Camping Shower and Pump - Page 4
Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 61 to 80 of 171
  1. #61
    Apr 2019
    Thanked: 872
    Default Re: Camping Shower and Pump
    Quote Originally Posted by Tall Paul View Post
    You're going to use an awful lot of matches with that approach, and you best hope the wind is calm and your fingers well calloused.
  2. #62
    Clanwilliam
    Thanked: 24
    Was nice to read through this thread. Some ingenious ideas.
    I have also used most showering methods through the years.
    Started with the black solar bags with shower head. Works fine in summer when sunny but obviously a no no in winter or cloudy days.
    The pot with the 12v submersible pump is but far the most cost effective method with a high predictable outcome. I still have many friends and family that use this method even though they can afford better.
    Personally the easiest and nicest unit was the Hansen geyser. For ease of use not many come close. You can run it on 220v before you leave home and when you arrive at camp or even next to the road you have hot water by just turning the tap. When you arrive at your destination you can then choose between 220v (if available) or gas.
    Of Course this "luxury" does come with quite a bit of weight and size and its definitively not the most economical on the gas.
    I now have a 6l/min small gas geyser fed by a shurflow pump. And after playing a bit with the settings I can now pretty easily create warm water on demand with minimal effort.
    All of them work.
    So it just depends on your space, funds and the effort you are willing to go through.
    Thanks for the interesting thread.
  3. The Following 3 Users Say Thank You to HiluxRoux For This Useful Post:
  4. #63
    Jun 2015
    Thanked: 66
    Just some tongue in cheek. This thread has been one I have been following from the start. Some very good ideas and some well kitted guys out there. I think this thread has covered most questions for a lot of us looking for ideas and guidance. At the end of it all, we all know, when the wife has nice warm water to shower/wash with makes for a better time than without
  5. #64
    Apr 2019
    Thanked: 872
    As was mine - I thought your post was quite funny considering the complexity of some of our contraptions.
  6. #65
    Ellisras
    Thanked: 688
    Out of curiosity, if the situation does not allow you to plug into 12v, do you have an extension, or what do you do, also this question is for all the others that need access to 12v in order for the shower systems to operate?
    I have various plugs on my trailer and Patrol. Plus I have 7Ah loose battery that I can connect at leisure...
    Rudolf Ras
    2000 Patrol GU 4.2D(onkey) "old-timer" and wise at 851 000 km
    2014 Patrol GU 3.0CRD "teenager" in puberty at 111 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" at 124 000 km
  7. #66
    Nov 2006
    Lonehill
    Thanked: 498
    I assume by extension you mean for 220v?
    If 220 is available then more than likely there will be showers available.
    BruceT
    ZS6EBT
    Defender 130 Puma
  8. #67
    Apr 2019
    Thanked: 872
    Maybe Iím paranoid ó I prefer own shower even with good ablution available. I set our shower on the Companion, even when parked next to ablution.
  9. The Following User Says Thank You to heyyahhey For This Useful Post:
  10. #68
    Jun 2015
    Thanked: 66
    No 220V
    If I may give a scenario:
    So you are out in the wild, but a designated campsite. The other sites are taken up by other campers, you can only use your shower pump off the 12V socket, but are unable to shower in the immediate surrounding of your own site, how do you get access to the 12V supply to run the pump needed for the shower or having to connect the gas to the geyser? However, there is a man made shower area/cubicle in the campsite or maybe just nothing at all. This is probably a unlikely situation as most people have cubicles, Just putting the question out there.
    Just playing devils advocate, no signalling out of anyone's setup.
  11. #69
    Ellisras
    Thanked: 688
    No 220V
    That's what the cheap loose 7Ah 12V battery is for
    Such as :
    https://www.batteryexperts.co.za/shop/12v-7ah/
    It weighs only 2kg
    Rudolf Ras
  12. The Following User Says Thank You to Dungbeetle For This Useful Post:
  13. #70
    Jun 2015
    Thanked: 66
    Thanks Dungbeetle,
    Being so small and compact, should not be any issue packing this for safety sake.
