cracked tierod attach point
Results 1 to 14 of 14
    Fishhoek
    Thanked: 127
    Default cracked tierod attach point
    What would cause a crack in the attach point of a tierod on the steering knuckle. A while back work was done on the steering rack that had to be removed and re fitted.
    2009 WK 5.7, OME 2" suspension, free flow no cats with harmonic chamber
    Ruimsig
    Thanked: 11740
    Default Re: cracked tierod attach point
    Are those not hammer impact marks. Exuberent whacking could do it as they can be boogers to get out.
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
    Ruimsig
    Thanked: 11740
    It could also be an expansion pressure fracture
    Hummer H3 V8
    W.A.P Objectivist
    Out of Town
    Thanked: 717
    Thats just plain rubbish quality and cheap manufacture. I don't recall ever witnessing a failure like that in my life. I have beaten those for ages to release a ball joint that has been in place for years. Left both sides, you could access, flattened out, but the cars run to this day with that arm in place.
    Next time you install a ball joint like that, give it a bit of grease on the shaft so it pops out with minimal effort next time.
  5. The Following User Says Thank You to bfreesani For This Useful Post:
    Robertson/ Larissa, Greece
    Thanked: 3377
    Is that aluminium? It got seriously wacked!
    Thanked: 261
    Wrong size hammer used. Hammer was too small.
    Robbie
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Fishhoek
    Thanked: 127
    Thanks for inputs. The knuckle is still OEM from Jeep. Also though was caused by hammer blows, but was also told, over tightening causes the taper to put too much stress resulting in crack.
    Also for sure ball joint removal tool not used.
    Tried TIG welding, but Aluminium type material would not hold the weld. So waiting for "new" part.
    Mar 2014
    Richards Bay
    Thanked: 13
    What Jeep is this on?
    Thanked: 938
    The abuse with the hammer probably left damage that was a stress riser for the crack to start. Over tightening on the refit accelerated the stress crack. People should realise that there are specified torque values for the different nuts and bolts on the vehicle. A big hammer isn't the correct tool for this type of job.....
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
    Fishhoek
    Thanked: 127
    Quote Originally Posted by GollyJeep View Post
    See my signature
    Mar 2014
    Richards Bay
    Thanked: 13
    Quote Originally Posted by skala View Post
    See my signature
    I see,I thought it was a newer Jeep where aluminum suspension components are more common.
    Whilst aluminum alloys are pretty strong they don’t have the same ductility as steel or ductile iron (which is commonly used by many manufacturers on suspension components these days).
    Thanked: 2214
    Combination of circumstances / events, the pin is tapered and that will put a strain on the ring but it should be able to withstand it. Beating it with a hammer is par for the course even with a ball joint removal tool. Best way is to take a big hammer and wallop it do not play, if done right one shot usually does the trick.
    This is where the probable real cause of the failure came in, Aluminium is another pest of a metal, hit it with a hammer and it gets harder to the point that it will get brittle. Panel beaters back in the day when Land rovers had dents repaired and not panels replaced used to beat the panel and every so often take their blow torch to heat the area to anneal it.
    I think this joint was hit with a too small hammer and needing a few blows to get it to release and this hardened the ring just enough to split.
    To anneal alu is easy, take an ordinary bar of soap and draw a line on the area that needs to be softened and heat that area untill the soap line turns brown.
    Henk
    Follow us on Facebook
  14. The Following User Says Thank You to hbannink For This Useful Post:
  15. #13
    cape town
    Thanked: 162
    was taught by my Dad to use two hammers: one hammering and with a four pound held opposite and against the tie rod to absorb the shock.
    one or two good blows is all it takes.
  16. The Following User Says Thank You to RussellF For This Useful Post:
  17. #14
    Fishhoek
    Thanked: 127
    Thanks for all the comments and advice. Replaced with good used part from USA Spares in Pretoria.
