MTB ratchet set
Results 1 to 7 of 7
Thread: MTB ratchet set
    pta
    Thanked: 38
    Default MTB ratchet set
    I am looking for a ratchet set to obviously tighten all the hex bolts on my new mtb.
    Every hex bolt states a torque value, so instead of the kit i have on the bike tools, i want to make sure i torque the nuts correctly.
    The shops seem empty at the moment, but any suggestions?
    Many thx
    Jan 2007
    Thanked: 340
    Default Re: MTB ratchet set
    I used to go by feel and it worked pretty well. However, with carbon, I decided to buy a proper torque wrench. Got one from CWC, if I remember correctly. To be honest, I haven't really used it much, apart from tightening stem bolts.
    Loevenstein, Bellville
    Thanked: 427
    Stripping the bolt holes on bottle cage holder or brake caliper hole is no fun, believe me. I bought mine on Chain Reaction Cycles in the UK and someone brought it back for me - one of my best cycling related investments ever. The only things I don't tighten with the torque wrench are pedals.
    But as with anything cycling-related, they are expensive. You can probably buy a "normal" one from a hardware shop but make sure it can measure low enough for MTB purposes (as low as 4Nm). The added benefit of cycling-specific torque wrenches is you'll probably get the suitable range of hex and torx sockets that you'll need for working on the bike.
    Niel
    2012 BMW F800GS
    Aug 2017
    Durban or Centurion
    Thanked: 1271
    I have a couple of suitable torque wrenches. The latest one I got from Adendorffs.
    Aug 2018
    Paarl
    Thanked: 94
    This is what I use
    pta
    Thanked: 38
    i have found the LEZYNE TORQUE DRIVE which seems reasonable for the job and price,
    many thanks for ur help
    Cape Town Southern Suburbs
    Thanked: 1175
    Ice Toolz has a decent " one for around R900.
