URGENT - Pathfinder Drivers window "Slider"
Results 1 to 5 of 5
    Bethlehem
    Thanked: 4470
    Default URGENT - Pathfinder Drivers window "Slider"
    Morning Guys, I need help/advise please, this Thread refers..........https://www.4x4community.co.za/forum...-LE?highlight=
    I need to deliver the Car ASAP in KZN, but the Driver's window is buggered - there's a little plastic "shifter" on the "PC Board" that has broken off (a 2mm piece of plastic!!!). This has been ordered, but the Courier is dragging its feet, and the Buyer needs the Car as in YESTERDAY, having sold his Car already.
    I tried at Nissan = Part is on Back Order for 21 Days.
    Where can I get this?? Even just a temporary solution will work, if that part arrives I can send it down to my Client.......but would prefer the thing to be 100% working upon Delivery 1000 times over.
    PLEASE try and assist here, thanks!!
    "Yes, I have a Bad Habit. I take Tea at Three".........Mick Jagger
    Mar 2015
    Thanked: 350
    Default Re: URGENT - Pathfinder Drivers window "Slider"
    Petri,
    Those moving bits on the PCB are normally the same for all 4 windows (on the Suzuki in any case). Can't you swop out one of the back window's parts with the driver side, only until you get the new part in. At least the drivers side will be working then.
    Bethlehem
    Thanked: 4470
    Update - thanks so far, I've borrowed a console thingy from a Livina as temp solution, if the correct part arrives I'll just send that down to my Buyer to install.
    So.........sorted this side, already delivered the car in Pennington yesterday
    Langs die rivier, op n berg
    Thanked: 3188
    Quote Originally Posted by Tom13 View Post
    Petri,
    Nie op nissan. Die bestuurderskant het n ander een vs die res (op selfde switch)
    Bestuurder kant slide, res het micro switch.
    Loevenstein, Bellville
    Thanked: 427
    For future reference, I had some luck with these guys when it comes to second hand spares for a Navara:
    Address: 21 Rumboll St, Strand, Cape Town, 7140
    Phone: 021 853 6681
    In fact, I replaced a window switch in our Navara with a part from them. They had a lot of stripped Navara's when I was there.
    Niel
    2012 BMW F800GS
