Wire thickness for inverter.
Results 1 to 10 of 10
    Aug 2018
    Paarl
    Thanked: 75
    Default Wire thickness for inverter.
    Hi what wire thickness will be sufficient to run from battery to my 1000w inverter.
    About 500mm in length.
    Thanked: 1269
    Default Re: Wire thickness for inverter.
    I'd say to draw 1000W from a 12 V battery requires 80 Amps.
    As per below, you'd need a cable of 7mm diameter.
    But let's wait for the elec fundis to give you the correct answer.
    See here:
    https://youtu.be/KSYAqQ4xyJI
    Aug 2018
    Paarl
    Thanked: 75
    See here:
    Never going to run 1000w maybe at the most 350w.
    Was looking at 4sq not sure if it will work.
    Friemersheim, Southern Cape
    Thanked: 3253
    Just run 16mm sq from battery to inverter.
    Mar 2011
    Florida
    Thanked: 28
    16 mm - voltage drop < 2%.
    Aug 2017
    Durban or Centurion
    Thanked: 1268
    Quote Originally Posted by fatbike View Post
    4mm2 will be good for up to 40A or 500W
    Thanked: 192
    Running a thicker cable will result in less heat and less resistance over the cable.
    It won't hurt to put in a thicker cable at all.
    2018 Ranger DC 2.2 XLS Auto 4x4
    Canon 5DMkIV with L-goodies.
    Thanked: 538
    See here:
    Although 7mm might be the size to use one cannot get the cable or lugs.
    Rather use 16 Sq mm and you can use whatever you need to power from the 1000W the inverter can supply. It is only 1m in total to buy. Also no real gain to start using 35 50.or 70mm welding cable.
    King Williams Town
    Thanked: 1116
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Feb 2013
    Thanked: 383
    I agree, since you are looking at only buying a meter, go for 16mm and be done with it, rather spend R100 more now than having to worry about heat and other stuff later.
  11. The Following User Says Thank You to bigboy529 For This Useful Post:
