Help need to immobilise series 3
Results 1 to 19 of 19
    Nov 2016
    Thanked: 138
    Default Help need to immobilise series 3
    Hey guys I need some help, somebody's trying to steal my series 3 petrol from my garage at our beach House.
    There is a steering lock chain but they tried to bust the lock, can anyone suggest any other way to completely immobilise the vehicle.
    She is my pride and joy.
    I was thinking of pulling the points?
    Any suggestions?
    Jade
    Wilderness
    Thanked: 1223
    Default Re: Help need to immobilise series 3
    Remove the + wire from the coil. Tape up and hide. Pull the small wire from the solenoid on the starter. If the carburettor has a cutout solenoid valve. Remove that wire as well.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  3. The Following User Says Thank You to Pieterk For This Useful Post:
    Nov 2016
    Thanked: 138
    Thanks very much Pieter, will grab the manual and pull that wire. Royally pissed off by the break in, they never touched a thing in the garage and only tried to take the Landy. Even left the tools they used to try break the lock.
    Garsfontein
    Thanked: 568
    What I did back in the day when I had to use sidewalk parking at friends place was remove the cable between the solenoid and distributor cap, stopped a few attempts at stealing my Uno.
  6. The Following User Says Thank You to supersunbird For This Useful Post:
    Thanked: 2968
    Just remove the rotor, and put the distributor cap back in place. Will confound any thief who doesn't understand old engines, and the time spent cranking it with no start should be enough to send them into a panic. Also highly unlikely they will have a spare rotor lying around.
    Tony Weaver
    1991 Land Rover 110 Hi-Line S/W 3.5l V8 carburettor
    Cooper Discoverer STT tyres, four sleeper Echo rooftop tent
    2012 Mitsubishi Outlander.
    Previously Land Rover 1968 SII, 1969 SIIA, 1973 SIII, 1983 Toyota HiLux 2litre, 2006 Land Rover Freelander TD4 HSE.
  8. The Following 3 Users Say Thank You to Tony Weaver For This Useful Post:
  9. #6
    Nigel
    Thanked: 2311
    Couple of things.
    You could put a solid break on the positive to the coil. Be it via a switch or a latching relay.
    Alternative is a electrical non return valve to the brakes. So when the power is off and you press the brake, the brakes lock up.
    Else, switch to low range and lock it there.
    Uniglide
    +27 zero eight 2 four 95 9252
  10. The Following User Says Thank You to Henris For This Useful Post:
  11. #7
    Jun 2020
    Damascus
    Thanked: 23
    If you're not going to be using it for a while. Place on jacks/trestles/bricks. Remove the wheels.
  12. The Following 2 Users Say Thank You to DifflockDonkey For This Useful Post:
  13. #8
    Nov 2016
    Thanked: 138
    Thanks very much everyone.
    All great ideas - I am trying to find the least technical one since my BIL is there and will be doing this for me and doesn't really know a lot about cars. I would remove the bean can if I was there, but I think jack stands and wheels might be the best answer.
    I am going to look for a more permanent solution - there is a solenoid cut off, but its in an obvious place and a few turns of the dial they should get it to connect.
    Its bloody amazing, there are winches lying around, small outboards, lots of tools, boat gear, SUP's, and they didnt touch anything else but the landy, they even broke into the house and left the TV.
  14. #9
    Jul 2013
    Thanked: 310
    Midnight spares back orders...
  15. #10
    Nov 2016
    Thanked: 138
    Couple of things.
    The idea of locking it in low first is actually great and hilarious. Slowest get away ever.
  16. #11
    Nov 2011
    Langebaanweg
    Thanked: 1191
    In the UK they push it onto a rollerback and drive away.
    You need to make it so that they can't push it out of the garage.
    Removing the wheels isn't such a bad idea.
  17. The Following User Says Thank You to jfh For This Useful Post:
  18. #12
    Mar 2007
    Harties Boet
    Thanked: 851
    Agreed. They’re not going to try start it. It’s going to be pushed out and away or towed.
    take the wheels off and put on stands.
    and put the wheels somewhere else, not in the same garage.
    2004 Nissan Patrol 4.8
    1999 Nissan Patrol 4.2D
  19. The Following User Says Thank You to Graham For This Useful Post:
  20. #13
    Nigel
    Thanked: 2311
    Put a non return valve with bypass on the brake line.
    Step on the brake once and all locks up.
    Uniglide
  21. The Following User Says Thank You to Henris For This Useful Post:
  22. #14
    Apr 2018
    Fraserburg
    Thanked: 937
    That steering lock chain with this padlock. It makes things so much harder. You can't get into that padlock nor hold it to hammer or saw it:
  23. The Following User Says Thank You to Olyfboer For This Useful Post:
  24. #15
    Nov 2016
    Thanked: 138
    Thanks very much! I am getting one to replace it, but I also had the rotor in the distributor pulled out, so it's not going anywhere under her own power now.
    I am looking at a long term solution like a gear box lock etc.
  25. The Following User Says Thank You to JadeDsantos For This Useful Post:
  26. #16
    Nov 2011
    Langebaanweg
    Thanked: 1191
    Quote Originally Posted by JadeDsantos View Post
    Remember if box is locked in let's say 1st, if you drop Txbox in neutral you can push it away.
    So you will need 2.
  27. #17
    Thanked: 14235
    Please don't, it is illegal and for a reason. Rather install a huge pedal box.
  28. #18
    Nigel
    Thanked: 2311
    I would use a std gas change over valve. One line has the valve, the other straight through. No danger then.
    No point in being "legal" with no car.
    Uniglide
  29. #19
    Nov 2016
    Thanked: 138
    The vehicle is in a little town with one road in and one road out, 70kms of dirt. I dont think that anyone will be coming to flatbed it out, and it will definitely be seen being towed under great suspicion. Its a little place called Infanta opposite Witsands at the mouth of the breede river.
    There have been a few instances of theft now and the very tight knit community is up in arms about it, everyone is on high alert - the culprit has been spotted and chased, but lost in the thick coastal vegetation at the back edge of the town.
    The police has been very good apparently, and even suspect they know who it is.
    I personally think he was looking for a getaway vehicle to get down the dirt road to Swellendam easily without being spotted walking the road, since no TV's or valuble items were stolen. Its not easy to lug loot 70kms on that road without a car without being seen.
    Anyway, the garage has a new lock, burglar bars, and the vehicle is short a vital ignition component, and a new lock, plus a gear lock coming soon.
    I would be walking that bush every day if I was down there.
    Thanks very much again gents!
  30. The Following User Says Thank You to JadeDsantos For This Useful Post:
