Elec H2O switch for humidifier
Results 1 to 3 of 3
    Oct 2012
    jhb
    Thanked: 8
    Default Elec H2O switch for humidifier
    Hi.
    I'm looking for an electronic or otherwise level sensor that I can hook up to a solenoid / valve to control the level in our humidifiers.
    I have 6mm nylon tubing that I plan to use.
    Yes. This is plain laziness. I'm tired of filling them up.
    Any bright ideas?
    Jul 2013
    Thanked: 310
    Default Re: Elec H2O switch for humidifier
    Try this unfallable solution to refill on demand.
    Oct 2012
    jhb
    Thanked: 8
    School fees for any others....
    The water reservoirs rely on vacuum to control water level in the humidifier...
    So any release while in position makes it overflow...
    I need to full with water without breaking vacuum...
    Impossible....
