Results 1 to 9 of 9
Thread: Jetty Fenders
    Harties
    Thanked: 673
    Default Jetty Fenders
    We have an L-shaped jetty and need to fit fenders to the edges for the protection of boat hulls when they are moored there.
    The total jetty edges length needing fenders is 28m.
    Inland, so not salt water.
    Any suggestions?
    Some people use car tyres, others use strips of polyurethane sheets, others rigid plastic fenders (any sense in this?) etc.
    Any suggestions or comments as to what to use?
    If you make a noise or need music in the bush or on the beach, you’re missing the point.
    Oct 2006
    Walmer Heights, Port Elizabeth
    Thanked: 172
    Default Re: Jetty Fenders
    i would mount rigid plastic sheets to the full vertical surface of the edge of the jetty.
    in addition i would also moutn a short +- 100 - 150 mm section to the horizontal piece of the jetty around the edge
    Youtube
    Owned:
    1999 Colt Rodeo 3.0 V6 4x4-Build
    Sold:2005 Chevrolet Lumina UTE SS 5.7 V8 Auto - Build
    1998 Pajero Gen 2 SWB 3.0 V6 4x4 - Resurrection
    1997 Ford Ranchero Outback 4.0 4x2 -
    Build
    1979 Landrover Series 3 88" Ford 3.0 V6 4x4- Build, 1980 Landrover Range Rover 3.5 V8 4x4 - Build, 1979 Landrover S2A 109" with Chev 4.1 4x4
    cape town
    Thanked: 810
    I have used black thin walled irrigation pipe
    Does not scuff, lasted really well and easy to mount with nails.
    Can't find a good picture.
    Jan 2020
    Thanked: 212
    Use a heavy duty rubber pipe. A small hole for the bolt with washer to hold to jetty and a bigger hole on other side to put bolt and washer through. Water has a tenancy to bash boats against jetty when other boats speed past. That why I say heavy duty pipe about 100mm to 150mm should do best.
    Thanked: 2224
    I have just bought 4 fenders from a Cape Town operation. These were the cheapest I could find by a long shot and they are perfect at R 250ea plus shipping. Nice soft PVC that you can inflate to your desired level. They are shipped uninflated.
    OCEAN FENDER UTILITY U2 – WHITE
    520mm from tip to tip with eyes on both sides and 160mm in diameter (they say 140mm diameter).
    [email protected]
    Jul 2017
    Louis Trichardt
    Thanked: 289
    [email protected]
    Good price, seen them going for closer to R1k. I hope they are durable
    My Life Loving It
    Thanked: 2224
    Quote Originally Posted by Chris G View Post
    Very much so, they are heavy which means the PVC wall is thick.
  8. The Following User Says Thank You to Andrew Leigh For This Useful Post:
    Harties
    Thanked: 673
    I ended up using a dock fender profile from Pro Auto Rubber manufactured from EPDM.
    Will last forever, looks good, quite costly though.
    Jan 2009
    Linyanti, Botswana.
    Thanked: 133
    This is what we used on our docks when I was working in the Bahamas, it worked really well. I know it's not in SA, but, maybe something similiar can be made or found somewhere in SA.
    https://slammermarine.com/
    Land Cruiser 76 4.5D V8
    Conqueror Companion
    I don't trust anyone who's nice to me but rude to the Janitor. They lack integrity...
