SnapBridge - Nikon D500
Results 1 to 15 of 15
    Thanked: 227
    Default SnapBridge - Nikon D500
    Hi guys - my Nikon D500 initially did not have issues transferring photos from the camera to phone via the SnapBridge app, but it has now not done it for a while. I have Googled all the possible remedies, have deleted and re-install it etc, but it still does not work.
    It goes through all the motions but just does not transfer.
    Is there a fail-safe cure for the connection issues anyone know of?
    Thanks.
    2009 VW Touareg 3l V6 TDi
    2006 Isuzu DMax 300Tdi DC 4x4 (sold)
    Thanked: 1024
    Default Re: SnapBridge - Nikon D500
    Personally I have never tried it, but I am just wondering: when last did you upgrade the firmware of your camera?
    I suspect Snapbridge, like most phone apps probably auto-updates, but the camera doesn't.
  3. The Following User Says Thank You to Peter Connan For This Useful Post:
    Thanked: 227
    Hi Peter, never, how do I do that?
    Thanked: 227
    Don't stress, found this of Steve Perry on youtube, am sure it will have everything in it:
    https://www.youtube.com/watch?v=KEWQ4GCbWuI
    You have taught another thing today, thank you Peter Connan!
  6. The Following 2 Users Say Thank You to walkabout For This Useful Post:
    Thanked: 1024
    Just hope it solves the problem!
  8. The Following 3 Users Say Thank You to Peter Connan For This Useful Post:
  9. #6
    Feb 2016
    Thanked: 941
    At which exact step does it stop when you attempt to re-do the connection between camera and cellphone? Which cellphone do you have?
    A while ago I had the same issue. Also did a firmware update but to no avail. I had to disconnect/Ďforgetí all connections on the camera as well. Then reconnect as if itís the first time setting it up. Have you tried that?
  10. The Following User Says Thank You to MrTolbos For This Useful Post:
  11. #7
    Thanked: 227
    HI MrTolbos, will check where exactly, it's been a while but like all things started to bother me as I might take some pics this weekend!
    I still have a Samsung S8, but have not done the procedure you described. Will do the firmware upgrade and take it from there and report back.
  12. #8
    Feb 2016
    Thanked: 941
    Quote Originally Posted by walkabout View Post
    I had a quick look again, and Iím pretty sure it was the Bluetooth connection that I had to delete on the camera:
  13. The Following User Says Thank You to MrTolbos For This Useful Post:
  14. #9
    Thanked: 227
    Thanks, I have done it on the camera, thought you were talking about on the phone.
    Anyway, will do it today and report back later.
  15. #10
    Thanked: 227
    Ok have updated the firmware and it is definitely closer to happiness...it at least seems to connect phone & camera, it is just the last step where one is supposed to see the camera pictures on the phone where things are just blank (black screen). Yes there are pictures taken. Will try again tomorrow.
  16. The Following User Says Thank You to walkabout For This Useful Post:
  17. #11
    Thanked: 227
    Quote Originally Posted by MrTolbos View Post
    I have now deleted the phone off the camera and vica versa. The phone does not seem to pick up the camera. If I scan for available devices it comes back with "no devices found".
    After a few tries it shows the camera but now says;"Couldn't pair. Check settings for this device and try again".
    Bluetooth is on on the camera but the "paired devices" option is now dull, so can't get there.
    Rather frustrating.
  18. #12
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    I donít know if you have tried this, but perhaps it could help:
    https://www.nikonimgsupport.com/eu/B...ameOrigin=null
  19. #13
    Thanked: 227
    Will have a look thanks SAND.
  20. #14
    Thanked: 227
    Ok, somehow got everything connected again, in the process also updated the snapbridge app so that possible issue is now also eliminated. But I'm back at #10...so it does everything but showing me the photos. Will fight again tomorrow, rather frustrated now. Thanks for everyone's assistance.
  21. #15
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    Shot in the dark here...
    Do you shoot RAW, or RAW+JPG? Perhaps try JPG or combination, and see if the images show.
  22. The Following User Says Thank You to SAND For This Useful Post:
