Hose connectors
Results 1 to 10 of 10
Thread: Hose connectors
    Thanked: 345
    Default Hose connectors
    We never seem to have the correct hose connector for the campsite wherever we camp.
    What do you carry with to cover all the tap bases?
    Gaborone, Botswana
    Thanked: 1196
    Default Re: Hose connectors
    If it is me I will just get 3 of this. 1/2 , 3/4 and 1 inch.
    Kobus
    Jun 2012
    Thanked: 355
    ...or if that's still too bluky and heavy , they also have thread adapters that IIRC you can buy as a set.
    Make it happen!
    2018 Mobi Lodge
    Dec 2007
    nelspruit
    Thanked: 101
    There is universal that has a rubber fitting that clamp on fits everywhere even when there is no thread
    Feb 2013
    Thanked: 378
    Quote Originally Posted by bertus View Post
    Do you perhaps have a link to a connector like this?
    Gaborone, Botswana
    Thanked: 1196
    Quote Originally Posted by Toccata (Roelof) View Post
    I have seen those. That will be the ultimate compact solution.
    Kobus
  7. The Following 2 Users Say Thank You to KobusDJ For This Useful Post:
    Apr 2011
    Thanked: 102
    This fitting ...
  9. The Following User Says Thank You to spicydave For This Useful Post:
    Feb 2016
    Thanked: 941
    All of that should have you covered for almost any situation. I pack everything with the expandable hose in itís original box, nice and compact
  11. The Following User Says Thank You to MrTolbos For This Useful Post:
  12. #9
    Dec 2007
    nelspruit
    Thanked: 101
    yes, now we getting somewhere. Add bath plugs, basin plugs string it on a wire in the nose cone and you are settled. Only problem that I experienced is that stretch house does not work on low pressure, still thinking maybe the youngsters can help
  13. #10
    Thanked: 537
    Also be carefull if there is a stone under the hose and a car drives over it as any sharp stone will puncture the latex pipe inside the fabric. I onve had a guy stop on the hose to see if it will burst. It did not but later I found on the spot where he stood on it it had a hole in it.
