200Ah Gel batterye: Hoe lank kan hulle hou?
Results 1 to 12 of 12
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 1367
    Default 200Ah Gel batterye: Hoe lank kan hulle hou?
    Ek het 4x 200Ah gel battery in serie om die 6kW UPS te voer.
    My vraag is:
    Hoe lank behoort hierdie stel batterye te hou teen sowat 7A (AC) stroom?
    Ek is nie slim genoeg nie en hier is baie slimmer ouens...
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    BMW R1200GS & GSA
    Thanked: 516
    Default Re: 200Ah Gel batterye: Hoe lank kan hulle hou?
    3 Ure tot by 12V
    5 ure tot by 10.8V
    Okahandja, Windhoek
    Thanked: 871
    My vraag is:
    7 amp AC is ongveer 220/48 x 7 = 32 amp dc as dit 48 volt is.
    Yes +- 5hours.
    Johan Kriel
    Thanked: 516
    Hier is die ontlaai kurwe volgens die data sheet wat jy aangeheg het, ek het kolle gemaak op die 12V en 10.8V spanning na discharge.
    Die 0.17C lyn is teen 34A DC (ongeveer 7A AC)
    Thanked: 537
    3 Ure tot by 12V
    5 ure tot by 10.8V
    Post verwyder want ek het nie gesien dis 7A AC nie.
    Paradise Beach
    Thanked: 47
    3 Ure tot by 12V
    5 ure tot by 10.8V
    This is correct
    Jun 2008
    Thanked: 1367
    Quote Originally Posted by fredwb View Post
    This is correct
    Dankie.
    Dan moet ek nou begin huil. Desember gekoop en tans hou hulle met moeite 1.5h.
    Isuzu 300 d-tec
    BMW R1200GS & GSA
    Paradise Beach
    Thanked: 47
    Dankie.
    Check that your charging voltage and cycle is as per the suppliers specifications to ensure the battery gets fully charged before the next load cycle.
    Also check the individual battery voltages when under load. You may only have one faulty battery that is collapsing under load and drawing the system down.
    Thanked: 537
    Dankie.
    Dalk wil jy die SMF100/101 van Raylite wat deur Battery Centre verkoop word probeer. Hulle is ongelukkig net 100Ah. Ek is seker hulle gaan beter hou.
    Dec 2019
    Thanked: 40
    My vraag is:
    Hi Johan. Wat se maak UPS is dit? Ietsie wat jy kan in bele vir daai size GEL batterye is HA02 ballancer. https://www.google.com/search?q=ha02...w=1920&bih=937 Daar dop gereeld van hulle op Powerforum.co.za . Victron maak ook. Dit help met daai size batterye om bietjie amps rond te skywe tussen die batterye en verlang die lewe van daai size batterye. Die HA02 kan so 10amps deur gee. Ek het destyds dit gebruik op my 190amp selle bank.
    Nog ietsie wat jy kan kyk ook voor is Victron BMV. Jy tel hulle 2de hands ook op. Jy kry iets naby aan dit ook van oorsee af, dan kan jy presies sien hoeveel krag jy uit hulle gebruik en hoeveel jy in laai. Die regte laai volts is ook belangrik. Vir die geld wat jy uit gehaal het vir daai batterye moet jy so ietsie by sit om hulle net n bieitjie langer te laat hou.
    Thanked: 537
    Dankie.
    Johan hierdie is die afmetings. WxDxH soos aangetoon in die laaste 3 komme. Die 1e kolom is die kapasiteit.
    Jun 2008
    Thanked: 1367
    Quote Originally Posted by Gerlach View Post
    Hi Johan. Wat se maak UPS is dit? Die regte laai volts is ook belangrik.
    Die UPS is "Current Automation". Het hom al tien jaar en altyd goeie diens gelewer. Hy laai tot by 57.6V.
    Die sonpanele laai gedurende 9vm-3nm 54.4V wanneer Eskom afgeskakel is.
    Ek glo my laaivermoŽ is binne perke.
    Isuzu 300 d-tec
    BMW R1200GS & GSA
