Discovery 1 300tdi AC guide pulley problem
Results 1 to 5 of 5
    Aug 2008
    Default 300tdi AC guide pulley problem
    Hi,
    Please could I get some guidance with my small problem
    Is the AC guide pulley a separate unit, should it just pull off to be replaced? Or is it part of the cover.
    I guess that this may have been covered before, but I can not get mine loose (already removed the center bolt on it) and before I damage anything I thought it best to ask.
    Also I discovered that the previous Indy stripped 2 of the 3 bolts on replacing the AC belt tensioner. Besides filing them down to a size 9 is there perhaps any other suggestion that I could try please?
    cheers
    Mike
    New Germany
    Thanked: 515
    Default Re: 300tdi AC guide pulley problem
    The guide pully Has the center bolt remove it and it comes off then you can change the bearing, as for the 3 bolts that have stripped in casing get it time-cert and will be good again
    2005 Defender TD5
    Aug 2008
    Hi Clive,
    Thanks for the reply.
    I have removed the centre bolt, but it still seems stuck when trying to remove by hand. I have applied gentle leverage pressure but no luck.
    Perhaps i should exert more pressure to remove with a gentle tap or 2 from a hammer ?
    Modjadjiskloof
    Thanked: 147
    I also can't see what is still holding the guide pulley in. There is only the centre bolt. Something must be sticking a bit...
    If the tensioner pulley bolts are rounded, it's probably also because they have seized into the cover. I would go the route of trying one last time with a good 6-point socket then file to a 9 as you suggest. Do be careful... many people round these bolt heads because of using those multi-point sockets, and using a 6-point socket helps. But if they are genuinely, tightly, solidly seized, the bolt heads could break off. Then you will probably have to remove the timing cover and operate on it.
    Aug 2008
    Thank you,
    Will give it a bash today, first the pulley then the surgery on the bolt heads 🤔
