Digitale battery tester
Results 1 to 10 of 10
    Feb 2014
    Thanked: 781
    Default Digitale battery tester
    My Discovery seemed to crank just that midget slower this morning and this got me thinking: is it worth investing in something like this:
    https://youtu.be/lC2tUolCZwI
    Zapiture,
    Discovery 4 Facelift 2015
    Defender D90 2.8 2003
    Conqueror Commander 2014
    Friemersheim, Southern Cape
    Thanked: 3381
    Default Re: Digitale battery tester
    Robert van den Berg
    Feb 2014
    Thanked: 781
    800 odd
    Zapiture,
  4. The Following User Says Thank You to Zapiture For This Useful Post:
    Apr 2016
    Thanked: 65
    Don't you think cranking your engine to start it is a good enough test for your battery?
  6. The Following User Says Thank You to Richard Mackay For This Useful Post:
    Jul 2016
    Thanked: 520
    If you get any strange fault codes popping up you know itís time for a new battery. D4s donít like tired batteries
    Sep 2008
    Vanderbijlpark
    Thanked: 185
    Type of tool that only makes sense if you're in the car battery business. (Frequency of use)
    ZS6VL
    Thanked: 186
    Not digital but cheap enough for once in a while testing. All the battery shops I visited to have car battery tested use this type.
    https://www.adendorff.co.za/product/...attery-tester/
    "The whole problem with the world is that fools and fanatics are always so certain of themselves, but wiser people so full of doubts" : Bertrand Russell
    2014 Nissan Navara 2.5 4x2
    1995 Nissan Sani 3.0 V6 4x4
    Thanked: 587
    I voltmeter permanently on at R50 that indicates the cranking volts IS a good tester. As long as the reading is above about 9.5V the battery is sound. Any deviation from the normal reading would tell you the battery is getting weaker.
    The very cold mornings I found my diesel Freelander started dipping below 10V but still good for about 18months I would guess.
    Dec 2007
    nelspruit
    Thanked: 109
    99% of batteries can be opened. The lids are under the sticker. The electrolyte can be tested with a hydrometer which shows good bad and ugly or calibrated with figures. A bad cell with a short will show up visually with bubbles rising when you switch on your lights on high or start
    Thanked: 694
    Quote Originally Posted by staalwol View Post
    I have that one. Works great.
    2010 Bombardier Electrostar 746 kw - Gautrain (Daily Commute)
