National Luna Weekender - 220V not working (KZN)
Results 1 to 14 of 14
    DBN
    Question National Luna Weekender - 220V not working (KZN)
    Hi All,
    Looking for a referral to have my National Luna Weekender looked at.
    The 12V side works fine, but the 220V side does not work
    On 220V (OEM cable and using various wall sockets) it starts up, and then shuts down (and repeat...).
    Based in Westville/Durban - where can I take it to have it looked at by competent people?
    Cheers,
    Jimny, the force awakens.
    Feb 2007
    Umdloti
    Thanked: 560
    Default Re: National Luna Weekender - 220V not working (KZN)
    Casey Services in Durban north should be able to assist.
    Dec 2007
    nelspruit
    Thanked: 109
    Your controller is faulty. Look down to the probe thread. Replacement only way R3500.00. This is a National luna illness. What happen to other brands with Danfoss compressors.
    DBN
    Quote Originally Posted by RobH View Post
    Great, thanks.
    DBN
    Quote Originally Posted by bertus View Post
    That is a rather unfortunate illness.
    Thanked: 370
    Is the controller the panel where one switch on and adjust the temperature?
    2006 VW Touareg 4.2 V8 Auto
    2000 Disco 2 GS 4.6 V8 Auto
    2013 Wildebeest Kalfie Boswa
    2002 Audi S6 4.2 V8 quattro
    2013 Freelander SD4 (SWAMBO)
    ORRA Z07
    Thanked: 1069
    I thought the Luna's had fused 220V input sockets?
    Dec 2007
    nelspruit
    Thanked: 109
    Quote Originally Posted by TwinDisco View Post
    No it sit on the side of the compressor. Google Danfoss bd35 compressor. I think the new company that took over is secop. The controler make the 220 12v and then a 3phase are generated to drive the compressor
    Attached Files Attached Files
  9. The Following User Says Thank You to bertus For This Useful Post:
    Mossel Bay
    Check the earth wire,that sorted out the same problem as yours on my unit.
    Feb 2013
    Thanked: 495
    Yes, they have a fuse on the 230V socket as well as the 12V socket.
    Thanked: 1069
    So the question must be asked, has the fuse on the 220V supply been checked?
    Feb 2013
    Thanked: 495
    No harm in checking it anyway, though OP said it does turn on if on 230V but then switches off again.
    Thanked: 1069
    Ah, missed that .
  15. #14
    Jan 2009
    Thanked: 42
    Mine sometimes does this if both 12V and 220V connected.
    If just one connected it works fine
    Willem Louw
    Toyota Hilux D/C 3.0 D-4D 4x4, Full OME suspension, African Outback Alu-Top, Dual Battery, DIY Drawer System, National Luna 50L
    Venter Offroader Trailer
