What adhesive?
Results 1 to 12 of 12
Thread: What adhesive?
    Harties
    Thanked: 530
    Default What adhesive?
    I have to attach lengths of rubber strip (8mm thick, 50mm wide) to one side of hot dipped galvanized angle iron rails.
    What adhesive is best for this application?
    Initially I thought of using contact adhesive but it seems that contact adhesive does not work that well adhering to hot dipped galvanized surfaces.
    Advice and comments please.
    If you make a noise or need music in the bush or on the beach, youíre missing the point.
    May 2018
    Paarl
    Thanked: 77
    Default Re: What adhesive?
    Get " Sticks like ####" - pretty sure it will work if it sticks porcelain to cement and polycarbonate to steel.
    Debbin
    Thanked: 58
    Make sure you clean the galv properly.
    something like plascons galvanized iron cleaner.
    then try a sikaflex or den braven polyflex
    Harties
    Thanked: 530
    Potchefstroom
    Thanked: 218
    Just check sticks like s... and other adhesives, some needs one side to be porious to stick!
    Lonehill, JHB
    Thanked: 993
    2014 Pajero 3.2DiD SWB
    Sep 2016
    Thanked: 4006
    Feb 2017
    St Francis Bay
    Thanked: 56
    Could 3M VHB tape could work?
    Harties
    Thanked: 530
    Thanks for the replies
    Quote Originally Posted by mike morrison View Post
    Thanks Mike.
    That looks like the proper solution.
    Iíll find out about compatibility with HDG but it seems as if it should be OK.
    Feb 2017
    St Francis Bay
    Thanked: 56
    Quote Originally Posted by PRA View Post
    Thanks Mike.
    Also look at using a primer, apparently makes a huge difference to the adhesion
    Hillcrest, Malaysia
    Thanked: 6511
    We used to wash HDG with pool acid - it removes any waxes and reacts with the zinc, then rinse, dry, prime with etch primer before painting. I would do the same before relying on any adhesive. Except glue instead of paint.
    Gloves, good ventilation ....blah blah blah.
    Is the rubber there as a simple barrier or are there shear forces which may try to strip it off. The thing with rubber is that the glue should contain a solvent which softens and penetrates the surface, else you are farting against thunder. That rules out all or most of the cellulose/acrylic based compounds, including, most probably, Sticks Like Sh!eeT
    I think your best bet is going to be a professional Cyanoacrylate. Not you Supermarket 9g tube of SuperGlue knockoffs. SIKA are also bound to have a suitable product. What works for me is phoning the glue companies Customer Service Help Line.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
    Strand
    Thanked: 48
    Cold vulcanizing adhesive - available at most suppliers of rubber products.
