220V Compressor not working at home
Results 1 to 14 of 14
    Feb 2012
    Thanked: 64
    Default 220V Compressor not working at home
    Need some help from the Electric Guru's.
    Bought a 1.8KW (2.5Hp) 100 litre direct drive compressor from Builders to use at home. Sometimes it runs, other times it makes a humming sound and battles to turn (Run).
    Went back to builders and they plugged it in and it ran fine. Switched on about 8x times with no problems.
    Get back home and again it switches on sometimes other times just a loud humming sound.
    Back to builders and now insisting they send it back to supplier. Supplier checks and test and finds no problem.
    Back at home still same problem. Take it to a mates house and also same problem. Sometimes starts, other times only humming.
    We then plug it into the generator (5.5KVA 230V) and runs like a dream. Starts without a glitch and runs smooth.
    So the conclusion is that it is not happy with the Eskom 220V at home. 220AC at home measures around 216V and at mates house 218V.
    Wii changing the run Capacitor (40MFD 450V) on the motor make a difference, or do I call it a day and return back to Builders.
    Gary W
    Mar 2012
    Thanked: 1207
    Default Re: 220V Compressor not working at home
    Just sounds like a bad cap.I don't think it's voltage related though.
    What does the oil level look like?
    If it's new take it back
    Honda Civic Type R
    - Daily Drive
    Isuzu KB 250 Xrider - Swambo
    Feb 2012
    Thanked: 64
    Oil level 100%
    Brand new.
    Gary W
    Thanked: 538
    Quote Originally Posted by Tsotsi View Post
    Oil level 100%
    Brand new.
    I will not bother with a new cap. Take it back for a refund/replacement. Item not working as intended.
    Mar 2012
    Thanked: 1207
    Have you tried it at home in different temperature situations. In the garage it might not start because it cold. Take it outside leave it in the sun for 30min and then try again. Might be to do with the resistance of having to start the motor.
    Honda Civic Type R
    - Daily Drive
    Feb 2012
    Thanked: 64
    In the mornings it seems to start no problem. During the day/afternoon it does not. Thinking it is load on the AC grid.
    Strange thing is that at Builders in their office no problem. Running of the Generator also no problem.
    Even loosened the hose from the pump to the tank and it still won't start.
    The idea was to maybe run a slightly lower Cap and see if it will compensate.
    Just worried that even if they replace/refund I might have the same problem with another unit.
    Gary W
    Thanked: 522
    Had the same with an Adendorfs compressor, it is very sensitive to voltage supply, it does not like running of extension leads etc.
  8. The Following User Says Thank You to faniedup For This Useful Post:
    Wartburg
    Thanked: 1683
    I will also put my money on low voltage. Single phase starting currents are 4 to 5 times full load running current.
    Try running it on a plug closer to your DB. If you can, measure the voltage while it's trying to start it. My bet is that a replacement will do exactly what yours is doing.
    You could also try another capacitor - try and borrow one from a shop selling spares for testing
    Thanked: 14209
    Yep low voltage causes all types of crap, we had as low as 200vac at one stage and I had endless issues. If the neighbour also has low voltage, it will be the transformer. Log a call.....unless you are illegally connected or in an area that has this type of connection.
    Feb 2012
    Thanked: 64
    Our house is one of the old houses and still has 3-Phase connection into the house. From there we are connected to single phase.
    Just wondering if changing the value of the run Capacitor would make a difference. I have this feeling that I would have the same issue with another compressor as well.
    Will get someone to do a temp plug at the DB board and try.
    Gary W
    Wilderness
    Thanked: 1223
    Good heavens! Is that DB still legal?
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Thanked: 14209
    Agree, time to rewire, the voltage drop across phases will be huge.
  14. The Following User Says Thank You to jelo For This Useful Post:
  15. #13
    Feb 2012
    Thanked: 64
    Definitely antique. We still have electric cables running between the lamp posts in the area!
    Gary W
  16. #14
    King Williams Town
    Thanked: 1116
    Chat to your supply authority to tap up the transformer voltage. I like to keep our voltages between 230 to 240 volts AC.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  17. The Following User Says Thank You to hunter26 For This Useful Post:
