plug and when it's in the back of the car I just connect the little remainder/converter (as in post #5) and can use the lighter socked in the back of the vehicle.
    Subsequently also made an extension with two Brad Harrison plugs and it works like a charm in the trailer as it can now run under the fridge slide. The standard cable that came with the fridge was just a tad short.
    2016 Toyota Fortuner 2.8 GD-6 4x4 AT
    2016 Wilderness 200 (Karet) Trailer
