DIY - Alcohol Pot Still using a Copper Water Geyser - Page 8
Page 8 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 141 to 160 of 208
  1. #141
    Richardsbay, KZN
    Thanked: 14165
    Default Re: DIY - Alcohol Pot Still using a Copper Water Geyser
    Quote Originally Posted by ColeGP View Post
    I hate to tell you this but I don't think you will be able to find one, I also was looking out of interest as I am considering making some adjustments but there seems to be no stock locally.
    You may need to get a stainless steel one and have somebody braise it for you (vs solder)
    Probably the best way. With the column upgrade this side I was surprised how not cheap the bigger sizes of compression couplers are, ie copper to male iron with back nut for 42mm to connect to the lid. As I am building two it ain't funny and being so seldomly required we don't stock them so special order it is.
    Walker Evans, Photographer
  2. #142
    Thanked: 991
    A small machining shop with no work could make a fortune.
    Who's got the SS ones, Ketelkraal had none of those either.
  3. #143
    Thanked: 167
    Try guth or NDP they most likely will have the fittings, gaskets and the tri clamps.
    2009 Suzuki GV 3.2
    ex : 2010 Suzuki GV 2.4 M/T
  4. #144
    Thanked: 991
    For the record, my keg is Grade 304, stamped into the keg. I understand 304 to be food grade?
  5. #145
    Thanked: 14172
    Yes. Should be anti-magnetic.
  6. #146
    Thanked: 991
    Talking Tri-clamps.
    Picked mine up today. It came with the silicone gasket which has location ridges on both sides. The keg does not have a ridge.
    Do you get the sealing rings ridged on one side only?
  7. #147
    Thanked: 167
    Talking Tri-clamps.
    I cant find the video now but there was a guy on youtube who very carefully uses a sharp stanley knife to cut the ridge off the one side... voila.
    ha found the video
    https://www.youtube.com/watch?v=Y3XPHXfjanw
    2009 Suzuki GV 3.2
  8. #148
    Thanked: 991
    Gasket Modified.
    So I am wanting to get the PID controller in a box and all sorted. I do not want the incoming power or the power to the element to be permanently wired into the enclosure so was thinking of using a IEC C13 and C14 combo plug (ones in the rear of a computer tower). These however are rated at 10A and I need 15A.
    Any suggestions?
  9. #149
    Gaborone, Botswana
    Thanked: 1196
    My PID will be wired with a 3 pin female plug build into the side of the box. A normal round pin wall plug.
    I will then just plug the existing power cord for my element into the 3 pin on the box.
    Kobus
  10. #150
    Thanked: 991
    I can't see another way out of either.
  11. #151
    Thanked: 167
    I built a box out of wood for my STC1000, and wired up a 3 pin plug receptacle, keeps little hands from pulling on wires.
    What I am trying to do is get my hands on a 3 pin receptacle that allows each plug to be wired seperately (used to be like that in the old days, threw away a ton of them when we rewired our home )
    Then I will be able to wire one plug to come on for cooling and the other plug to come on for heating.
    2009 Suzuki GV 3.2
  12. #152
    Thanked: 991
    I think I may go with this for the element side.
  13. #153
    Thanked: 991
    Water flow.
    So the reason for the water in at the bottom out at the top is not to get a temperature gradient but if if you fill from the top you are never assured of having a full Liebig as gravity is not your best friend. So that got me thinking. I have bought a gate valve for flow control, this then would be best suited on the output (hot side) from the Liebig?
  14. #154
    Thanked: 167
    Water flow.
    correct, you install the valve at the top.
    2009 Suzuki GV 3.2
  15. The Following User Says Thank You to ColeGP For This Useful Post:
  16. #155
    Thanked: 991
    So some progress. I can't rotate the pic. Will trim the distillate outflow pipe only once fully mounted to the column and mounted on the keg.
Name:	Completed Liebig.jpg
  17. #156
    Thanked: 991
    Talking parrots.
    Why the huge discrepancy in heights of the two bowls in a parrot. I cannot see why they cannot be the same height based on the fact that water will find the same level.
  18. #157
    Thanked: 167
    Talking parrots.
    The pipe on the left if where the distillate drips in, it has to be higher on the left in order to ensure that it does not overflow as you want all the distillate to come out on the right, if it is the same level once it fills up the distillate will start to pour out over both sides.
    It doesnt need to be a huge difference, 5cm should be sufficient.
    2009 Suzuki GV 3.2
  19. #158
    Thanked: 991
    Deleted, comment posted not accurate.
    Ok the penny has just dropped. I was relating it to the "parrot beak" and not the height of the tube in the middle.
  20. #159
    Thanked: 991
    More progress;
    First pass of 220grit, still lots of work to go.
    The straight SS Parallel Socket for the element is now welded in place. (The camera angle makes it look like its not square but it is).
  21. The Following User Says Thank You to Andrew Leigh For This Useful Post:
  22. #160
    Thanked: 991
    OK more progress. Remember the keg is purely a transition to get me distilling while I convert the geyser into a kettle.
    So in the picture the column is not vertical as it is not yet brazed, hoping my mate will Braze / Silver Solder it for me tomorrow. The unions have also not been fitted hence the 15mm copper pipe holding up the condenser. The element will be positioned to the rear but for illustrative purposes is shown here. I need to continue polishing up the keg and will polish up the copper when all the soldering and brazing is complete.
    If I am to cut the column it needs to be tonight. To me it simply looks too long to be a pot still. I will be removing 50mm in any event in order to fit a top cap to the top of the T Piece. This will make the column height 580mm from the base to the c3ntre of the 22mm output of the condenser.
    I would appreciate input on this.
  23. The Following User Says Thank You to Andrew Leigh For This Useful Post:
