4m40 engine
Results 1 to 13 of 13
Thread: 4m40 engine
    durban
    Unhappy 4m40 engine
    Greetings
    I would like to know the exact size of a spanner or socket that I can but to turn the 2800tdi 4m40 engine on the pulley in front of crankshaft underneath.
    I left my car last year in the garage and my son delayed to start and run it, it's been 5 months now without running. I want him to turn it manually sothat it won't seize.
    I will also request any advices on danger of car not running for that long please.
    Tia
    Thanked: 13607
    Default Re: 4m40 engine
    Please don't turn that engine on the crank pulley bolt. A high compression diesel is very difficult to turn and he can easily damage the bolt or even the pulley and crank.
    Rather just spin the engine 1 or 2 turns with a quick flick of the starter.
    durban
    Thank you very much, how dangerous is it to leave it until I come back September?
    Thanked: 13607
    Depends where it is. Near the sea might be an issue but I've seen cars start after being stored for years. Rotten diesel should be your bigger worry.
    Thanked: 2444
    Unless he is hulk hogan, he can not by hand exert enough force with a spanner to damage that bolt.
    Turn it.
    However, if it was only 5 months, I wouldnt worry. (Not recommended though)
    I have opened engines that stood for years and the bearing surfaces were pristine. (Engine was stored properly though)
    A car that stands, breaks. He needs to drive it. 50km at least once a month to get drivetrain up to temp etc.
    Postmasburg
    Thanked: 255
    Why dont you just let him start it and let it idle for 10min each month?
    durban
    He can't drive thats why I am in this trouble.
    durban
    Yes it's in the coast
    durban
    I am thinking of replacing all fluids before I even start and drive it, engine oil, gear box oil, diff oil, coolant.
    Langs die rivier, op n berg
    Thanked: 2980
    Sal more kyk, daar is een op my vloer wT ek nounet hetbou het. Jy kan maar draai asn daai bout, die nms waarmee dit getorque word, is baie meer as wat dit vat om engine te crank.
    Maar.... 5 maande::: dit is niks. My grootste worry sal wees of battery nog krag in het.
    Jy kan maar start as battery nog dit in hom het.
    Thanked: 2980
    24mm socket.
    durban
    24mm socket.
    Thank you
    durban
    Sal more kyk, daar is een op my vloer wT ek nounet hetbou het. Jy kan maar draai asn daai bout, die nms waarmee dit getorque word, is baie meer as wat dit vat om engine te crank.Maar.... 5 maande::: dit is niks. My grootste worry sal wees of battery nog krag in het.Jy kan maar start as battery nog dit in hom het.
    Yes the problem is the battery has gone pap, that's why I want him to keep on turning it using a spanner or socket
