Best 4x4 tires for deep sand
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 76
    Humansdorp
    Thanked: 22
    Default Best 4x4 tires for deep sand
    Hello everyone. Which tire profile do you think is best for sand? ATs (All Terrain) or MTs (Mud Tracks)?
    I preffer the less aggressive AT tires but the MTs look damn nice
    Which are the most effective ones though?
    I love Mozambique!
  2. The Following User Says Thank You to Gomario For This Useful Post:
    Sep 2018
    Not too far from Pofadder
    Thanked: 432
    Default Re: Best 4x4 tires for deep sand
    I did extensive reading into this subject while preparing for an rather ambitious Dune trip , there is a lot of different opinions , but in general you want as much surface area as possible , apparently a tire with less or zero sipping is better.
    I went with AT in the end as I deflate as much as I can and try to drive on top of the sand, though if you have lots of torque available and can fit huge tires for serious dune climbing MT will do better.
    Amanzimtoti
    Thanked: 198
    Have both sets for my Wrangler. ( muds and ATís ) found ATís better in sand...muds want to dig in rather than float over sand.....maybe just my driving style.
    Now donít ask forum for advice on which brand is best
  5. The Following User Says Thank You to Andrepb For This Useful Post:
    Kathu
    Thanked: 2898
    We have tested them side by side. Same vehicle, same day, same dune. MT did go further.
  7. The Following 5 Users Say Thank You to grips For This Useful Post:
  8. #5
    Ellisras
    Thanked: 607
    Here is a simple test for you:
    Fit one of each of the tyres you have to decide between (Widths must be the same to compare apples/apples)
    Pump the tyres to 2.5 Bar
    Park the vehicle on sheets of A3 paper
    Trace the tyre contact perimeter on the paper
    Repeat with different colours while lowering the pressure
    Do it at the following pressures
    2.5
    2.0
    1.5
    1.2
    1.0
    0.8
    0.7
    0.6
    You will be supersized which gives you the largest contact patch
  9. The Following User Says Thank You to Dungbeetle For This Useful Post:
  10. #6
    Okahandja, Windhoek
    Thanked: 875
    Quote Originally Posted by Gomario View Post
    The one you have. Unless you drive 90% of the time sand . Then is it dunes or flat areas?
    Johan Kriel
  11. #7
    Humansdorp
    Thanked: 22
    Here are the two profiles in question. Both are Bridgestone Duellers. They are the exact same size but I could not get the pictures right.
    I love Mozambique!
  12. #8
    Kathu
    Thanked: 2898
    There is a reason why Sandrails and Dune buggies run scooper tyres
  13. #9
    May 2017
    Thanked: 171
    Have a look at this video as well, might help:
    https://youtu.be/M6j2jia0kII
    2015 Pajero Sport Shogun
    2012 Kia Cerato Hatch
  14. The Following 3 Users Say Thank You to Hendel1986 For This Useful Post:
  15. #10
    Thanked: 1031
    My understanding is thus:
    If your vehicle is not particularly powerful, and/or if the sand you want to drive on is relatively flat, you want the smoothest and softest-construction tire you can get away with. H/T (highway/road) even better than A/T.
    But if you want to go upwards, and if you have a seriously powerful car, MT is the way to go.
    I also suspect that a set of bead-lock rims may be a better upgrade for sand than any given set of tyres. The lower the pressure you can run at, the more footprint you have, the better you will do on sand.
  16. The Following 2 Users Say Thank You to Peter Connan For This Useful Post:
  17. #11
    Swakop
    Thanked: 794
    From the one or two dunes I have driven the answer is MT, no question. The bigger the better, depending on what your engine can turn.
  18. The Following 2 Users Say Thank You to AboutAfrica For This Useful Post:
  19. #12
    Mar 2013
    Swakopmund
    Thanked: 135
    The tour guides on the Namib Desert dune trips use Mud Terrain tyres on their vehicles.Enough said.
    Swakopmunder
  20. The Following 3 Users Say Thank You to basie oosthuizen For This Useful Post:
  21. #13
    Kathu
    Thanked: 2898
    Peter I have successfully run tyres at 0.5 bar for many years with no bead-locks with only a few debeads. Yes the wider the footprint the better. That is why 35 x 12.5 and 33 x12.5 work so nice in sand.
    I grew up with the believe that smooth tires are the way to go for sand. Over many years of all sorts of sand driving I doubt that smooth tyres are the best for sand even flat sand. More important is tyre pressure and footprint like you have said.
    But when it comes to tyre pressure and sand driving I keep a low profile on these topics. Everyone have his own idea and experience
    about sand driving. Have read here that guys think the sand in the Letaba and Molototsi riverbeds is serious sand driving. When doing the River Trip a few years ago I found the sand very easy going. The criteria of sand driving is just too big.
    Wat vir party ouens se berg is as dit by sandry kom is die volgende ou se molshoop.
  22. The Following 5 Users Say Thank You to grips For This Useful Post:
  23. #14
    Kathu
    Thanked: 2898
    Quote Originally Posted by AboutAfrica View Post
    The truth short and sweet
  24. The Following User Says Thank You to grips For This Useful Post:
  25. #15
    Okahandja, Windhoek
    Thanked: 875
    Even Google believe in smooth tyres, but to me it make no sense. Maybe for an aeroplane yes!
    Johan Kriel
  26. The Following User Says Thank You to JLK For This Useful Post:
  27. #16
    Oranjemund Namibia
    Thanked: 449
    I live in Namibia and know a little bit about sand driving.
    Surveyor, worked extensively in the southern Namib.
    Driven my own vehicle to Meob bay (and back) 5 times.
    Etc.
    Tyre pressure is important and you can drive for 100's of km at 0.8.
    Softer sidewall tyres with rounded contact areas best.
    My best tyres for sand (worst for everything else) was the Bridgestone dueler at.
    Worst Tyre for sand but best for everything else is the bfg at (sharp sidewalls, cuts into the sand).
    I say best and worst but either is fine for a trip through the dunes and there is no reason to buy a set of tyres just for a big dune trip, just go with the ones you have.
    Kimball R. Pitcher
    Head - 2007 Toyota Fortuner, OME, extra tank, roof rack, bent running boards
    Heart - SFA hilux dcab
  28. The Following 9 Users Say Thank You to KimballR For This Useful Post:
  29. #17
    Humansdorp
    Thanked: 22
    Quote Originally Posted by KimballR View Post
    Etc.
    I am hearing you. Powerful enjine + mud tires = Trouble on Sand. OK, if you are very experienced, have a foot reaction time of less than 1/10 of a second AND know EXACTLY when to lift of the accelerator, than MT are for you. But for everybody else, including Johny Bravo and myself, MT will help you more to get stuck than move forward. The Duellers ATs are damn good tires for sand but the MTs look like a million dollars
    Thank you every body for the nice inputs
    I love Mozambique!
  30. #18
    Dec 2018
    Thanked: 248
    I concur. Two previous sani's. First one had near racing slicks when it was purchased and those floated over the sand even at full psi. Second Sani had MT's and struggled over the same sand time and time again.
  31. #19
    Thanked: 14221
    The Arabs use tyres with no tread. They should know best.
  32. The Following User Says Thank You to jelo For This Useful Post:
  33. #20
    Sep 2016
    BogotŠ
    Thanked: 51
    AT in my view.
    I think that it's important to consider what you're driving on to get to the sand and back again. If you're going to drive 1000 Km of tarmac before reaching the dunes, you may not want MTs...