  14. #71
    Nov 2006
    Lonehill
    Thanked: 498
    No 220V
    Oh right. Ive never had that situation but i think most will have a cubicle of some sort that they would use close to the power source or portable power. I have just purchased an Eezi Awn Cube for showering and changing in when needed. Its an awesome bit of kit and so easy to setup.
    BruceT
    ZS6EBT
    Defender 130 Puma
  15. #72
    Thanked: 297
    [QUOTE=hbannink;4426636]Still baffled by how they got the hot and cold water ti stick to their own side of the pipe
    Different density as in the different colours in the Amazon at Manaus.
    Roberto Forbes
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
  16. #73
    Jun 2013
    Thanked: 2700
    Our setup is
    Pop up shower tent
    48 amp portable aux battery (we can charge via the car or solar)
    Shower pump and head
    https://www.takealot.com/kaufmann-po...v/PLID51793215
    I remember going to Khama Rhino one Jan. The ablutions were filthy and full of mozzies. So even there we got to use the set up as it was far more sanitary than the ablutions.
    Stranger
    BMW R1200R
  17. #74
    Jan 2015
    Witbank
    Bruce, a few important things to bear in mind.
    1. What is your water carrying capacity.
    2. How long trip do you need to cater for with this amount of water.
    3. Means to keep track of your water consumption.
    Although the gas type geysers is nice it is difficult to keep track of water use. For short trips they work well or where you can refill water regularly.
    For extended trips we use the 12v submersible pump setup with a 4.5 liter chlorine bottle. it is easy to keep track of water use and the long upright chlorine bottle makes it easy for the pump to suck up most of the water in the bottle.
  18. The Following 3 Users Say Thank You to Poena Minnaar For This Useful Post:
  19. #75
    Langebaan
    Thanked: 48
    This works for me in the sticks..... Just shorten the nozzle pipe, half fill with cold water and add some hot water to get the temperature right.
  20. The Following 5 Users Say Thank You to RiaanJ For This Useful Post:
  21. #76
    Nov 2006
    Lonehill
    Thanked: 498
    Quote Originally Posted by Poena Minnaar View Post
    I have about 140 ltrs carrying capacity. 80 grey water and 60 drinking.
    BruceT
    ZS6EBT
    Defender 130 Puma
  22. #77
    Ellisras
    Thanked: 688
    Me and Swambo
    - Echo Trailer 100 L
    - Patrol : if need be 4 x 25 L drums behind front seats on floor - they fit upright easily in all that leg-space
    Total 200 L - once done 12 days trip without taking any on along the way, there was a little left.
    Rudolf Ras
  23. #78
    Nov 2006
    Lonehill
    Thanked: 498
    Oh ja I didnt think about the jerry cans I can add to that total. So say 100 ltrs on top of that in jerry cans although Ive never carried that much. Drinking water I usually add a few 5lr containers in when necessary also.
    There are always, rivers, garages, tanks etc to fill up from.
    BruceT
    ZS6EBT
    Defender 130 Puma
  24. #79
    Jul 2015
    Garsfontein
    Thanked: 162
    I use my Kariba K2 shower/cooker. Circulate water through the geyser into a 20l jerry can until hot enough to shower. Then use a normal 12v shower.
ID:	578849   Click image for larger version.
    Flip le Roux
    2012 Fortuner D4D 4x4 Auto
    2016 Jurgens Exclusive
    2014 BMW R1200RT
    2016 BMW F800GS ADV
    2016 Kia Picanto - Swambo
    2019 2.2 Ranger D/C XLS 4x4 Auto - Work
    GP0015
  25. The Following User Says Thank You to Riekielouw For This Useful Post:
  26. #80
    Thanked: 596
    Not having a car and 12V means I don't have to shower Don't know of many cars and campers that won't have a battery in the car or then a loose remote smaller one at mentioned. I always use a small battery for my camping/braai LED lights. It is just part of my kit.
