Results 1 to 20 of 36
    Oct 2008
    East Rand
    Thanked: 80
    Default Show your Two Way radio and Arial setups
    Hi Gentlemen
    Busy purchasing myself a Two Way radio. Thought it well to start a thread where guys share some pics of where they mounted the two way radios and aerials.
    Please also share tips on what you found worked well.
    Disclaimer : Attached pic merely an example
    To Operate Your Own Terrific Automobile AKA TOYOTA
    Oct 2008
    East Rand
    Thanked: 80
    Default Re: Show your Two Way radio and Arial setups
    No setups?
    Jan 2015
    pretoria
    Thanked: 420
    Janee dis sad, gehoop die manne wys hul radios....wil ook een aanskaf. Uitgesien na wenke en raad.
    Thanked: 1346
    My radio is fitted to the side of the center consul on the Disco and the additional speaker is mounted to the overhead panel. It's small and far forward enough to not be in the way of my leg while driving. I have moved the mic bracket up onto the dash as it did get bumped by my leg now and again.
ID:	576819   Click image for larger version.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  5. The Following User Says Thank You to Paul#25 For This Useful Post:
    Thanked: 1346
    Forgot to mention the antenna setup I have. My Disco 2 had a hole in the roof aft of the second sunroof that had a plastic plug fitted in it. It turns out that is where the optional SATNAV antenna would be fitted if that option was installed. I removed the plastic plug and fitted the antenna to this hole with the coax cable running above the headliner along the standard wiring looms to the right "A" pillar and then down into the dash. I get slightly further comms in front of the Disco compared to the sides and behind but still get 15km to 20km reception and transmission depending on terrain.
    2004 Disco 2 Td5
    VW Touran 2.0Tdi
    Oct 2017
    Rustenburg
    Thanked: 7732
    My little RTS unit works a treat and fits snugly in a place that seems like it was made for it.
    Andrew van Staden
    =Anti Lockdown Activist=
    2021 FJ Cruiser
    Thanked: 1024
    Centre console to the left - Kenwood UHF NX800 Digital
    Centre console in the middle - Kenwood VHF TK7360H
    Behind the back seat - Kenwood HF TK90
    Right C pillar - UHF antenna
    Left C pillar - VHF quarter wave antenna
    Rear bumper - HF antenna coil, the antenna self only gets screwed in when taking a looong trip as it frustrates low flying planes.
    Oh yes and then I have an ATU for the HF in the load bin which I don't have a photo of now.
    Comms sorted.
ID:	576839   Click image for larger version.
ID:	576840   Click image for larger version.
ID:	576841   Click image for larger version.
ID:	576842   Click image for larger version.
ID:	576843   Click image for larger version.
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
  9. The Following User Says Thank You to Die SwartKat For This Useful Post:
    Klerksdorp
    Thanked: 599
    I don't have any smart pics, these were what I could find stored in my PC from a long time ago.
    Vehicles are as listed below in my signature, then the Motorola HAD Rooftop antenna, a Zara60 pillar mount antenna and a couple of antenna mounting brackets.
    -F_D
ID:	576859   Click image for larger version.
Name:	Hilux, 2.7i 015 Resize 500.jpg
ID:	576860   Click image for larger version.
Name:	Repcom Radio in Hound Dog (R).jpg
ID:	576861   Click image for larger version.
ID:	576863   Click image for larger version.
Name:	Pradog with HAD4006.JPG
ID:	576864   Click image for larger version.
Name:	Zara60 Pillar Mount.jpg
ID:	576865   Click image for larger version.
Name:	ST700 Boot Mount with 20mm hole.jpg
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
    Thanked: 66
    Amarok under seat instalation , mainly with velcro that sticks to carpet. Easy drill free instalation
ID:	576891   Click image for larger version.
ID:	576892   Click image for larger version.
ID:	576893   Click image for larger version.
ID:	576894   Click image for larger version.
    VW Amarok 3.0
    Invader duo
  12. The Following User Says Thank You to Oswald For This Useful Post:
  13. #10
    Thanked: 977
    I am considering the under seat mounting, is it not a hassle changing channels?
    or is channel hopping not really something you do?
    12 Conqueror courage
    Dawie van der Merwe
    If you fail to plan, you plan to fail.
    A goal without a plan is just a dream.
  14. #11
    Pta
    Thanked: 125
    Quote Originally Posted by LandyLove View Post
    Normally you pick a channel and stay on that channel.
    It does happen sometime that you get closer to another group and they are on the same channel. And then you want to move to a different channel. But that doesnt happen a lot. I normally just ignore them. Listen to what they say. 5 min and you are out of range and you alone on the channel again
  15. The Following User Says Thank You to renier_c For This Useful Post:
  16. #12
    Wartburg.
    Thanked: 708
    Some of mine.
ID:	576931   Click image for larger version.
ID:	576932   Click image for larger version.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    ZS5CL
  17. #13
    Thanked: 66
    Channel hopping and volume setting is not possible for the driver while driving but manageable for the passenger .
    VW Amarok 3.0
    Invader duo
  18. The Following User Says Thank You to Oswald For This Useful Post:
  19. #14
    pta
    Thanked: 46
    Please excuse my lack of knowledge of this subject, but do i need a HAM licence to run these types of radio systems?
  20. #15
    Thanked: 977
    Quote Originally Posted by bobscratchit View Post
    You need a licence yes. You can get one on the forum.
    Dawie van der Merwe
  21. #16
    Oct 2017
    Rustenburg
    Thanked: 7732
    Yes, but you don't need a H.A.M. licence. The one you need for these VHF's are actually just a permit.
    Andrew van Staden
    2021 FJ Cruiser
  22. The Following User Says Thank You to Hedgehog For This Useful Post:
  23. #17
    Apr 2018
    JHB
    Thanked: 202
    I've noticed online and by the pictures posted so far that we have really cheap antenna. Is there no company in SA that makes decent antenna like the ones in AUS? Those won't snap at the first branch it sees.
    2018 Suzuki Jimny - Expedition vehicle
    2002 Land Rover Defender - Daily Drive
  24. #18
    Oct 2017
    Rustenburg
    Thanked: 7732
    Quote Originally Posted by Sheldon93 View Post
    The Aussy ones are for UHF, and they are more prone to snapping than a shorter VHF. generally our VHF have longer ranges than their UHFs, even with the shorter antennae. And being shorter and solid, I cannot see why you would say that they snap? In the 5 years I have had mine, going through a lot of rough brush causing all sorts of pin stripes to my vehicles I have never had my VHS arial snap.
    Andrew van Staden
    2021 FJ Cruiser
  25. The Following User Says Thank You to Hedgehog For This Useful Post:
  26. #19
    Thanked: 1024
    Since taking up this hobby in 2002, I have had radios in all my vehicles and I have never ever experienced snapping of a radio antenna. And I have done a fair amount of bushwacking.
    You would have to bundu bash and drive like a maniac to accomplish this and something else on your vehicle is much more likely to break before an antenna. That said, what happens from time to time is that you may lose the whip, as this is only held in place by 2 - 3 grub screws. But only with serious bundu bashing.
    As Hedgehog said, no HAM license is required. You just need to be a member of a registered club (like this forum) and you can apply for a license.
    Nico Swart
    ZS6NJS
  27. #20
    Klerksdorp
    Thanked: 599
    Post Re: Show your Two Way radio and Arial setups
    The Aussy ones are for VHF, and they are more prone to snapping than a shorter VHF. generally our VHF have longer ranges than their UHFs, even with the shorter antennae. And being shorter and solid, I cannot see why you would say that they snap? In the 5 years I have had mine, going through a lot of rough brush causing all sorts of pin stripes to my vehicles I have never had my VHS arial snap.
    I think you meant to say the Aussie ones are UHF, so yes, they are much shorter than the VHF ones. The length of the whip is dependent upon the operating frequency of the radio. For VHF purposes, you could use the locally made 5/8 antenna, which is around one metre long but for the forum VHF frequencies you should really use the 1/4-wave VHF antenna, which is under 500mm in length. The whips are made of spring steel and they do not snap easily.
    -F_D
    White Fang:
  28. The Following User Says Thank You to Family_Dog For This Useful Post:
