New Maxxis Razzor AT
Results 1 to 20 of 26
    Oct 2017
    Rustenburg
    Thanked: 3912
    Default New Maxxis Razzor AT
    Has anyone got prices on this yet? How does it compare pricewize?
    Andrew van Staden
    Dec 2014
    Thanked: 171
    Default Re: New Maxxis Razzor AT
    Isn't the Razr a M/T?
    2012 Jeep Wrangler JKUR
    35/12.50/17 BFG KM2s
    AEV Heat Reduction Hood
    Lonehill, JHB
    Thanked: 1032
    There is a new AT that was recently launched
    2014 Pajero 3.2DiD SWB
  4. The Following User Says Thank You to KurtG For This Useful Post:
    Oct 2017
    Rustenburg
    Thanked: 3912
    Quote Originally Posted by Alwyn777 View Post
    Andrew van Staden
    Dec 2014
    Thanked: 171
    Ah okay cool. Not yet listed on Maxxis' website under their SUV and 4x4 tire section, hence asking. Looks very good though! Should be in the same price range as BFGs and Coopers I reckon.
    Thanked: 1090
    3 ply sidewall?
    Malcolm van Coller - retired 2013 but remained in Johannesburg (maybe will look at moving south, Robertson or Wellington type of town, once the wife retires)
    Ex 2011 Conqueror Supra II
    Ex 1995 Sani 3.0 V6 Exec
    Oct 2017
    Rustenburg
    Thanked: 3912
    Quote Originally Posted by mvcoller View Post
    3 ply sidewall?
    No idea... But generally Maxxis do not advertise their sidewall rating
    Andrew van Staden
    Strand
    Thanked: 22
    It says 3-ply sidewall on the add that Kurt posted....??
    His:
    2009 Pajero 3.2 Di-D GLS
    1996 Beamish Buggy SWB
    Hers
    2008 Triton 2.5 4x4 S/S - Longdistance roamer
    Oct 2017
    Rustenburg
    Thanked: 3912
    Quote Originally Posted by JeanR View Post
    I don't see it?
    Andrew van Staden
    Oct 2017
    Rustenburg
    Thanked: 3912
    Ha
    Found itClick image for larger version.
    Andrew van Staden
    Jun 2015
    Pretoria East
    Thanked: 732
    I don't see it?
    Bottom right corner.
    Do I have a problem if I say, another very sexy tire .
    Dirk Theron
    18 Land Cruiser FJ - build to play
    19 Hilux 2.8 GD-6 Auto 4x4 - my best build ever
    17 BL865 Ratel4 - the house on wheels
    Lifes a journey, enjoy the ride
    Thanked: 1090
    That is no good if they do not say, I am also not interested so much in the ply rating, but rather the actual numbers of sidewall plies. It is an important factor in looking for tyres, they should at least say their tyre model has 3 ply sidewall if they do have.
    Having said that, generally if they say the tyre is a 6PR (6 Ply Rating), is means in term of strength, it is as strong as an old Cross Ply tyre that had 6 plies. Modern tyres rated as 6PR often only have three plies on the tread portion of the casing, two plies of cotton (actually Rayon or Nylon) across the whole tyre tread and one steel ply, the two cotton plies then continues to the bead. These are your SUV type 2 ply sidewall tyres and mostly has a load rating of around 109/112.
    Generally, and I really mean only generally, not always, an 8 PR tyre will have 3 sidewall plies. An 8PR tyre, is by reason of its construction a heavier tyre, sturdier (thicker) sidewall rubber and usually 3 plies in the sidewall. These would have 3 plies from bead to bead and an additional steel ply in the tread area. This is also a tyre called a LT (Light Truck) tyre, the type of tyre recommended for heavy load and extreme rocky areas when over-landing. it will also have a 121/118 load rating or better. Some of these LT tyres may even be a 10PR tyres
    So 6PR, 8PR, and 10PR are not actually the number of plies, it is only an indicative rating, meaning "as strong as a conventional cotton plies of this number of plies". Tyres do not actually have these numbers of plies today, because that many plies makes the side walls too hard, thick and unforgiving, causing a lot of heat buildup and leading to eventual premature tyre failure.
