Results 1 to 12 of 12
    Mar 2018
    Ellisras
    Thanked: 71
    Default Does it overheat: Compressor 180 Litre Per Minute in Ammo Box
    Hi everyone, I recently became the owner of a 2010 Fortuner D4D 4x4 and would like to purchase a good air compressor for the vehicle.
    I saw this: https://4x4direct.co.za/tyre-care/92...110661683.html
    It is built into an ammo box and it looks quite decent. Anyone with experience with it as it seems like it might overheat inside the enclosure?
    Otherwise, any other air compressor recommendations?
    Thanks !
    May 2017
    Thanked: 243
    Default Re: Does it overheat: Compressor 180 Litre Per Minute in Ammo Box
    FIL has one, pumped up a few tyres in succession without any overheating. It's a good solid pump. Just check the pipe fittings after use, you can almost weld with them, they get very hot.
    2015 Pajero Sport Shogun
    2012 Kia Cerato Hatch
  3. The Following 2 Users Say Thank You to Hendel1986 For This Useful Post:
    Tshwanetoria
    Thanked: 1462
    Each time I do business with 4x4 Direct, I get more respect for their "branded" products (and the service I get at Montana branch)
    Recently bought a set of spotlights - real value for money.
  5. The Following 3 Users Say Thank You to hatjohan For This Useful Post:
    Mar 2018
    Ellisras
    Thanked: 71
    Quote Originally Posted by Hendel1986 View Post
    Thanks for the review, it helps
    Mar 2018
    Ellisras
    Thanked: 71
    So far only heard good things of them
    Nov 2012
    Thanked: 36
    I use that pump for 33's.
    I connect it to an Indeflate and pump up two tyres at once to around 2.4 Bar no problem.
    Wanted an ARB twin, was told to try this first. I cant complain.
  9. The Following User Says Thank You to Mypro-D For This Useful Post:
  10. #7
    Gaborone, Botswana
    Thanked: 1864
    Anyone else with experience with this Air Bullet pump ?
    Kobus
  11. #8
    Pretoria/ Hoedspruit
    Thanked: 320
    I have one. It works like a charm. No overheating issues.
    2018 Ranger DC 2.2 XLS Auto 4x4
    Bushtech Canopy and goodies
    Canon 5DMkIV with L-goodies.
  12. The Following 2 Users Say Thank You to Mtber For This Useful Post:
  13. #9
    Nov 2012
    Thanked: 36
    I have often pumped up 8x tyres from around 0.8.
    So far, no problems.
    Has not cut out on me yet.
  14. The Following User Says Thank You to Mypro-D For This Useful Post:
  15. #10
    Mar 2018
    Ellisras
    Thanked: 71
    I eventually bought one and so far no complaints. Very good build quality and the the pipe which comes with is a proper compressor rubber pipe with proper fittings. 5/5
  16. The Following User Says Thank You to WantOnsKan For This Useful Post:
  17. #11
    Thanked: 1965
    Sorry to be doubting Thomas here.
    These compressors pretty much all have some type of soft polymer seal between the piston and the cylinder. And all these materials will suffer damage at or before 250 degrees C. If you get this seal to those types of temperatures, it's life will be shortened, probably significantly. This does not lead to sudden failure, but it does lead to the piston seal by-passing, and thus your compressor becomes less efficient until it eventually just runs and runs without actually pumping any air. Also keep in mind that this seal is doing pretty much all the work, and thus is the single hottest component in the compressor.
    Your compressor can be failing long before the motor ever cuts out, and if you pump it until the fitting joining the air hose to the compressor gives you a blister when you disconnect it, you have definitely damaged your compressor.
    When running a compressor, periodically feel how hot the head is getting, and if it feels like it's going to burn you, give the poor thing a rest.
  18. The Following User Says Thank You to Peter Connan For This Useful Post:
  19. #12
    Thanked: 526
    And any other negatives a few months later? Looks like a nice addition to the kit.
    Dont take anything I say as actual advice or fact. I dont.
    Haval H9 2.0T AWD
    Ex 2019 Ranger DC XLT Manual 4x4
    Ex 2017 Ranger DC XL Auto 4x4
