Spray painted braai dome, can it be saved?
Results 1 to 6 of 6
    Feb 2013
    Thanked: 326
    Default Spray painted braai dome, can it be saved?
    Hi all
    I got this small gas braai with a dome lid, a very convenient thing.
    Problem is, someone went and spray painted the metal dome lid with normal spray paint, inside and out.
    How can I save it and get it safe for use again, will it even be possible?
    If I apply heat now, I get some potent fumes which only worsens as the dome gets really hot.
    Melkbosstrand
    Thanked: 468
    Default Re: Spray painted braai dome, can it be saved?
    Paint remover/stripper
    Sand Paper
    Lots of elbow grease / even sand blasting
    Re-spray
    Here before & after pic of mine.
ID:	573698Click image for larger version.
    Everybody needs to believe in something.... I believe I will have another Beer!
    Travel Blog: https://since1652.wordpress.com/
    https://www.instagram.com/since1652travel/
  3. The Following User Says Thank You to Papsak For This Useful Post:
    Apr 2014
    Thanked: 3512
    Papsak is right. Depending on the original paint paint remover will take off everything. Buy it plus brush and have some scraper/s. We have "like new" enamel painted plug and light switch covers etc.
    Jouko
    2003 Grand Cherokee 4.7l
    2012 Smart
    Never drive a normal car 8)
  5. The Following User Says Thank You to Jouko For This Useful Post:
    Apr 2017
    PUMULA
    Thanked: 306
    If heat paint for a braai is used, even with proper heat paint the first few times you will get fumes. You need to heat it up to get rid of the fumes.
    As it is a enclosed dome braai, proper heat paint is needed.
    I would be very warry, heat it up a few times and see.
    I would start from the beginning and redo completely.
    Current off-road vehicles: *** Great family accommodation. See Facebook, Google maps and airbnb. Wild Wind Ranch/Mkulu Kei
    * 1975/8 SHREK Land-Cruiser FJ40 DIESEL P/U, BFG 31x10.5 muds. 2 x 1.6 ton tirfor winchs
    * 1994 Land-Cruiser J70 DIESEL P/U, my truck recovery vehicle. 15000 warn winch. And 3.5ton tirfor winch. Back full of appropriate sized recovery gear. BFG31x10.5 muds
    * 2014 Land-Cruiser LX V8 76 DIESEL STATION WAGON, BFG's 285 all terrain.
    * 1988 HILUX TOYOTA 4x4 D/C.
    SOLD 2020 Jan.
    * 2011 HILUX 4X4 P/U, BFG 31x10.5 all terrain
    * 1999 PAJERO 3.5 V6 Mitsubishi (sorry not a Toyota), BFG 31x10.5 all terrain
    * 2006 FORD ranger 2.5 diesel. 4x4, (what was I thinking, also not a Toyota!) I have a spare 5000 warn winch I might fit.
    * 2011 Isuzu bakkie 4x4
    * FIONA - Rhino Yamaha 660 4x4. Warn winch. Mud tyres
    * 4x4 trailer, 1987, BFG all terrain
    * GSA 1200 BMW ADVENTURE LC 2018, the closest motorbike to a land cruiser
    * A Massey Fergusson 375 tractor. Not BFG's and not a 4x4
  7. The Following User Says Thank You to K-9 For This Useful Post:
  8. #5
    Ruimsig
    Thanked: 10806
    As an option, consider sending it in for enamelling or porcelain.
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
  9. #6
    Wilderness
    Thanked: 1196
    Place a metal container in it with water. Switch it on and heat it up until it stops smelling. Use as normal.
    Scared of poisoning yourself.
    Us 60's babies: grew up in cots painted with lead paint, rode bicycles without helmets and fell ourselves into hospital.. Our mothers and fathers smoked , drank and used drugs. We climbed and fell out of trees. We all drank straight from the same tap without a class. When one of us got sick from mumps or chicken pocks. We were all bundled into the same room so that we can get sick and build up resistance. We swam in the rainwater ditches when it rained. There is a lot more.
    Get over it!
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
