4WD Rally conversion
Results 1 to 20 of 36
    May 2007
    Here, There, & Every Where
    Default 4WD Rally conversion
    Hi guys.
    Want to find out if anyone may know who can do a 4WD conversion on a hatchback to convert it into a Rally Car?
    You don't need eyes to see...
    You need vision.
    Thanked: 14240
    Default Re: 4WD Rally conversion
    Not possible without significant fabrication. Go find Project Binky on Youtube.
    I'd start with a 4x4 hatchback and make a rally car.
  3. The Following 2 Users Say Thank You to jelo For This Useful Post:
    Ruimsig
    Thanked: 11996
    Which hatchback and what is your budget?
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
    KEMPTON PARK
    Thanked: 328
    why not start the project with a Subaru, its 4 wheel drive , good base as a rally car . go from there , think to try and convert to 4x4 could be costly . It can be done , but you could also need a dump truck full of cash to do so. anything is possible , but some is just way easier and cost effective . platform that work , makes it easy to get done .
    05 TJ SAHARA
    08 3.8 JK ULTD RUBICON
    Thanked: 14240
    Maybe Reenen can do the conversion.
    FrankenHatchback.
    Thanked: 2264
    Maybe buy one of these as a base to start with...
    My name is Rainier and I drive a Frotuna.
    Why are you always in such a bad mood? Experience...
    Thanked: 14240
    Quote Originally Posted by Rainier Vermaak View Post
    Those must be going for a fair amount of cash these days?
    What about the Audi Quattro?
    Thanked: 2264
    Like this?
    Thanked: 732
    I know at a stage a private person could buy from VWSA Motorsport, don't know what the current situation is.
    (But I did found this:
    https://volkswagen-motorsport.com/en/rally
    190K Euro + VAT )
    Thanked: 229
    I'm sure with enough time and money that could compete in a rally
    Thanked: 14240
    Like this?
    yep, the Lancia's nemesis
    Thanked: 2264
    Quote Originally Posted by Wicd View Post
    I believe one or two were used in local/regional rallies around the world.
    Ruimsig
    Thanked: 11996
    You would need a Bar and some for the Lancia these days.
    Hummer H3 V8
    W.A.P Objectivist
  15. #14
    Jun 2016
    Randfontein
    Thanked: 2324
    Willie
    2020 Nissan NP300 2.5TDi S/C
  16. The Following User Says Thank You to FWM For This Useful Post:
  17. #15
    Ruimsig
    Thanked: 11996
    Ideally, one would need an AWD system that allows for a split front-rear to be dialed in, like Subaru. Next best would be a selectable AWD like that on a Jeep Patriot.
    If the conversion is going into a Golf body for example, then a donor system would be required. This would require some body modification unless you take the floorpan from the one and mount the body of the other on it with still lots of measuring, cutting and welding as well as reinforcing required. The elektronickery could be problematic. Then the mating of the original engine to the transmission and associated peripherals.
    If its for competition purposes then you could run into problems in meeting a category formula/requirement.
    It could easily end up as a R1 million project on a R30k car. But hey, if you have the dosh and thats what you want to do, then go for it.
    Hummer H3 V8
    W.A.P Objectivist
  18. #16
    Jun 2016
    Randfontein
    Thanked: 2324
    Or maybe a Suzuki Sx4 awd. Some big rally history there as well
    Willie
  19. #17
    Robertson/ Larissa, Greece
    Thanked: 3377
    Quote Originally Posted by Acrorellik View Post
    Hi guys.
    I've been out of the game for too long now, so don't know anyone off hand. I don't know where you reside, but would make contact with those in the racing fraternity and state your requirements. Guys like Glynn Hall and the late Own Ashley or Hennie vd Linde used to be the go to guys. Even Hannes Grobler.
    I don't know the younger generation, but visit the nearest racing circuit.
  20. #18
    Thanked: 262
    dont some people just use an AVIS car.
    Robbie
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
  21. #19
    Jan 2011
    Thanked: 61
    Quote Originally Posted by Robbief View Post
    Not only the best offroad vehicle, but also the best rally vehicle there is.
    Toyota Hilux 2.7i
  22. #20
    Kuilsrivier
    Thanked: 135
    Just for a toy/project or would you like to race it officially?
    First one is easy, 2nd one is eye-watering expensive!!!
    There is some local builders that will build you the complete car.
    Make sure you know the regulations before you even start
