Forester sucking dust
Results 1 to 20 of 20
    May 2015
    Thanked: 71
    Default Forester sucking dust
    I did a few hundred kays of very dusty roads and the inside of my Forester (2020 2.0) is covered in a layer of dust. Anyone else experienced it? I could see clear dust lines on 3 of the doors rubbers where it appears to have taken it in. Any idea on how to appreach the matter with the dealer?
    Lonehill, JHB
    Thanked: 955
    Default Re: Forester sucking dust
    They can easily adjust the latches to make a tighter fit, just have a chat with them.
    2014 Pajero 3.2DiD SWB
    Thanked: 287
    Do you use the Forester's air conditioning function on recycle or fresh air?
    May 2015
    Thanked: 71
    Thanks I have to say the buying and ownership experience was great so far and I am sure it will continue from the dealerís side. Just wanted to see if itís common and or at least fixable
    May 2015
    Thanked: 71
    Recycle. Worst is on the side plastic of the rear foot wells where you could clearly see is a entry hot spot
    Thanked: 296
    Driving on dirt roads with windows closed and vents on recirculation ? Iso intake from outside and fan on ?
    Old problem.
    Thanked: 287
    This is the problem. You need to get fresh air into the car. On recycle the cabin tends to be at lower pressure than outside and sucks dust through every little crack. Especially the back doors.
    Put it on fresh air and at higher fan speed than normal. You pressurise the cabin slightly and the dust will be a lot less.
    Quote Originally Posted by Dwerg View Post
  8. The Following 2 Users Say Thank You to Tom13 For This Useful Post:
    Thanked: 2920
    Always use from fresh on dusty roads.. Never recycle. It applies to any vehicle. You have to maintain cabin pressure
    Dum vivimus, vivamus!
    May 2015
    Thanked: 71
    Quote Originally Posted by janseekat View Post
    Old problem.
    Everything closed, circulating and heater on mild
    May 2015
    Thanked: 71
    Ok I wouldíve thought outside air would let dust in. Thanks
  12. #11
    Jun 2008
    Terenure, Kemptonpark
    Thanked: 93
    Ag nee man, het jy alweer n dud(ktm) gekoop Dwerg??
  13. #12
    May 2015
    Thanked: 71
    Nee wat. As mens die goed gebruik om plekke te sien in plaas van net in die dorp ry gaan daar maar nou en dan goed op pop
  14. #13
    Lonehill, JHB
    Thanked: 955
    Dit is wat die pollen filter voor is
  15. #14
    Thanked: 287
    Nou gaan jy die naweek al die paaie weer moet ry om seker te maak die "vars lug teorie" werk inderdaad. Look on the bright side!
  16. #15
    May 2015
    Thanked: 71
    Dealer said the same thing about the air system. Apparently there was a bulitin about it as well although he did say mine was particularly bad
    Thanks everyone
  17. #16
    Thanked: 221
    I don't buy the fresh air etc story. My Forester is a 2006 and I have not had this issue even though I have done a lot of gravel with it. And I just leave the climate control on auto
  18. #17
    May 2015
    Thanked: 71
    Well itís on record now anyway. The road that caused most of it is close enough to ride up and down to test. Previous trip we had no issues and did 100s of kms on very dusty roads
  19. #18
    Thanked: 13630
    Quote Originally Posted by Wicd View Post
    Happens to many vehicles, not just the Forester.
    Recirc function actually causes a slight vacuum or low pressure inside the vehicle. This then sucks any available dust past the door seals.
    Weird, but a known issue.
  20. #19
    Barberton
    Thanked: 1200
    It isn't about "fresh air". It is about positive pressure inside the car. Auto setting is only likely to recirculate air for a few minutes after start-up. After that it will have the air inlet open and fan running - thus creating the positive pressure.
  21. #20
    cape town
    Thanked: 382
    sunroofs, especially in tip mode also create a vacuum effect and aggravate dust ingress.
