Inverters - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 45 of 45
Thread: Inverters
  1. #41
    Aug 2019
    Thanked: 135
    Default Re: Inverters
    Quote Originally Posted by Wetkit View Post
    Please help me understand the Sunsync unit.
    I do not see that you can connect a power meter to it, so how can it do Zero consumption?
    Only advantage is that you can parallel these units, so basically you have to put 100% of your load on backup?
    https://mybroadband.co.za/forum/thre...#post-25864236
    From about pg80
  2. #42
    Thanked: 1341
    It does come with an elec meter. Not only can you have zero feedback (actually 20W or so, but this can be changed / set as per your meter to prevent the meter from logging a fault) but you can also limit the overall production of the unit....
  3. #43
    Thanked: 591
    Quote Originally Posted by Wedwo View Post
    Hi all.
    I have just installed a 3KVA 24 volt inverter. Everything works perfectly but the fan has remained on constantly for the last 48 hours. This cant be right can it.
    Gavin
    Gavin indicate what make of inverter is it?
  4. #44
    Thanked: 97
    ekkekan
    Hi. Please see picture attached
    Attached Files Attached Files
    2015 Discovery 4 30 SDV6 SE
    2007 Defender 90 Puma 2.4
    Metalian Off Road Trailer
    Previous
    2010 Discovery 4 30 TDV6 SE
    Discovery 3 V6 S
    Discovery 2 TD5
    Defender 90 TDI
    Defender 110 V8 Hard Top
    Jurgens Xplorer
  5. #45
    Thanked: 591
    ekkekan
    It seems like my phone can't open these files.
