4x4 Gearbox recon
Results 1 to 6 of 6
    Apr 2020
    Paarl
    Default 4x4 Gearbox recon
    Hi,I have a 1999 4x4 Toyota Hilux with the 2.7 gearbox.The box is noisy through all the gears.Sounds like dry/worn bearings. Low range, high range and transfer case is working 100%.I live in Paarl (Cape Town). Mike's Place sells new gearboxes for 9k.Would you replace or recon? And who would you recommend?
    Thanked: 178
    Default Re: 4x4 Gearbox recon
    Friends have used Triangle transmissions and been happy.
    Parow area
    Westville KZN
    Thanked: 9
    Rex diff and gearbox (RDG) also did me a great job -
    Thanked: 2891
    Quote Originally Posted by The Hound View Post
    Rebuild kits is between 4 and R5k. Add labour and you will be close to 9k. There are very few I trust in rebuilding gearboxes in SA.
    Buy the new box.
    Wartburg.
    Thanked: 617
    Listen to Grips, he knows!
    Im yet to see a successful rebuild that doesn't hassle in one way or another, well around here in my area that is.
    That sort of profession is very scarce, like all other professions when it comes to trades men.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    Jul 2014
    Thanked: 9
    R9k for a new box is little money.
    I have a 2004 2.7 and collected my bakkie from Gearmax in Nelspruit last week.
    It cost double that, but included the spigot shaft/gears with 1st, 2nd and 3rd gear.
    The latter 2 only from Toyota at around R5k.
    Also did new clutch kit while the box was out.
    True about workmanship. They have a guy, goes by the name of Rasta, lady mentioned they will be lost without him.
    He stripped the box, I was called to witness the worn parts, before they continued to repair.
    The cost did include labour at R2k, the clutch was done for free, I bought the kit and paid for the flywheel skim.
    A 6 month/10 000km warranty is part of the deal.
    I bought the bakkie with 28k on the clock and 1 year old from a Toyota dealer.
    Box had a slight whine when I bought the vehicle. Started jumping out of first gear recently.
    Won't be surprised if they swopped boxes before I bought it.
    It only has 120k on the clock now.
    It drives better than ever now, so I'm more than satisfied.
    2004 Hilux 2700i 4x4 DC Raider
    2009 Terios 1500 4WD A/T
