Camping Shower and Pump - Page 6
Page 6 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 101 to 120 of 171
  1. #101
    Overlanding Southern Africa
    Thanked: 75
    Default Re: Camping Shower and Pump
    Nice and simple. What do you use to pressurise it?
    Glue in a tyre valve and just plug in tyre compressor as and when you need pressure. Worked good for us too.
    Dale
    WhatsApp: +64-21832765 (Currently in New Zealand)
    2006 Suzuki Grand Vitara V6 2.7
    2006 Toyota Hilux DC V6 4.0
    2007 Nissan Pathfinder V6 4.0
  2. #102
    May 2018
    Hi Bruce
ID:	580651Click image for larger version.
ID:	580653Click image for larger version.
ID:	580654Click image for larger version.
ID:	580655Click image for larger version.
    This is my Hours-of-Showers kit. Thought I needed to come up with plan after years of “showering” in the river, lake or dam. The cumulative shower time runs into many hours.
    In remote areas with no one else around, will just set it up by hanging geyser unit on the outside of the trailer and shower “al naturale”. If we are staying longer or in company, will set up the Tentco shower cubicle.
    The travel box becomes the reservoir that holds the water which is sourced from river/dam. System starts and shuts off automatically when you close the tap on the shower head between wetting, soaping and rinsing.
    Not pictured is the gas cylinder used for cooking and 12V battery for lighting.
  3. The Following User Says Thank You to Freetofish For This Useful Post:
  4. #103
    Feb 2015
    This unit -Kexin - is it more efficient compared to the Totai that look very similar?
  5. #104
    Dec 2007
    nelspruit
    Thanked: 109
    Quote Originally Posted by TJWM View Post
    Ek het ook die Totai 5L gas geyser oorweeg vir R1795, want ek het reeds water tenk, gas en 12V water pomp op trailer, maar sy gas verbruik van 1.26kg per uur is vir my hoog. Ek ry 'n totaal van 8kg gas saam.
    Attachment 579863
    https://ecodepot.co.za/products/tota...BoCMTEQAvD_BwE
    Het iemand ondervinding van die Alva Portable water heater. Dis bietjie duurder teen R2195, maar kom met sy eie water pomp, en ek sien sy verbruik is slegs 287 gram per uur wat vir my meer sin maak.
    Attachment 579864
    https://ecodepot.co.za/products/alva...RoCPfMQAvD_BwE
    Ek besef ook dat hie Alva baie minder warm water gaan lewer as die Totai, maar mens gebruik mos maar wat beskikbaar is en as dit voldoende is dan maak hy vir my meer sin. Sal dus graag wil hoor van mense wat dit besit, of weet waar ek dit kan toets in Kaap omgewing, want Ecodepot hou nie voorraad aam nie so mens kan nie by hulle gaan demo nie.
    Dew hot geyser:0.8 kg of gas
    300lt of water /hour
  6. #105
    Jan 2018
    ellisras
    goeie dag menere / dames
    Die kraan van die opwasbak in my explorer het nou vir die tweede maal gegroet
    het vanoggend geskakel en hulle vra R1700 vir n nuwe ( meer as die paaiement wat ek maandeliks op die karafaan betaal )
    Is daar iemand met soortgelyke probleem of weet iemand van goedkoper alternatief ?
  7. #106
    Thanked: 598
    2 x 2l Coke Bottles with Nozzle Holes in the caps I have found to be the most reliable and efficient and LEAST costly by far
  8. #107
    Dec 2007
    nelspruit
    Thanked: 109
    Quote Originally Posted by jacquesd View Post
    Stuur n foto laat ons kan sien hoe hy lyk,daar is altyd n plan
  9. #108
    May 2017
    Thanked: 1159
    ZS1ETphonehome
  10. The Following 2 Users Say Thank You to EHoffmann For This Useful Post:
  11. #109
    Nov 2006
    Lonehill
    Thanked: 498
    Nice but at $149 for essentially a plastic tank and a shower fitting is crazy.
    BruceT
    ZS6EBT
    Defender 130 Puma
  12. #110
    May 2017
    Thanked: 1159
    I am not even sure it's nice. There is a reason for sharing tho.
    1 - so you can see what to buy.
    2 - so you can see what not to buy
    ZS1ETphonehome
  13. The Following User Says Thank You to EHoffmann For This Useful Post:
  14. #111
    Nov 2006
    Lonehill
    Thanked: 498
    Quote Originally Posted by EHoffmann View Post
    Haha thank you for sharing anyway. All these different products do spark ideas
    BruceT
    ZS6EBT
    Defender 130 Puma
  15. The Following 2 Users Say Thank You to BruceT For This Useful Post:
  16. #112
    Wartburg
    Thanked: 1767
    "The Day Tank™ takes the hassle out of manually pressurizing water by conveniently absorbing the water pressure from your house. Simply plug your garden hose into the tank’s quick connect and your Day Tank™ will automatically pressurize as it fills."
