Ons nuwe ryhuis in wording..... - Page 3
Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 41 to 60 of 141
    Thanked: 2219
    Default Re: Ons nuwe ryhuis in wording.....
    Quote Originally Posted by vnielsen View Post
    Elize.....
    Dis nie 'n drag racer
    Henk
    Follow us on Facebook
  2. #42
    Thanked: 16
    Elize,
    I have a NPS300 motorhome. The tyre issue is important to note.
    GVM of that vehicle is 6 200kg. Front axle rated at 2 800kg, and rear axle at 6 600kg.
    The reason I state the axle loads above, is that it is clear the bulk of the load sits on the rear axle. You can easily manufacture your motorhome to have 3.6 tonnes on the rear axle - that is 1 800kg per wheel. Are the 265/70R19.5 tyres that you're planning to put on rated to that load?
    I have Hankook Dynapro MT's fitted (rated to 1 800kg) - I imported them (http://www.trucksupersingles.com.au/tyres.html) but I believe they are available from Motorhomeworld. You can also buy the 6 stud rims with them.
    Trucksupersingles.com.au also has Gladiator MT's 37x13.5R17, rated at 1 950kg, although I'm not sure they'll fit because they are slightly wider than the Hankooks.
    Also, with the smaller rim (and therefore greater tyre depth), you can deflate more in sand, and the truck has a softer ride.
    I've done 45 000km on these tyres so far. We've had one issue: A blow out in Mozambique, after damaging a tyre on sand tracks in Chobe (somebody's firewood buried in the sand...).
    Give this some thought.
    Enjoy the truck, it is an excellent 4x4.
    Etienne
    Edit: Oh, and make sure you put an aircon in the cab, it is well worth the money .
    Edit edit: Photo below of new Hankooks vs original OEM tyres.
Name:	iPhone 007 (3).jpg
  3. #43
    Subscribed!
  4. #44
    Dec 2009
    Delmas
    Thanked: 762
    Quote Originally Posted by erduplessis View Post
    Elize,
    Etienne
    Ja ons het intussen bande gekoop R10 17.5 Goodyear en dit kan 2120 kg per band vat.
    En ja, aircon in kajuit en ook een ekstra gekoop vir kamper agter.
    Elize
    en ry saam met SarelF in
    4x4 Isuzu NPS 300 met kamper
    Kyk gerus by www.blinkgatproducts.com
    Vir enige aluminium produkte,canopy's, campers kontak gerus
    Sarel 0828209413
  5. The Following User Says Thank You to witklipbank For This Useful Post:
  6. #45
    Dec 2009
    Delmas
    Thanked: 762
    Gou nog so foto of 2 van tot hoe ver ons Saterdag gewerk het.
    Die nosecone se vorm is gesny
    Elize
    Sarel 0828209413
  7. The Following User Says Thank You to witklipbank For This Useful Post:
  8. #46
    Dec 2009
    Delmas
    Thanked: 762
    Die dak is opgesit en daar is 'n luik ingesny,
    Elize
    Sarel 0828209413
  9. The Following User Says Thank You to witklipbank For This Useful Post:
  10. #47
    Dec 2009
    Delmas
    Thanked: 762
    Dan die deurklim luik is ook ingesny
    Elize
    Sarel 0828209413
  11. The Following User Says Thank You to witklipbank For This Useful Post:
  12. #48
    Dec 2009
    Delmas
    Thanked: 762
    En een belangrike item vir my is (met my ongelooflike vrees vir trappe) moes Sarel bontstaan om die trap te ontwerp.
    Hy is in sy beplan fase en dit lyk asof hy fantasties sal werk.
    Elize
    Sarel 0828209413
  13. The Following 3 Users Say Thank You to witklipbank For This Useful Post:
  14. #49
    Dec 2009
    Delmas
    Thanked: 762
    En hy kan dan opvou en onder die trok inskuif
    Elize
    Sarel 0828209413
  15. The Following 7 Users Say Thank You to witklipbank For This Useful Post:
  16. #50
    Dec 2009
    Delmas
    Thanked: 762
    Dan so paar ander dingetjies.
    Sarel het my die vrye hand gegee met die binne decorating. Saterdag die mooi goedjies gesien en is dit beslis op my inkopielys. (of van die goed.)
    Skottelgoedwasser vir 2 persone, mooi rooi ketel en daardie mooi rooi bank! Ek is oop vir voorstelle
ID:	579705   Click image for larger version.
ID:	579706   Click image for larger version.
ID:	579707   Click image for larger version.
ID:	579708   Click image for larger version.
    Elize
    Sarel 0828209413
  17. #51
    May 2015
    Paarl
    Thanked: 63
    Jammer as ek sleg kyk - waar is die blyplek van die "butler"?
  18. #52
    Gaborone, Botswana
    Thanked: 1199
    Baie netjies.
    Quote Originally Posted by witklipbank View Post
    ... Skottelgoedwasser vir 2 persone....
    By watter winkel kry mens dit ?
    Kobus
  19. #53
    Dec 2009
    Delmas
    Thanked: 762
    Quote Originally Posted by ChrisA View Post
    Dalk bo op die dak
    Elize
    Sarel 0828209413
  20. The Following User Says Thank You to witklipbank For This Useful Post:
  21. #54
    Dec 2009
    Delmas
    Thanked: 762
    Baie netjies.
    By House and Home by die Hyperama....en daar is 3 verskillendes.
    Elize
    Sarel 0828209413
  22. The Following User Says Thank You to witklipbank For This Useful Post:
  23. #55
    Malmesbury
    Thanked: 119
    koop vir ons ook sommer 'n mooi dingetjie vir ons camper ,kan nie wag vir ons s'n nie ,hell dis baie werk ,die ding is, ons gaan dit in lewende lywe sien
    Colt clubcab 2.8tdi 4x4 2005
    Ford Fiesta 1.4i (SWAMBO]
    opel corsa 1.7 dti 2006
  24. #56
    Feb 2017
    St Francis Bay
    Thanked: 56
    Dishwasher - next level camping👌, hope there’s a cappuccino machine going in there
  25. #57
    Thanked: 16
    Those tyres need to be pumped to close on 6 bar, and their side-walls are too strong to give any flotation when deflated. You will get terribly stuck in sand, and you'll feel every stone you drive over on a gravel road (it is in essence the tyre on the right of my previous photo).
  26. #58
    George
    Thanked: 82
    Môre, sjoe dit lyk na ń lekker projek
    wat is die binne afmetings?
    wat gebruik julle vir die kante, is dit die aluminium cladding profiel wat inskuif bymekaar?
    lekker beplan!
  27. #59
    Thanked: 217
    Voorstel: in plaas van 'n winkel bank koop, oorweeg dit om een te bou wat julle gaan toelaat om die spasie binne in die bank vir stoor spasie te gebruik.
  28. #60
    Aug 2010
    Delmas
    Thanked: 38
    Quote Originally Posted by PhlippieV View Post
    Die bank is n grap om reaksie uit te lok.
    BlinkGat Products
    Manufacturing of Aluminium
    custom made Products
    Sarel 082 820 9413
  29. The Following 2 Users Say Thank You to SarelF For This Useful Post:
