Ons nuwe ryhuis in wording..... - Page 4
Page 4 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 61 to 80 of 280
  1. #61
    Tshwanetoria
    Thanked: 866
    Default Re: Ons nuwe ryhuis in wording.....
    Sal goed pas by rooi hakskoene
    Quote Originally Posted by SarelF View Post
    Die bank is n grap om reaksie uit te lok.
  2. #62
    Thanked: 3991
    Net groot geluk vorentoe Sarel en Elize. Lyk my julle het 'n goeie projekt aan die gang en miskien sien ons mekaar weer aan die gang iewers.
    Se net as ek enigsins kan help.
    Stanley Weakley.
    Toyota Landcruiser 76SW 4,2L diesel.
    Trans East Africa 2015/2016 Trip report https://www.4x4community.co.za/forum...-6-SLOW-DONKEY
    OR
    http://www.4x4community.co.za/forum/...e16?highlight= from post 315.
  3. #63
    /\_/\_/\
    Thanked: 219
    Nuuskierig om te sien hoe julle die deur klim luik CAB toe gaan maak
  4. #64
    Thanked: 225
    Quote Originally Posted by erduplessis View Post
    Elize,
    I have a NPS300 motorhome. The tyre issue is important to note.
    GVM of that vehicle is 6 200kg. Front axle rated at 2 800kg, and rear axle at 6 600kg.
    The reason I state the axle loads above, is that it is clear the bulk of the load sits on the rear axle. You can easily manufacture your motorhome to have 3.6 tonnes on the rear axle - that is 1 800kg per wheel. Are the 265/70R19.5 tyres that you're planning to put on rated to that load?
    I have Hankook Dynapro MT's fitted (rated to 1 800kg) - I imported them (http://www.trucksupersingles.com.au/tyres.html) but I believe they are available from Motorhomeworld. You can also buy the 6 stud rims with them.
    Trucksupersingles.com.au also has Gladiator MT's 37x13.5R17, rated at 1 950kg, although I'm not sure they'll fit because they are slightly wider than the Hankooks.
    Also, with the smaller rim (and therefore greater tyre depth), you can deflate more in sand, and the truck has a softer ride.
    I've done 45 000km on these tyres so far. We've had one issue: A blow out in Mozambique, after damaging a tyre on sand tracks in Chobe (somebody's firewood buried in the sand...).
    Give this some thought.
    Enjoy the truck, it is an excellent 4x4.
    Etienne
    Edit: Oh, and make sure you put an aircon in the cab, it is well worth the money .
    Edit edit: Photo below of new Hankooks vs original OEM tyres.
    Attachment 579503
    I'm curious, how did you address the effects of the bigger diameter wheels? Did you change the gearbox or diff ratio?
  5. #65
    Gaborone
    Thanked: 25
    julle mag maar! Awesome!
    Hennie
    Ford Ranger Wildtrak 4x4
    Disclaimer: The views expressed by me in the above thread and replies are based on my personal experience and perceptions, which may be subjected to change from time to time.
    ORRA Call Sign B165
  6. #66
    Feb 2013
    Thanked: 499
    Wat is julle plan met bande om ruil in die bos? Domkrag, torque wrench en dan ook die hanteering van so swaar spaar wiel?
    Dit is altyd een van die eerste goed waar oor ek wonder as ek hierdie groot campers sien.
  7. #67
    Aug 2010
    Delmas
    Thanked: 49
    Die wiele is nie baie groter as bakkie wiele nie maar ons gaan n klein elektriese hyser gebruik om hulle op en af te haal.
    Ons beplan om later n hidrouliese stelsel in te sit om die kamper mee op te lig asook n hidrouliese wenas.
    BlinkGat Products
    Manufacturing of Aluminium
    custom made Products
    Sarel 082 820 9413
    www.blinkgatproducts.com
  8. The Following User Says Thank You to SarelF For This Useful Post:
  9. #68
    Delmas
    Thanked: 939
    Nou ja vandag was 'n besige dag op die plaaas met die koeriers.
    Die lugversorger is afgelewer.
    Elize
    en ry saam met SarelF in
    4x4 Isuzu NPS 300 met kamper
    Kyk gerus by www.blinkgatproducts.com
    Vir enige aluminium produkte,canopy's, campers kontak gerus
    Sarel 0828209413
  10. #69
    Delmas
    Thanked: 939
    Die invertor - pure sighn
    Elize
    Sarel 0828209413
  11. #70
    Delmas
    Thanked: 939
    En die 4 x 365 w sonpanele
    Elize
    Sarel 0828209413
  12. #71
    Delmas
    Thanked: 939
    En ek het intussen 'n rooi pan en rooi ketel gekoop.
    Elize
    Sarel 0828209413
  13. The Following 2 Users Say Thank You to witklipbank For This Useful Post:
  14. #72
    Ellisras
    Thanked: 688
    Quote Originally Posted by witklipbank View Post
    Waar gekoop ?
    Rudolf Ras
    Don’t blame yourself over past mistakes. It’s like driving down the N1 while looking in the rear view mirror only.
    2000 Patrol GU 4.2D(onkey) "old-timer" and wise at 851 000 km
    2014 Patrol GU 3.0CRD "teenager" in puberty at 111 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" at 124 000 km
  15. #73
    Clanwilliam
    Thanked: 312
    Alles is rooi .Sarel gaan sy hande vol he lyk na n rooilig gebied
    Dis nie n Isuzu nie ma i Bush Lodge!
    2011 FJ Cruiser
    2018 Hilux 2.4 4x4 D/C
    Afrispoor Serval
  16. #74
    Aug 2017
    Thanked: 50
    Volg
  17. #75
    Delmas
    Thanked: 939
    Quote Originally Posted by Sandveld View Post
    gelukkig nie buite nie. Net so klompie goed binne.....maar daar gaan baie goed in beidge wees
    Elize
    Sarel 0828209413
  18. #76
    Delmas
    Thanked: 939
    Waar gekoop ?
    Hier in Pretoria tel no 0845276423
    Elize
    Sarel 0828209413
  19. The Following User Says Thank You to witklipbank For This Useful Post:
  20. #77
    Dec 2012
    Secunda
    Thanked: 138
    Laat loop Sarel en Elize lekke projek ek hou die draad fyn dop
  21. #78
    Delmas
    Thanked: 939
    Vandag is die trok uit die werkswinkel getrek. Groot opgewondenheid want hy kom net net uit. Ek het al gesien hoe sny hul die deure van die werkswinkel groter.
    Toe gou vir 'n toetsrit gevat. Wel hy ry 100 x beter met die bak op as sonder die.
    Hier is 'n foto van die kamper in die stoor met die bo en onder deur
    Elize
    Sarel 0828209413
  22. The Following User Says Thank You to witklipbank For This Useful Post:
  23. #79
    Delmas
    Thanked: 939
    nog so foto met trap
    Elize
    Sarel 0828209413
  24. #80
    Delmas
    Thanked: 939
    die trok vir die eerste keer buite
    Elize
    Sarel 0828209413
  25. The Following 4 Users Say Thank You to witklipbank For This Useful Post:
