New tyres fitted - floaty movements
Results 1 to 10 of 10
    Aug 2010
    Thanked: 117
    Default New tyres fitted - floaty movements
    I changed tyres recently from the Wrangler AT/SA to the Wrangler Adventures
    By all accounts, the newer adventure tyres are smoother, quieter, better ride.
    Have not taken them offroad yet
    However, ever since fitting the new Adventures (which has very good reviews), the car tends to float abit on the road, when turning or taking a curve. It's quite disconcerting.
    Just slight movements of the car when taking a curve, almost as if a wheel or nut could be looseI've checked tyre pressure and they at 2.1 bars, my normal for City driving
    Any other tips or things I could look at perhaps?
    Freelander 2 i6 SE - loveeee iitttttt!
    650 V Strom - my trusty beast
    Honda XR400R - wanna play......
    Vespa - when you just have to be cool 8)
    GT Expert and Giant Anthen MTB's - keeping the tummy in check
    Thanked: 14198
    Default Re: New tyres fitted - floaty movements
    Check the load rating on the new tyre. A lower load rating implies a softer sidewall which will cause the effect you are experiencing.
    Feb 2016
    Thanked: 876
    2.1 bar seems low for tar, the floattiness you experience could be the tyre's sidewall flexing.
    try upping it to 2.4 and see if that makes a difference?
    Aug 2010
    Thanked: 117
    will check the load rating
    My gut says softer sidewall but this make me very nervous when out in the Tankwa with the family
    2.2 bar is the recommended pressure for most activities for my vehicle, including towing - will do the 2.4 and experiment
    Feb 2016
    Thanked: 876
    If 2.2 is recommended for your car, then try 2.3 and assess, then go down to 2.2 and re-assess.
    Thanked: 1029
    Have you actually checked that they did tighten all the wheel nuts?
    I have had a wheel fall off on me in a corner due to technicians at a tire place cross-threading three quarters of my wheel nuts...
    Nov 2006
    Thanked: 432
    I agree with the 2.4 suggestion.
    Had the same feeling on two vehicles with the Wranglers and it was corrected by increasing pressure to 2.4bar.
    When I carry an overlanding load or tow something I reduce the front to 2.2 and increase the back to 2.8 or 3.
    If you live each day as if it was your last, someday you'll most certainly be right. SJ
    Barberton
    Thanked: 1269
    To the OP:
    I assume wheel alignment was done when new tyres were fitted. This can also change the feel. I have experienced this in the past.
    Aug 2010
    Thanked: 117
    Thanks for the replies
    The alignment was done at fitting, and all wheel nuts I checked personally
    I'm going 2.4bar and see
    Aug 2010
    Thanked: 117
    Quote Originally Posted by Damdan View Post
    Thanks for this tip - I occasionally tow a caravan and will try this
