Camping Shower and Pump
Results 1 to 20 of 112
    Nov 2006
    Lonehill
    Thanked: 403
    Default Camping Shower and Pump
    I would like to set up a camping shower system. It will be mounted in my canopy. Im guessing it will include, a water tank, pump, gas geyser and obviously the piping and shower head. is there anything else?
    Please could you recommend a no hassle setup to be used far off grid.
    - What size water pump do I need?
    - What geyser is best? I was looking at something like this : Total Outdoor Gas Geyser with shower set
    https://ecodepot.co.za/products/tota...CABEgK7P_D_BwE
    Any other suggestions?
    Thank you
    BruceT
    ZS6EBT
    Defender 130 Puma
  2. The Following User Says Thank You to BruceT For This Useful Post:
    Apr 2011
    JHB
    Thanked: 87
    Default Re: Camping Shower and Pump
    Hi Bruce,
    A lot more basic than what you're proposing, but we use the following:
    https://4x4direct.co.za/camping-and-...et-12v-dc.html
    This is fed from an old metal water jerry can which is placed on the coals for 30 minutes - nice hot water with decent pressure.
    Current - FJ Cruiser
    Current - Disco 2 GS TD5
    Current - BMW GSA 1200
    Ex - Ford Ranger WildTrak
    Ex - KTM 300 XCW
    Ex - Jeep Commander (Biggest POS ever owned)
    Ex - Mitsubishi Triton
    Ex - Gen 4 Paj SWB Tractor - Death by Taxi
    Ex - JK Wrangler Rubicon - Sold
    Ex - Colt Rodeo
    Ex - Audi S3
  4. The Following 5 Users Say Thank You to matty2.8tdi For This Useful Post:
  5. #3
    Apr 2019
    Thanked: 738
    I built a system into an ammo box. The ammo box contains:
    1) Pentair/Shurflo AquaKingII 11.4 LPM pump, R 1500 or so ex
    2) The Kariba combination hot water / LPG burner - http://www.karibaproducts.co.za/
    3) On/off switch for pump
    4) 50A BH plug for 12v supply
    5) 2x Hella sockets for accessories
    6) Intake port with strainer
    7) Output port on front to connect hose/shower
    8) Output port on back to allow the pump to recirculate water thru the Kariba, back to the source water tank.
    9) Battery voltage meter
    There are two ways the Kariba can be used:
    A) Water pumped straight thru it, to a shower head. Because there is no tank in the Kariba, and no on demand function to ignite/extinguish, water must always be flowing thru it, which means better use is B)
    B) Water pumped in a loop, from a low fitting on a water tank, thru the Kariba, back to the top of the water tank. This tank can be any size - 10l, 20l, 40l. In my case, 40l. Run the water in a loop, until the desired temp in the tank is reached, then turn off the loop, and run water thru the head.
    In use, the Kariba comes out of the ammo box and sits on top. There is also room in the ammo box for hoses, shower head. this also allows me to plumb a connection for a sink, or wash down hose (nice for the beach). The ammo box and gear mounts to the roof rack, but can be moved anywhere that suits. The other add-value here is I can use this to pump water thru a 5 stage filter system, if I wanted to, eg, from a river.
    The Kariba can also be used to cook, so is dual purpose. The kariba unit is expensive. But in terms of far-off-grid, this has the value of being multi-purpose - which is important when space and weight are limited.
    You could go with a smaller pump - this pump has enough pressure to be properly used as a wash-down. We connect it to two 40l tanks with individual shutoff, so I can heat water in just one of the tanks. These pumps have pressure switches, so you can leave them on, vice the submersible pump, which is either on or off.
  6. The Following User Says Thank You to heyyahhey For This Useful Post:
  7. #4
    May 2015
    Paarl
    Thanked: 62
    Same as matty2.8tdi
    If in a hurry - one kettle of hot water enough for lovely 5 liter warm shower. my wife prefer this to many shared ablution showers.
    It is so small/light/cheap - I even carry a spare!
  8. The Following 2 Users Say Thank You to ChrisA For This Useful Post:
  9. #5
    Nov 2016
    Thanked: 131
    Quote Originally Posted by matty2.8tdi View Post
    Hi Bruce,
    I can second this, works very well - I stuck a magnetic thermometer on the side to monitor the temp - it easily gets too hot.
  10. The Following User Says Thank You to JadeDsantos For This Useful Post:
  11. #6
    Nov 2006
    Lonehill
    Thanked: 403
    Thank you for the replies.
    We've used the pumps and jerry cans but would like something a bit less hassle, as it will sometimes not be possible to make a fire. The kariba looks like an option and the only negative i think, is having to pack it away in a wolf pack, so will have to wait for it to cool down first I would guess?
    BruceT
    ZS6EBT
    Defender 130 Puma
  12. #7
    Apr 2019
    Thanked: 738
    We've used the pumps and jerry cans but would like something a bit less hassle, as it will sometimes not be possible to make a fire. The kariba looks like an option with the only negative is having to pack it away in a wolf pack, so will have to wait for it to cool down first I would guess?
