I thought this was a great project
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 52
    Dec 2014
    Kokstad
    Thanked: 39
    Default I thought this was a great project
    1962 SWB, needs slight work, so i thoughtClick image for larger version.
  2. The Following 3 Users Say Thank You to zuluboy For This Useful Post:
    Thanked: 243
    Default Re: I thought this was a great project
    daai shock bush lyk actualy nog mooi!
    D90
    D130
  4. The Following User Says Thank You to D-tox For This Useful Post:
  5. #3
    Thanked: 388
    Good luck. Go for it!!!
    Thanked: 448
    Drop arms on the top of the swivel ball ??
    Thought only the Series 1 did that
    Dec 2014
    Kokstad
    Thanked: 39
ID:	579568Click image for larger version.
ID:	579569Strip, clean, sand blast. New Bearings, seals brakes and sommer everything.
  8. The Following 2 Users Say Thank You to zuluboy For This Useful Post:
  9. #6
    Dec 2014
    Kokstad
    Thanked: 39
    Engine was not in as good shape as i thought.
    New seals, water pump, alternator, fuel pump, distributor, pistons and bearings. Head re-done. Much better now.
ID:	579570Click image for larger version.
ID:	579571Click image for larger version.
  10. The Following 4 Users Say Thank You to zuluboy For This Useful Post:
  11. #7
    Dec 2014
    Kokstad
    Thanked: 39
    Stripped and rebuild clusterClick image for larger version.
ID:	579574Click image for larger version.
  12. The Following 5 Users Say Thank You to zuluboy For This Useful Post:
  13. #8
    Dec 2014
    Kokstad
    Thanked: 39
ID:	57988058yr old panel, came out very nice
  14. The Following 7 Users Say Thank You to zuluboy For This Useful Post:
  15. #9
    Dec 2014
    Kokstad
    Thanked: 39
ID:	579881New wiring front to back
  16. The Following 3 Users Say Thank You to zuluboy For This Useful Post:
  17. #10
    Dec 2014
    Kokstad
    Thanked: 39
ID:	579882Click image for larger version.
ID:	579883Click image for larger version.
    Bare metal re-build, new shackle bushes, master cylinders seals and all.
  18. The Following User Says Thank You to zuluboy For This Useful Post:
  19. #11
    Dec 2014
    Kokstad
    Thanked: 39
ID:	579885Used Dinitrol on all exposed surfaces, even sprayed with a hose inside the chassis tubing.
    Converts rust to a stable organic compound, and is fully paintable. Avail online order from JHB supplier.
  20. The Following User Says Thank You to zuluboy For This Useful Post:
  21. #12
    Thanked: 542
    I saw the original post and thought you were joking! Respect.
    Tyrannosaurus R5 and a second hand British Tata
    Quote Originally Posted by 2beFree View Post
    Jan your signature says it all
  22. The Following 6 Users Say Thank You to JanB For This Useful Post:
  23. #13
    Thanked: 388
    It seems you have already come looong way since the first photo.
    You have losts of patience. Respect.
  24. The Following User Says Thank You to Spiceman For This Useful Post:
  25. #14
    Oct 2007
    Midvaal
    Thanked: 367
    Really impressive. Well done. Will be following this thread.
    Charl
    Pajero 4 LWB
    The most important thing to do if you find yourself in a hole is to stop digging (Warren Buffet)
    We have become a society that creates, rewards and protects thieves, parasitic, ambitious and greedy thieves with an insatiable lust for money, and an aversion to honest work and creativity. (Anthony Turton)
  26. The Following User Says Thank You to Slow Ranger For This Useful Post:
  27. #15
    Dec 2014
    Kokstad
    Thanked: 39
ID:	580035Someone had already galv the frame, so i cleaned it, sprayed it with "CONVERUST RC900", it turned a little purple, but looked authentic and old, so i left it like that. New safety glass window, the chap at GLASFIT, would not believe that this was a windscreen for a motor-vehicle, not an essential service during lockdown, so i had to show him pics of old Land Rovers, before he would do the job.
  28. The Following User Says Thank You to zuluboy For This Useful Post:
  29. #16
    Dec 2014
    Kokstad
    Thanked: 39
    Bought a Sand blasting kit from Adendorff PMB, works like a charmClick image for larger version.
    Decided to install Defender door mirrors, instead of the small chrome jobbies.
  30. The Following User Says Thank You to zuluboy For This Useful Post:
  31. #17
    Dec 2014
    Kokstad
    Thanked: 39
    Replaced the Series 2 gearbox with Series 3 full syncro box, they look the same but have small differences, for example, the clutch slaves are diff. Click image for larger version.
    Had to wait till stage 3 lockdown to get the right part. Wasted a lot of time, due to not having a clue of the differences in the various Landi models.
    But i'm better now.
  32. The Following 2 Users Say Thank You to zuluboy For This Useful Post:
  33. #18
    Dec 2014
    Kokstad
    Thanked: 39
    Un-believable, my original rear diff was off-set to the left (standing behind the vehicle), the SWB prop, would never reach and have an acute angle. So i had to source another, folks in KZN don't know where the left off-set diff comes from. As can be seen, the transfer case and front diff is to the right ??
    Diffs are upside down in the pic, but you get my drift. Had to re-position the leaf-spring mounts inwards to suit. One step forward, another back.
ID:	580083Here is the original
  34. #19
    Thanked: 14187
    Quote Originally Posted by zuluboy View Post
    So they flipped the axle and reinstalled the center portion?
    I really wonder why that was done?
  35. #20
    Thanked: 228
    Quote Originally Posted by JanB View Post
    It was my thoughts exactly!
    Well done zuluboy, for someone that "doesn't know the different Landi models" you have done a remarkable job! It's obviously not your first rodeo.
    Following with interest.
    2009 VW Touareg 3l V6 TDi
    2006 Isuzu DMax 300Tdi DC 4x4 (sold)
