Engine transplant into D3
Results 1 to 19 of 19
    Mar 2013
    Thanked: 66
    Default Engine transplant into D3
    Hi.
    Just wanted to ask advice please.
    Any 2.7TDV6/4.4 V8 or TD3.0V6 engines for sale?
    How easy is it to marry the 3.0 diesel engine to the D3, or the V8 petrol for that matter taking into consideration the current D3 has a 2.7 in it.
    It is a 2008 HSE.
    ''​Luck favours the prepared man''
    Discovery 3 HSE - 2.7V6Tdi 2008 (Written off)
    Aug 2019
    Thanked: 122
    Default Re: Engine transplant into D3
    Unless you have lots of time, expertise or money it would probably be best to just cut your losses and move on. I know it's not what you asked or want to hear at this stage but this quickly becomes a bottomless pit.
  3. The Following 2 Users Say Thank You to Tiaan Pot For This Useful Post:
    edenvale
    Thanked: 227
    Quote Originally Posted by Naguiltjie View Post
    Hi.
    It is a 2008 HSE.
    In simple terms for a seamless and oem style transplant
    more money than a non runner d3 is worth
    transplanting the petrol v8 will need
    petrol ecu
    gearbox, dashboard
    can electronics marry up so new key, then new door locks if you want key to match
    the petrol ecu must have same spec as the diesel chassis and and and
    then exhaust, fuel pump, radiator, transmission cooler and loads other different items
    thats why people put a lexus v8 in and live with the complications, and putting a lexus v8 in is about 70k and it doesnt then work like a land rover, add another 35k and it gets close
    rather dont is my humble answer, there are better ways to spend hard earned rands and a converted land rover with a dead engine isnt one of them
  5. The Following User Says Thank You to 3bar For This Useful Post:
    Thanked: 14209
    Get a new sub assembly. Cheapest easiest and fastest.
  7. The Following 3 Users Say Thank You to jelo For This Useful Post:
  8. #5
    Thanked: 157
    What he said.
    Darron John Misplon
    Land Rover Discovery 2 Td5 ES Manual (Loaded)
    BMW F30 320i Sport Auto
    BMW R1200 GS
    'One life-Make a difference"
  9. #6
    Jul 2016
    Thanked: 510
    if you want to keep the vehicle a new sub directly from Landrover is the only way. Any form of repair will end in tears.
  10. #7
    Mar 2013
    Thanked: 66
    Thank you guys.
    Good advice.
    I don't have a snapped crank. Got my wheels stuck over the edge of a dam after sliding in slow motion on the brown snot due to 7 days of rain earlier this year...
    We suspect whilst waiting for someone to snatch me out, water leaked into probably the intercooler pipe and when I turned the engine it sucked up the water. The front wheels were just half deep into the water and rear wheels on land. How is that for bad luck.
    I have asked a quote from Remtec as I will need the full engine as in most probability conrods might be bent etc.
    I'll ask LR Nelspruit today what their new cost is for an engine for interest sake.
    Do you think fitting a 3.0TDV6 is viable
  11. #8
    Thanked: 522
    Thank you guys.
    That will also end in tears
  12. #9
    Jul 2016
    Thanked: 510
    Thank you guys.
    Good advice.
    the 3.0 will fit however making the electronics work is not gonna happen. If you wanna sell it as is gimme a price
  13. #10
    Thanked: 14209
    yes
    @Naguiltjie:
    Listen to MikeBob.
    He has the T-shirt. With the oil stains.
  14. #11
    Mar 2013
    Thanked: 66
    yes
    @Naguiltjie:
    Listen to MikeBob.
    Thx. Ja, one does not want to struggle with numb cold hands in the current winter...
  15. #12
    Thanked: 200
    Thank you guys.
    Good advice.
    You really only have 2 workable options, and both has the same guy involved: Mikebob!
    Either sell it to him or get him to drop a new motor into your car and drive it home.
    I have been to Mike's workshop a few times and there has been quite a few Disco's for new engines through his facility. I recon they have the basics figured out by now.
    Si vis pacem, para bellum
  16. The Following User Says Thank You to thabogrobler For This Useful Post:
  17. #13
    Thanked: 19
    The end of the D3 is near, many are now off the road as they are no longer financially viable to repair, just this week I had to inform owner that their D3 was a gooner, blown motor caused by seized turbo through the failure of cracked turbo oil pipe which another workshop had interfered with.
    Then yesterday was nearly the same issue with a D4 but this turned out saved, there again turbo feed pipe also cracked due to another workshop interfering when they replace rear belt and do other things.
    These motors are not worth rebuilding due to cost and liability of failing as many have been stung by this route
    Symptoms of the turbo pipe issue is oil leaking down the bell housing although important to confirm its not from oil cooler on top which can easily be inspected.
    The 3.0 can be fitted into a 2.7 D3 but with the turbo setup from the 2.7 D3, the V8 petrol cannot as it uses a different bell housing and Ecu's
    In the UK the D3 was sold in 2.7 or 3.0
    30 years experience and knowledge certainly out weighs a 5min keyboard bashing on google
    Love's electrickery stuff and problems related to it as long as it dont go bang cos then its f......
    NO REPLACEMENT FOR DISPLACEMENT
    A V8 is where thunder is made
    100%WEE
  18. #14
    Thanked: 14209
    Quote Originally Posted by viperover View Post
    And yet many D1s and D2s are still happily driving around. Makes one think that maybe planned obsolescence is actually real despite what many people say.
  19. The Following 2 Users Say Thank You to jelo For This Useful Post:
  20. #15
    Thanked: 19
    Indeed, D1 and 2 are great vehicle regardless of capability, not sure which D1 you have but if a petrol 3.9 and having loads of issues with the efi or motor then get a complete v8 from a D2 ands transplant, inc wiring etc, you wont regret the transplant, just depends how its all going I guess
    If you have a TDi engine in the D1 the aftermarket parts for these motors are becoming problematic regarding quality
    100%WEE
  21. #16
    Thanked: 14209
    You miss the point.
  22. #17
    Nov 2011
    Langebaanweg
    Thanked: 1190
    OT, sorry, but not much to go wrong on the Tdi and some of the problematic stuff, like lift pump and vacuum pump, can easily be replaced by electric stuff that is much more reliable.
    '07 Land Rover Defender 110 TDI 300 Kalahari (Meisiekind)
  23. #18
    Harare
    Thanked: 110
    So true Jelo. I would buy another D2 in a heartbeat. Td5 or V8.
    Having said that, 'my' old D3, American Spec, 4,4l V8, is now owned by my daughter and son-in-law, and lives in Washington State, USA. Still going strong, no mechanical issues, getting close to 300k MILES.
    Ex - 109 SIIA R6 pickup, rebuilt from a kraal find, still thrashing around in the Zim Lowveld.
    1972 88 Safari SW petrol - Mellie
    1995 Disco I 300TDi - Daisy
    Ex - 2003 Face Lift Disco II Td5 auto - d'Arcy. Now living by the sea in KZN.
    2003 Defender 110 Td5 - Bruce
    Ex - 2005 D3 V8. Still in the family in Washington State USA.
    Ex - 2007 Freelander Td4 HSE. Still in the family in Bury St Edmunds, UK
    Life is a journey. Have you determined your final destination?
  24. #19
    Harare
    Thanked: 110
    Quote Originally Posted by 3bar View Post
    petrol ecu
    gearbox, dashboard
    If the space and power of the D3 is not absolutely necessary, spend the money on a good D2, V8 or Td5. This, or a D1 are appreciating assets now...
