Defender Strange steering behaviour
Results 1 to 5 of 5
    Langebaanweg
    Thanked: 1135
    Default Strange steering behaviour
    I recently did my swivel pin housings.
    I just replaced seals and new grease, although I striped and cleaned everything.
    All bearings where in excellent condition but I did replace the needle bearings in the stub axle as I replaced the seals behind them.
    I did preload on swivel pins IAW the manual.
    All bolts where torqued and locktited.
    She drives normally.
    But if I reverse out of the driveway after it standing for a few days, when I turn the steering wheel to drive off, there is a stiffness/hesitation on the steering wheel.
    It's just then. If I try to replicate it... nothing.
    It only happens once and then it's gone.
    Steering box was replaced 2 years ago with all ball joints.
    Can't get my head around it.
    Thanked: 13630
    Default Re: Strange steering behaviour
    Power steering pump.
    Langebaanweg
    Thanked: 1135
    Might it be affected by the cold?
    Fluid level is fine.
    No noise.
    Thanked: 13630
    If your steering box needed replacing, you can appreciate the pump would have similar wear and tear but it's fine, ignore my comment.
    Langebaanweg
    Thanked: 1135
    No. I understand.
    I replaced the box because of a collapsed bearing.
    I would just have expected the pump to give me an indication, audible maybe, of failure.
