Defender Windscreen Wipers
Results 1 to 3 of 3
    Napier
    Thanked: 41
    Default Windscreen Wipers
    Has anyone tried fitting 14 inch wipers on the front window of the 110 Defender?
    The 13 inch are a little small in my opinion and it looks like a 14 inch will fit in its place - lots of room.
    Babushka - 3.5 V8 Defender Highline
    SWAMBO - 1.6 Nissan Livina X-Gear
    Feb 2016
    Thanked: 873
    Default Re: Windscreen Wipers
    Quote Originally Posted by DSouter View Post
    I switched to the Bosch AeroTwin and they are simply amazing compared to the originals.
    I'm not sure the 14" ones will fit, but you can try.
    https://photos.app.goo.gl/195fpEkG5FPmgQvA9
    Thanked: 14172
    Go get a set of Midas cheapies and try it. The worst you might need to do is trim some rubber where it touches the windscreen frame.
