One Ten V8 Starting Problem
Results 1 to 15 of 15
    Thanked: 108
    Default One Ten V8 Starting Problem
    Good day. I have an early One Ten V8 with carbs that is giving issues to start after driving it for a while. Initial starting is not a problem even if I go for days without driving it. But after driving around and cutting off engine, I will need to give it 20-30 minutes for it to restart. What could be the problem? Battery is old (March 2016), but wouldn’t the problem show at first start?
    Thanked: 637
    Default Re: One Ten V8 Starting Problem
    Which ignition (electronic or points), which carbs (SU or Stromberg)?
    '89 LR 110 V8
    Thanked: 108
    It has SU carbs and points.
    Thanked: 288
    Sounds if the carbs are peculating after you switched off . Check the float levels on the carbs maybe needle and seat issues not sealing properly too .
  5. The Following User Says Thank You to smarty For This Useful Post:
    Zululand
    Thanked: 99
    I’m not sure the carbs are percolating, or it wouldn’t start easily after a long stop. Sounds heat related, somewhere.
    Thanked: 288
    Quote Originally Posted by Andrew D View Post
    Hi Andrew from my understanding is tha
    t when you switch the engine off there is a substantial heat built up under the bonnet .This causes the fuel in the carb to change into a vapor form that makes the mixture too rich should you start after a short stop . However when standing for a longer period the vapor evaporates and the engine will start . Just my 2 C worth im sure there are more technical people that can explain it better .
  8. The Following 3 Users Say Thank You to smarty For This Useful Post:
    Jan 2015
    Thanked: 147
    I would say valve clearances. When last did you check them?
    2014 LC76 4.5 V8
  10. The Following User Says Thank You to ghouwens For This Useful Post:
  11. #8
    Thanked: 99
    Quote Originally Posted by Twist View Post
    Maybe the fuel cap breather blocked creating a vacuum?
    Regards,
    Suid-Wes
    2006 Defender 110 Td5
  12. The Following User Says Thank You to Suid-Wes For This Useful Post:
  13. #9
    Thanked: 108
    Thanks gents. From the suggestions being thrown around it sounds like it’s not something as simple and straight forward as I was hoping. This is way above my abilities, so will check it in.
  14. #10
    Thanked: 1163
    Maybe it is the battery after all? Battery on its way out, heats up while driving and then first have to cool down to produce enough power to start.
    Or some other electrical connection heating up and losing contact.
    This can keep you busy for a while ...
    Defender 2.8i
  15. #11
    Nov 2011
    Langebaanweg
    Thanked: 1191
    Quote Originally Posted by smarty View Post
    100% correct. Mine did the same. I owned her for 12/13 years.
    It's all about the heat. In the old manuals LR shows a vapour trap on the firewall in the engine compartment.
    I did want to build a heat shield to stop this but never got to it.
  16. #12
    Thanked: 14254
    Precisely why I wanted to convert to EFI.
  17. #13
    Thanked: 637
    If it still have points the fuel pump is most probably at the filter next to the chassis below the drivers feet. That pump sometimes caused suction issues, in that it could not get the fuel sucked from the tank without forming vapour locks as there was heat spill-over from exhaust, engine and gearbox after a hot run. One of the reasons the later fuel pump was moved to inside the tank where vapour locks could not form. But first check where your fuel pump is located :-)
    '89 LR 110 V8
  18. The Following User Says Thank You to Mike N For This Useful Post:
  19. #14
    Dec 2014
    Thanked: 1920
    My money is on vapour lock in the pipes to the carbs. If they run past/near the exhausts they will boil off internally and then the next start has to fill the pipes with fuel before the carbs get fed.
    A small bore return line from the carbs to the tank will resolve that, if the pump is up to the task, or wait after turning on the key for the regular pump to fill the line again.
    FWIW, my P6 with the 3.5 is notorious for heat soak starting issues and sometime even affecting running if it's hot enough outside.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  20. The Following User Says Thank You to JohnnoK For This Useful Post:
  21. #15
    Napier
    Thanked: 41
    If it is a twin carb su hif44 then it should already have the return pipe. standing at the radiator and looking towaeds the engine the right hand carb gets fed first and then the return is on the left hand carb.
    Have you tied changing the rotor arm - I had a similar problem which was a fault with the Rotor arm - Do NOT use interpart one - get proper Lucas one.
    Good luck.
    Babushka - 3.5 V8 Defender Highline
    SWAMBO - 1.6 Nissan Livina X-Gear
  22. The Following User Says Thank You to DSouter For This Useful Post:
