3.0 Vibration
Results 1 to 20 of 36
Thread: 3.0 Vibration
    Jul 2014
    Thanked: 827
    Default 3.0 Vibration
    I have been wondering.
    My 3.0 Tdci 4x4 supercab seems to "vibrate" a lot when sitting and idling the engine - feel it in the cab and the mirrors wobble at idle. The engine is idling at about 800RPM so its not very low, and as soon as it revs just a little bit the vibration is a lot less, also when driving all is fine but siting at a traffic light makes my fillings in my teeth come loose it feels.
    I have looked at the engine mountings and all seem (visually) OK and the engine does not move much when I pull off or under load.
    Are these 3.0's that rough since my 2.5 never vibrated this much, or should I replace the engine mountings?
    Platkar - Haaihoendaai i20 1.4]
    Ex'es
    KIA Sorento 2.5 Crdi 4x4 (diesel guzzler of note)
    Nissan Terrano II 2.7
    Mazda Drifter DC 2.5 4x4
    Toyota 60 series 5.7 V8
    Daihatsu Rocky 2.8
    Thanked: 13631
    Default Re: 3.0 Vibrator
    Also check the gearbox crossmember mounts. You can't check the stuff by looking anyway. You need a pry-bar and a hoist. IMHO.
    WAJ
    Thanked: 272
    Did it happen all of a sudden?
    Ruimsig
    Thanked: 10456
    Dont engines have a vibration balancing system?
    Remember the old Mitsubishi Colt Gallant adds with a glass of water on the rocker cover?
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
    Jul 2014
    Thanked: 827
    What I did was put a brick in front of the one wheel (since the handbrake on these old fords are useless at best) and opened bonnet and asked my brother to slowly pull away while I look and there seems to be no real movement of the engine, as I would expect when a rubber mount is tired.
    It always kinda did this since I bought it, but that was fairly recent and with all the time it spend having things fixed I did not give it much thought.
    Ex'es
    Daihatsu Rocky 2.8
    Thanked: 272
    They do. Both the 2,5 WLT and the 3,0 WEC has dual balancer shafts. I would say it works quite good, especially on the 2,5WLT.
    The 3,0WEC has additionally a dual mass flywheel to remove more vibrations.
    Since mine was locked up (cheap remedy) the engin vibrates a lot more when driven under 2500rpm.
  8. The Following User Says Thank You to Spiceman For This Useful Post:
    Ruimsig
    Thanked: 10456
    Apart from a mount becomming a bit more flexible before failing, balancing shaft issue.
    Thanks Spice.
    Hummer H3 V8
    W.A.P Objectivist
    Out of Town
    Thanked: 691
    The old Hardbody gearbox mount would collapse and go lay on the crossmember. Or if one of the engine mounts went, the whole setup up would tilt and the gearbox mount would wedge the crossmember. Both of these would cause a vibration. I got fedup with these mounts packing up every few months, and the Nissan mount was also not doing the trick. Needing to keep that setup dead accurate to insure perfect line up to my TC, I built a polly mount setup to replace the old Nissan part, and now have the same vibration. Personally will live with it knowing that my gearbox stays located where it is supposed to, preventing other problems of misalignment that could occur.
    Thanked: 272
    Thanks Spice.
    Some HiLuxes had balancer shaft issues and it was outrageously expensive to replace. A friend bought a bakkie cheap-cheap about just for the body because of that issue. He installed a 3,0KZTE engine. It could be the 2700 or the 3000d, don't know which one is the culprit.
    (I editted my post)
    Jul 2014
    Thanked: 827
    Default Re: 3.0 Vibration
    I guess I will take it to the workshop (again - this bakkie loves workshops) and have them take a look at it - I am just worried if places are not desperate for business and money after this lockdown period and make me spend all my beer money...
    Ex'es
    Daihatsu Rocky 2.8
  13. #11
    Thanked: 13631
    Why exactly did you sell that nice little Daihatsu again?
  14. #12
    Jul 2014
    Thanked: 827
    uhm
    Ex'es
    Daihatsu Rocky 2.8
  15. #13
    Jul 2014
    Thanked: 827
    Took it in today to a indie to have both engine and gearbox mountings replaced. Lets hope that sorts out the vibrator of a ford
    Ex'es
    Daihatsu Rocky 2.8
  16. The Following User Says Thank You to WAJ For This Useful Post:
  17. #14
    Thanked: 272
    I hope with you.
  18. The Following User Says Thank You to Spiceman For This Useful Post:
    WAJ
  19. #15
    Jul 2014
    Thanked: 827
    By the time I am done with this lorrie it will be a brand new truck
    Ex'es
    Daihatsu Rocky 2.8
  20. #16
    Jul 2013
    Thanked: 296
    Ai maar die vibrations kan jou mal maak en jou moermeter rooi toe stoot.
    Het eenslag gelees n ou het so probleem gehad en die kant toe en daai kant toe. Niks
    Toe ontdek hulle n klip wat vasgesteek het onder die sump en crossmember.
  21. #17
    Jul 2014
    Thanked: 827
    Quote Originally Posted by janseekat View Post
    Ja daai vibrasie is net erg as hy staan en idle, die hele kajuit dreun so die wax in my ore wil al uitval, maar sodra ek ry is als fine.
    Ex'es
    Daihatsu Rocky 2.8
  22. #18
    Thanked: 272
    Kan ek dalk die naweek kon vir waks terapie? Ek sukkel effe met te veel waks in die ore.
  23. #19
    Jul 2014
    Thanked: 827
    Het die lorrie terug gekry met nuwe engine mountings - die oues was poegaai, rubbers heeltemal af.
    Ten minste voel dit nou nie meer asof die engine gaan uitspring as hy start nie, en die vibrasie is ietwat beter.
    Hulle sÍ vir my dat die dual mass flywheel ook effens van 'n vibrasie kan gee as hy al bietjie gewerk het (179,000 kilos) so ek leef maar daarmee saam todat ek eendag die clutch moet doen, maar sovÍr werk die clutch nog fine.
    Kan mens die idle spoed effens opstel of die 3.0 en, wel, indien ja, HOE?
    Ex'es
    Daihatsu Rocky 2.8
  24. The Following User Says Thank You to WAJ For This Useful Post:
  25. #20
    Thanked: 272
    Sit 'n baksteen op die versnellerpedaal.