    I want to sit at home, see on a manufacturers' websites which tyres have 3 ply sidewalls and then go on the internet find real life experiences guys have had with the tyres. I want to know how the average over-lander rates those tyres, for grip in sand on rock, on dry or wet tar, and how do they last?
    If I do not find the number of side wall plies on the manufacturer's website, I generally do not bother with that specific tyre. I know for instance, that BGF, Cooper, Dunlop AT3G, Sailun and now these Maxxis tyres have 3 ply sidewall plies.
    I will only fit 3 ply tyres on my Patrol, which I only use on taking visitors on safari. I lost 3 tyres in two days in Northern Namibia going on an extreme route. The tyres were good ATRs, but only had 2 ply sidewalls. It is not a good advert for your business to loose 3 tyres on one trip, never mind in two days. Three ply sidewalls are not totally immune to sidewall cuts, but they have better cut resistance and are not often penetrated buy sticks and those thick white (Acacia) thorns .
    Thanked: 1090
    Quote Originally Posted by DCTheron View Post
    And with all those sipes on the big tyre blocks, should not be too noisy on tar either....
  15. #14
    Jan 2014
    Rustenburg
    Thanked: 2620
    Spoke to one of the Maxxis reps, no price at the moment as stock will only be available from September, but would be slightly more than the 980 Bravo's.
    Hermie
    Turning Vegan would be a big missed steak!!
    Jurgens XT 140
  16. The Following User Says Thank You to JeepNewbe For This Useful Post:
  17. #15
    Nigel
    Thanked: 2329
    Let's put it differently.
    Maxxis have got the compound down pat and the sidewall protection is brilliant.
    Be it the Razr, Mining Razr or the AT Razr, I will go head to head with anybody.
    Uniglide
    +27 zero eight 2 four 95 9252
  18. The Following 2 Users Say Thank You to Henris For This Useful Post:
  19. #16
    Apr 2012
    Thanked: 39
    Quote Originally Posted by JeepNewbe View Post
    That will then put the price on par if not more than the Bf K02
    RechardT
    Now- Toyo GD6 2.8- Creed
    One day is One day- Dodge Ram 6.7l TD.
    You can go anywhere you want in life as long as its in a 4x4.
  20. #17
    May 2010
    Greenstone
    Thanked: 392
    I have the 245 Razrs on my Disco 1 and 285 Razrs on my Defender Td5 and it is the quietest mud I have used so I have no doubt the AT will be excellent.. My 90 still has Grabber X3s on it but will change these for Maxxis when the time is right.
    Discovery Sport 2.0i D
    Defender 90 LE Puma 2.2TDCI
    Defender 110 DC Td5 (life partners)
    Discovery 1 200 Tdi Auto
  21. #18
    Krugersdorp
    Thanked: 413
    Any more information on these?
    Bush Lapa Miskruier 586
    Youtube Channel: https://www.youtube.com/c/HenkBogaards4WheelingSA
  22. #19
    Nigel
    Thanked: 2329
    Apparently Aug Sept
    Uniglide
  23. The Following User Says Thank You to Henris For This Useful Post:
  24. #20
    Sep 2010
    Lonehill
    Thanked: 15
    Reviving this thread as I need to replace my BFG KO2's and there is no BFG stock in the country. Dealers tell me they are only expecting stock at the end of October.
    Rivonia Tyre have been trying to get me a price on the Maxxis Razr AT's, but can't get hold of Maxxis SA or their rep.
    Has anyone had any luck in sourcing these tyres yet? If so, what did you pay for them?
    2013 Toyota Land Cruiser 200 VX 4.6L
