Defender Rain water as coolant.
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 71
    Oct 2018
    Pinelands
    Thanked: 13
    Default Rain water as coolant.
    First question, can I use rain water collected in a bucket with a cloth filter over the top as engine coolant.
    Second question, I have the Wurth radiator coolant (Red) that I bought some time back but forgot to ask if it is concentrated or pre-mix. The label is a bit vague but it does say do not dilute which is either as it is already pre mixed with water or for sales reasons.
    Anyone have an opinion?Name:  IMG_2697.jpg
    Tshwanetoria
    Thanked: 745
    Default Re: Rain water as coolant.
    Rain water is not distilled water or "clean". It may contain varying amounts of acid and other chemicals/contaminants, depending on how polluted the atmosphere in your area is. I would rather buy the real McCoy. If you can't, rather use boiled tap water.
    The results of cooling system corrosion can be very expensive
  3. The Following 2 Users Say Thank You to hatjohan For This Useful Post:
    Oct 2018
    Pinelands
    Thanked: 13
    Ok. Will go back to Wurth Monday to get more and if necessary buy some distilled water.
    Thanks for reply
    Malawi
    Thanked: 1180
    Quote Originally Posted by one-more-landy View Post
    That Wurth coolant is premixed , you add it as it is .
  6. The Following User Says Thank You to tashtego9 For This Useful Post:
    Wilderness
    Thanked: 1170
    Also, rainwater collected from the roof is far from clean. What do birds do on the roof?
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
    Oct 2018
    Pinelands
    Thanked: 13
    Not from roof - bucket out in the open.
    Thanked: 13545
    Still no.
  10. The Following User Says Thank You to jelo For This Useful Post:
  11. #8
    Jul 2013
    Thanked: 295
    Boil it.
  12. #9
    Thanked: 515
    Why would one boil rain water before using it in the engine?
  13. The Following 2 Users Say Thank You to ekkekan For This Useful Post:
  14. #10
    Thanked: 13545
    Precipitate solids
  15. The Following 3 Users Say Thank You to jelo For This Useful Post:
  16. #11
    Barberton
    Thanked: 1182
    Precipitate solids
    All solids, or just the carbonates??
  17. #12
    Tshwanetoria
    Thanked: 745
    OK, maybe I am complicating it by adding the "boiling" angle. But I come from an Anglia and a Cortina mk1 background where in those days, frequent top-ups were at the order of the day. Significant carbonate ( "lime") deposits ( the same that you still found in today's' kettles and urns and geysers) in the cooling system was rather common.
    Nowadays, the cooling systems are more refined (or supposed to be) and more "sealed" and requires less if any top-ups.
    BUT, impurities may be more of a danger - me thinks.
  18. #13
    Tshwanetoria
    Thanked: 745
    "boiled tap water"
  19. #14
    Cape Town, Plumstead/The Sea/Franskraal
    Thanked: 554
    Put the dam water in, will do nothing, one or two litres of water will hardly contain enough of anything to cause a problem, how long does it take a kettle to scale up after boiling thousands of litres.
    Have now covered 270 000Km on veg oil.
    Oh, and an Isuzu 280DT, 40 000Km on Bio Diesel
    Rand for Rand gets 33Km/L
  20. The Following 11 Users Say Thank You to ZuluCowboy For This Useful Post:
  21. #15
    Plett/Paulshof
    Thanked: 986
    Distilled water is for batteries. Nothing wrong with tap water and coolant for radiator so long as ratios are correct. Who knows what is in rain water collected in a bucket unless analysed.
    my question is why would you want to do that in any case when you have tap water? Water the garden with rain water.
    2020 FJ Cruiser, 2020 Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), 2019 FJ Cruiser, Bush Lapa ?, Fusion 17 boat-Yamaha FT100hp 4st.
  22. The Following 2 Users Say Thank You to BruceHun For This Useful Post:
  23. #16
    Jul 2013
    Thanked: 295
    Have you guys probed a radiator with your finger,as well as the cap.
    Where does the muddy slush come from ?.
    The inside of the overflow bottle the same.
    I may add , a system left as is for a long time , points to unfiltered tap or rain water.
    2C
  24. #17
    Mar 2015
    New Germany
    Thanked: 479
    are you talking about rain water to get you out of a emergency that radiator needs water, or using it permanently with antifreeze
    2005 Defender TD5
  25. #18
    Dec 2015
    Harare
    There has been an increase in lost engines in Zim with the use of borehole water in radiators.
    Holes form in wet sleeves and internal corrosion elsewhere. An increase in electrolysis due to the minerals in the water has been muted.
    We've noticed along with this that Ph levels play their part in the corrosion of aluminium and copper components.
    It's akin to cancer, engine cancer as the effects are all internal and unseen until failure occurs.
    Just putting it out there.
  26. #19
    May 2016
    Thanked: 3034
    Water is not a good coolant.
    Use proper coolant.
    To dilute it to the correct ratio, just about any potable water will do.
    2006 VW Touareg V10 TDi
  27. #20
    Plett/Paulshof
    Thanked: 986
    Quote Originally Posted by James Stevenson View Post
    my point exactly. Why are they using water only?
