Defender 300Tdi Exhaust
Results 1 to 20 of 22
Thread: 300Tdi Exhaust
    Feb 2015
    Thanked: 11
    Default 300Tdi Exhaust
    Straight through pipe or 1 free flow box? What are you running?
    Mar 2015
    New Germany
    Thanked: 503
    Default Re: 300Tdi Exhaust
    Put 1 small free flow box in as the 300TDi will sound like a tractor,
    2005 Defender TD5
    Mar 2018
    Goba
    Thanked: 154
    Quote Originally Posted by thujack View Post
    1 Box only...Remove the front and keep the rear...(Original)
    1997 Discovery 1 300 TD i ...Old Faithful (Sold) Rusty
    2006 Discovery 3 2.7 TDV 6...not sure yet ? (Scrapped) Could not last
    2011 Toyota Fortuner D4D 4x4 Man
    Nov 2011
    Langebaanweg
    Thanked: 1191
    Mine had a freeflow setup as standard.
    The centre box was huge and heavy.
    I removed it.
    I now only have the rear box.(Still LR original) It's very small.
    I didn't notice a big difference in sound or performance with the removal of the centre box.
    With passenger window open and driving next to a wall, SWAMBO says it's like a truck.
    I'm contemplating removing the rear box, but never got to it.
    Thanked: 446
    Just remove the centre box.
    2004 Defender 110 Td5
    Thanked: 14248
    IMHO, leaving the diameter the same and removing a silencer will have minimal effect.
    Nov 2011
    Langebaanweg
    Thanked: 1191
    Mine is running a 65mm if I remember correctly.
    Thanked: 14248
    Then you would have seen most of the benefits already.
  9. The Following User Says Thank You to jelo For This Useful Post:
    jfh
    Nov 2018
    Mukifu
    Thanked: 448
    Just curious why would you remove any? Sound? Performance? Fuel consumption? Other?
    20 odd years box standard and happy as Larry with my 300.
    Took the cats out of the 2.8 and wish I hadn't, read a lot on how it increased power and saved fuel. Zero fuel saving or performance enhancement and sounds like a lawn mower.
    1996 300 TDI Defender 110 (Aqualung)
    1997 2.8i Defender 110 (Fats)
    1982 Mog 416
    1980 FJ45 (Piglet)
    1967 series 2a (dugudugu)
    1958 series 2 (Betty)
    Amarok (platcar to fetch eggs)
    Self made nilionaire
    Thanked: 14248
    The 300tdi like a bigger downpipe. Less turbo lag. Less EGT.
  12. The Following 2 Users Say Thank You to jelo For This Useful Post:
  13. #11
    Oct 2019
    Thanked: 36
    The only real benifit is it lowers the EGT temps and turbo manifold temps thus pro-longing the life of them and the head due to lower temps.
    It also reduces turbo lag lower down in the rev range
  14. The Following User Says Thank You to Bushbuk For This Useful Post:
  15. #12
    Thanked: 14248
    Quote Originally Posted by Bushbuk View Post
    Yes, what I said.
  16. #13
    Oct 2019
    Thanked: 36
    Sorry snap... took me longer to type😜
  17. #14
    Thanked: 14248
    No worries
  18. #15
    Sep 2014
    Sir Lowry's
    Thanked: 136
    What Jelo said!
    I've removed all boxes, pipe exits just in front of the left rear wheel.
    Yes, she sounds like an old John Deer, but it makes me moist.
    Turbo spools up a dash quicker, EGT most def lower.
    Do that along with a tweak on the Bosch VE and you have whole machine!
    No need to change gears the whole time, she has grunt in places she never had.
    Disclaimer: EMS (EGT probe) a must before tweaking fuel pump.
  19. #16
    Witbank
    Thanked: 205
    I have straight through pipe on the 130. Does sound like a tractor if you have passenger window open and drive next to a wall or something.
    But in all honesty, I like the sound.
    Power and or lower EGT, not that I noticed. But I do think Jelo is right, if you really want to get the full benefits, you need to start at the downpipe and take it all the way back.
    That's my next plan, bigger downpipe to try and drop EGT's as I have quite an aggressive tune on mine, with hybrid turbo and bigger intercooler.
  20. #17
    May 2010
    Thanked: 217
    My 300tdi D1 takes 24 seconds 0-100km/h
    Is that ballpark or slow for this vehicle?
  21. #18
    Witbank
    Thanked: 205
    I wouldn't know, I am pretty sure that my 130 takes long than that, but never really timed it.
  22. #19
    Thanked: 91
    Quote Originally Posted by JurgenSteyn View Post
    The spec sheet says 18.4 sec
    I must measure mine someday
  23. #20
    Aug 2016
    Thanked: 18
    Mine is just over 20s. But my timing is way retarded and pump is at stock settings.
