LC V8 LX - What do you recommend
Results 1 to 15 of 15
    Jul 2007
    Middelburg
    Thanked: 12
    Default LC V8 LX - What do you recommend
    Greetings to my fellow Cruiser owners ,
    I need your expert advice please.
    In what order of importance will you invest in the following mods to your LC please:
    * K&N Filter
    * RACOR 2nd diesel filter
    * Oil catch can
    Your advice will be so much appreciated
    Keep calm and Toyota on!!
    Jan 2016
    Middelburg
    Thanked: 139
    Default Re: LC V8 LX - What do you recommend
    Maybe the diesel filter but never had issues. Wouldn't do any of the things you mentioned.
  3. The Following 2 Users Say Thank You to GarethHAllen For This Useful Post:
    Sep 2018
    Thanked: 16
    Well that depends on what you planning on doing with the cruiser. I would do the exhaust change out and filter for now. If you going cross borders then yes the fuel filter and I would probably say the catch can if you have not had your egr deactivated in the software.
    What mods have you done to the cruiser so far?
    You have one shot.
    Make it count.
    Pretoria / Motopi Village, Northern Botswana
    Thanked: 272
    Quote Originally Posted by Turftoon View Post
    * K&N Filter
    * Oil catch can
    Please...if you are gonna be doing overlanding and dirt road driving, LEAVE THE K&N filter...it is just not worth the engine damage you might pick up...
    In my humble opinion, I would do the RACOR pre-filtration system FIRST AND FOREMOST...then whatever else...
    Trev
    2014 Land Cruiser 76 SW with extras
    2019 Jaguar Inkwe 4 Offroad Caravan
  6. The Following User Says Thank You to Trevor_Mathews For This Useful Post:
    Thanked: 14155
    Listen to Trevor.
    Robertson/ Larissa, Greece
    Thanked: 3377
    Listen to Trevor.
    Agree
    Jul 2007
    Middelburg
    Thanked: 12
    Thanks fellow forum gurus!!
    Jul 2007
    Middelburg
    Thanked: 12
    Quote Originally Posted by Roughneck View Post
    Thanks Roughneck for the advice. I bought the vehicle with the following extras:
    Diesel free-flow
    Amada Xtreme suspension
    Both front and rear replacement bumper
    Ironman winch
    I then fitted :
    Wilddog rocksliders
    Drawer system
    And a few other "soft mods"
    I do intend doing a lot of overlanding (Bots, Nam, Angola, etc)
    I pull a Jurgens Xcape
    Prior to the V8 I had the 4.2 straight 6 donkey but did a very enjoyable trip to Angola last year March North of Namibie and South to Flamingo lodge.
    I then decided to upgrade and are very happy.
    You mentioned removing the EGR electronically... can you perhaps elaborate?
    Thanks Click image for larger version.
    Thanked: 272
    Diesel free-flow
    Ironman winch
    I then fitted :
    Wilddog rocksliders
    Drawer system
    The EGR can literally be switched off when remapping the ECU...they tend to get stuck in the open position due to oily sludge build up and when this happens you have a permanent error lightup on your dash and you need to replace it...big cost as it sits in a very difficult place to get to.
    The EGR is all about emissions...quite frankly useless and potentially causes unenecessary headach...
    If you do go this route, look at fitting an oil catch can while you are at it...look at the locally produced LOCO CAN...it has a washable stainless filter whereas the imported one needs a replaceable filter every so often at quite a cost.
    Hope this helps.
    God bless
    Trec
  12. The Following User Says Thank You to Trevor_Mathews For This Useful Post:
  13. #10
    Jul 2007
    Middelburg
    Thanked: 12
    Thanks Trevor, much appreciated
  14. #11
    Apr 2018
    Thanked: 19
    Removing EGR via remapping the ECU is not successful, go for a catch can, it work's very well. The K&N filter is a big NO, you will get dust in your engine. A Racor pre filter is also a very good idea. I have done the above on a 76 V8, 200VX and now on a 79 V8 and all of them have been all over Southern Africa and it is really worth-while.Enjoy your beautiful Land Cruiser.
  15. The Following 2 Users Say Thank You to Andre Bos For This Useful Post:
  16. #12
    Oct 2017
    Rustenburg
    Thanked: 3314
    Quote Originally Posted by Andre Bos View Post
    This is the best advice here
    Dum vivimus, vivamus!
  17. The Following User Says Thank You to Hedgehog For This Useful Post:
  18. #13
    Thanked: 272
    Please tell us why switching the EGR off in the ECU mapping is not successful?
  19. The Following User Says Thank You to Trevor_Mathews For This Useful Post:
  20. #14
    Jul 2007
    Middelburg
    Thanked: 12
    Thanks to all for your valuable advice. It sure is well worth being a member of this forum... Dankie my groot krone!! Click image for larger version.
  21. The Following User Says Thank You to Turftoon For This Useful Post:
  22. #15
    Thanked: 74
    Quote Originally Posted by Trevor_Mathews View Post
    ...ook at fitting an oil catch can while you are at it...look at the locally produced LOCO CAN...it has a washable stainless filter whereas the imported one needs a replaceable filter every so often at quite a cost.
    Rather look at the Flashlube Pro .. filter housing/can can be drained at a tap on the bottom of the can and the filter only needs replacement at every 40K kms. Do a search and read the international comparative reviews and independent test results ....
    2c
    UZJ 42 LX: Olive (Sold and bought her Back !)
    HDJ 75 RV Troopy