    It runs quite cool, actually, when water is circulating thru it. You can actually put your hand on the top of the heat exchanger, when it is circulating.
    It would still need to cool a bit, yes - but it would not be long. In our case, the tanks are mounted to the roof rack. So it's not a lot of hassle. I'd rather have the tanks inside, but that's for the future.
  13. The Following User Says Thank You to heyyahhey For This Useful Post:
  14. #8
    Feb 2013
    Thanked: 372
    The most straight forward system and probably less expensive as well is a 12V pump connected to a hand held shower and a blue metal jerry can.
    Leave the half full jerry can in the sun for the day or put it next to the fire, add cold water, put in the pump and enjoy your shower.
    If you do a setup with a tank, make provision so that you can connect the geyser directly to a tap as well. Often you get to a place with a water tap but you want to keep the clean water in your tank for drinking, then you can connect the geyser directly to the tap and shower like that. In my experience if you get to a place with a tap, you don't always want to put that dodgy water in your tank and threw your entire system, so you rather keep the clean water in your tank for cooking and drinking and shower directly off the tap.
  15. #9
    Dec 2007
    nelspruit
    Thanked: 99
    I had seen a photo of setup that consist out of a 110mm pipe painted black on the roof rack. Filling hole and all those things. Just connect and shower
  16. #10
    Okahandja, Windhoek
    Thanked: 870
    Thank you
    You should get the pressure requirements for the geyser also. That is a 5l/min geyser thus the pump must deliver at least 5l/min at the pressure that the geyser requires. My guest would be it would be a pump that can pressurize up to 30 psi , else the geyser will just frustrate you.
    https://www.4x4community.co.za/forum...67#post4332167
    Johan Kriel
  17. #11
    King Williams Town
    Thanked: 1110
    Silly idea... But what happens when you run your battery down for some unexpected reason and if using solar you have a few bad rainy days... Fear not, best is buy a boat bilge pump. Pump your shower , or if you want to get fancy. Get a tank with a non return valves on one side and the other side with one tap to shower head on the other. Pump water into tank till bar pressure is achieved. The air compresses, when opening tap you will have pressurized water to shower with. No electricity required.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  18. #12
    Okahandja, Windhoek
    Thanked: 870
    Silly idea... But what happens when you run your battery down for some unexpected reason and if using solar you have a few bad rainy days... .
    Start the vehicle.
    Johan Kriel
  19. The Following User Says Thank You to JLK For This Useful Post:
  20. #13
    Jan 2019
    White River
    Thanked: 17
    Have a alva gs205 geyser but rarely use it. Found that a 40 l pioneer plastic water tank on the roof rack reaches about 35 degrees in September to October. Then use a bucket with a 12v oztrail shower.
  21. #14
    Aug 2018
    Paarl
    Thanked: 71
    For my long term camping I use a system that I built.
    Dewhot 6L geyser
    12v waterpump 8l/min
    120L watertankName:  IMG_20171208_084227.jpg
  22. The Following 2 Users Say Thank You to fatbike For This Useful Post:
  23. #15
    King Williams Town
    Thanked: 1110
    Quote Originally Posted by fatbike View Post
    Dewhot 6L geyser
    You take bathing seriously . Gone are the days of taking a small zinc bath with when camping. Water heated in a 20ltr cleaned out oil drum on the fire, use a jug to pour water over self.
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
  24. The Following User Says Thank You to hunter26 For This Useful Post:
  25. #16
    Aug 2018
    Paarl
    Thanked: 71
    Jip its 2020 need to stay abnormal clean. 😂
  26. The Following 2 Users Say Thank You to fatbike For This Useful Post:
  27. #17
    Feb 2016
    Thanked: 937
    Having to make a fire first was my main gripe also when you want to leave early morning, and where do you pack away that dirty jerrycan them?
    We use the bundu shower from http://bundushowers.com. Very compact, and itís cool enough to handle by the time you are dressed. I paired it with a 3.8L/m shurflo pump. We get away with using 5L of water per person if you close the taps between soaking and rinsing.
    And itís proudly made here in SA!
  28. The Following 5 Users Say Thank You to MrTolbos For This Useful Post:
  29. #18
    Nov 2006
    Lonehill
    Thanked: 403
    Quote Originally Posted by MrTolbos View Post
    Thank you. That looks like a great option.
    BruceT
    ZS6EBT
    Defender 130 Puma
  30. #19
    Nov 2006
    Lonehill
    Thanked: 403
    Just received the pricing for it. Ummm nope!
    So far the outdoor gas geyser type of geysers are leading the pack at half the price of the "camping" showers.
    BruceT
    ZS6EBT
    Defender 130 Puma
  31. #20
    Oct 2008
    Grabouw
    Thanked: 230
    Good morning. Are you prepared to share that price?
