Jeep front flickers
Results 1 to 10 of 10
    Louis Trichardt
    Thanked: 57
    Angry Jeep front flickers
    Both front flickers on my Jeep have stopped working.
    The fuse is okay and all other lights are working.
    The hazards also just flash at the rear,
    Signal lights flash faster than normal globes are okay
    Any advice would be welcome
    2003 Jeep KJ 2.5 CRD
    Default Re: Jeep front flickers
    Disconnect the battery to reset ECU and leave disconnected for about an hout for capacitors to discharge. Maybe that could solve the problem.
    2012 Jeep Wrangler Rubicon Unlimited
    Feb 2020
    Las Vegas and Minneapolis
    Thanked: 387
    Quote Originally Posted by Zoutpansberg View Post
    Both front flickers on my Jeep have stopped working.The fuse is okay and all other lights are working.The hazards also just flash at the rear,Signal lights flash faster than normal globes are okayAny advice would be welcome
ID:	574600   Click image for larger version.
    David -
    Ď20 Toyota Tacoma TRD Off Road Decal Edition 3.5L
    If your only tools are a cutting torch and hammer, all of your problems are locomotives...
  4. The Following User Says Thank You to AardvarkNV For This Useful Post:
    Feb 2020
    Thanked: 387
    Have you tried known good globes in the front or checked for power in the socket with a test light or multi-meter?
    David -
  6. The Following User Says Thank You to AardvarkNV For This Useful Post:
    Louis Trichardt
    Thanked: 57
    Yes I have no power, and the globes are good
    Louis Trichardt
    Thanked: 57
    Quote Originally Posted by nclaassen View Post
    Yes I tried, but no dice
    Saw a interesting post. See if your hazards work. If your hazards word it might be a different relay which is problematic.
    Louis Trichardt
    Thanked: 57
    Google say the flickers and hazards share the same relay
    Feb 2020
    Thanked: 387
    Disconnect the firewall connector C100 and check for power there in cavities L62 & L63, or one of the other connectors (C106 or C107) and check out the DG/RD (L turn) BR/RD (R turn) wires...
    Itís either going to be from one of those forward into the front harness, or from there back into the dash harness...
    David -
  12. The Following User Says Thank You to AardvarkNV For This Useful Post:
  13. #10
    Louis Trichardt
    Thanked: 57
    Quote Originally Posted by AardvarkNV View Post
    Thanks David will do at first light .