    For self pressurising, you need to fill it under pressure. So not really for camping if you have no other means of pressurising it.
    I assume that it is pressurised by compressing the existing air in the container. As you use up the water, the pressure will get less and less, until you just have a trickle at the end.
    Mike Lauterbach
  17. #113
    Jun 2015
    Thanked: 66
    Morning everyone,
    So after reading and having a look at what some guys have, I came up with my own idea. Some of you guys have great setups, but none here had what I had in mind and I asked a couple of questions and did not get the answers I was really looking for.
    My current setup is a simple pot to warm the water and then wash. This got me thinking. I wanted something to heat up as quick as possible, it must be portable, no 12v cables, no electric pumps, nothing, must be durable and I wanted to heat it once and get two showers from it, so from a single heat, my wife a I need be able to shower. Simple enough for Tracy to use, portable and light weight for transporting and must pack easily.
    So, off I went, bought the following:
    1x 20L JERRY CAN
    2 X TYRE VALVES
    1X HOSE (2.5M X 12.5MM)
    1 X SHOWER HEAD
    1 X BICYLCE FOOT PUMP
    1 X SPOUT
    Below is the end result. I timed it, within 10 min I boiled 10L of water, added 5L of cold water and had 15L of warm water to shower with. I need to tweak it a bit to minimize the water flow and maybe add a double barrel foot pump.
    Comments welcomed
ID:	582926   Click image for larger version.
ID:	582927   Click image for larger version.
ID:	582928   Click image for larger version.
ID:	582929   Click image for larger version.
ID:	582930   Click image for larger version.
  18. The Following 4 Users Say Thank You to Tall Paul For This Useful Post:
  19. #114
    Wartburg
    Thanked: 1767
    Very nice. For flow rate, add an inline valve - not sure if Gardina has one?
    I would also add protection for your tyre valves - they are bound to get damaged sticking out the side.
    Mike Lauterbach
  20. #115
    Jun 2015
    Thanked: 66
    I would also add protection for your tyre valves - they are bound to get damaged sticking out the side.[/QUOTE]
    I brazed it in such a way that when it is fastened to the Jerry can holder on the side of the car, it faces inwards towards the window. No damage when in transport and nobody can fiddle with it when unattended.
  21. #116
    Thanked: 973
    Quote Originally Posted by Tall Paul View Post
    Morning everyone,
    1x 20L JERRY CAN
    2 X TYRE VALVES
    1 X SHOWER HEAD
    1 X SPOUT
    Comments welcomed
    Very nice! Why 2x valves?
    12 Conqueror courage
    Dawie van der Merwe
    If you fail to plan, you plan to fail.
    A goal without a plan is just a dream.
  22. #117
    Jun 2015
    Thanked: 66
    Quote Originally Posted by LandyLove View Post
    Thanks.
    One is for adding the pressure. The other on only acts as a outlet for the steam build up when heating. Once the water boils, I put the cap back on.
  23. The Following User Says Thank You to Tall Paul For This Useful Post:
  24. #118
    Thanked: 973
    This weekend I finally started to get the geyser setup in the conqueror sorted. I have a Cadac Celsius geyser that came with the trailer. Couldnt get it working so I took it in to our local gas shop and they replaced some safety valve. In the meantime I decided to fit the Kexin geyser I got 6 years ago and never installed. It will be portable so that it can work with the trailer or vehicle only. Basically the geyser fits in a jerry can holder which I cut the bottom out to allow access to the plumbing. Solid backing and a cover / footing at the bottom. I will get fittings today and the footplate bent. I will post pics after painting it.
    Only snag I might have is that the Kexin is 6lt/min. My pump is 3.8lt/min. I hope it can supply enough flow to keep the geyser on..... I will know tonight.
    The cadac is up for sale should anyone be interrested.
    Dawie van der Merwe
  25. #119
    Wartburg
    Thanked: 1767
    I would be more worried about damage while lugging the can around in the campsite, or it accidentally falling over. But it is a nice simple concept, and you can also heat up your water by placing the can next to your evening fire.
    Mike Lauterbach
  26. #120
    King Williams Town
    Thanked: 1176
    Very neat idea to pressurize container. I made a diff oil filler by pressurizing a spray paint gun resevoir using a tyre 12v electric tyre compressor . Oil only flows when electric tyre compressor is on and does not over pressurize the container causing an accident. I know you said you avoiding 12v but check out my idea. https://youtu.be/2Xn0sEyrWdQ
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
